Can anyone suggest a method to represent an asteroid belt for an orrery I'm
making?
Nothing too fancy as there will be lots of other objects in the scene and I
think it will end up as an animation. I was thinking of something to fill a
torus with grain like objects. The orrery will not be realistic, astronomically
correct just something to give the impression of an asteroid belt.
Thanks in Advance.
Regards
Hi Ken,
sorry for this error -- just before I was browsing p.b.i. ...
The help of this outlook tells me I can only clear *downloaded*
postings from *my* computer, so how can I delete from the
*newsgroup*?
Sputnik
// Hi Stephen,
// I've just posted "Asteroids and more for Stephen ... [46 KB JPEG]" to
// p.b.i. That image was an easter joke, but the asteroids could be a
// starting point for you. The following code is a fragment from this
// scene (but ready-to-render), containing only a minimal scene with
// asteroids made of spheres. Some comments (in english) are added, I
// hope you can live with the german words.
// Sputnik
// P.S. I assume it's OK to post such a small SDL "inline" snippet as a
// direct answer in this group, or should I have posted it to p.t.s-f?
// +SP8 +EP8 +W1280 +H1024 +A0.1 +AM2 +R3 +B100 -FN
// Asteroids ----------------------------------------------------------------
#declare Number = 300;
#declare Rand = seed(89797234);
#declare I = 0;
#while (I<Number)
// choose random orbit (see translate statement below), random brightness
#declare R = rand(Rand)-0.5;
#declare Brightness = .8-.3*rand(Rand);
// create an asteroid in the origin; random size 0.04 ... 0.12
sphere { 0, 0.04+0.08*rand(Rand)
// put onto orbit at radius 7+some_variation
// The function 7+(4*R*R+1)*R maps R from the range [-0.5...0.5] to the
// range [6...8]. Because this function has a steep/not_so_steep/steep
// shape, the result is more likely to be 7 than 6 or 8, so the asteroid
// density at 7 is larger than at 6 or 8.
translate ( 7 + (4*R*R+1)*R ) * x
// let asteroid orbit to a random angular position
rotate 360*rand(Rand)*y
// apply a simple random texture
pigment { color rgb <1, 1-.2*rand(Rand), 1-.2*rand(Rand)>*Brightness }
finish { ambient .3 diffuse .7 }
// a must if sun and all asteroids are in the same plane
no_shadow
#declare I = I+1;
// Kamera und Beleuchtung ---------------------------------------------------
#declare Uhr = 360/12;
#declare Aspekt = image_width/image_height;
#declare Aspekt = 1024/768;
#declare Bildhoehe = 8;
#declare Bildbreite = Aspekt*Bildhoehe;
#declare Bildentfernung = 2*Bildhoehe;
#declare Fokus = 0;
#declare Fokusentfernung = 33;
#declare Kamerarichtung = 6*Uhr; // als "Uhrzeit"
#declare Kamerahoehe = 23; // in Grad
#declare Linksneigung = 20;
location -Fokusentfernung*z
right Bildbreite/2*x
up Bildhoehe/2*y
sky y
direction Bildentfernung/2*z
look_at 0
rotate Linksneigung*z
rotate <Kamerahoehe, Kamerarichtung-180, 0>
translate Fokus
light_source { 0, rgb 1 }
// ENDE =====================================================================
On Tue, 1 Jul 2003 05:20:06 +0200, "Frank 'Sputnik' Rothfuß"
<fr### [at] computermuseum fh-kiel de> wrote:
>// Hi Stephen,
Thanks a lot. It's more than I expected, the sample code is just what I want,
fast too.
Common Europe, of course I can. The comments are germane and easily understood.
Regards
>// p.b.i.
Frank, thanks again. I've posted an image in p.b.i of a WIP using it. My reader
started an new thread called Re: Asteroids and more for Stephen
Regards
