POV-Ray : Newsgroups : povray.general : [feature suggestion] exponential blobs Server Time
22 Oct 2026 05:23:38 EDT (-0400)
  [feature suggestion] exponential blobs (Message 1 to 4 of 4)
Subject: [feature suggestion] exponential blobs
Date: 23 Jun 2003 04:48:24
Message: <3ef6bed8$1@news.povray.org>
Hi there,
I recently experimented a bit with isosurface and blob objects. This is what
I got:
http://matthias.hullin.net/bilder/blobtest.gif
The upper series consists of exponential blobs, which I generated using the
isosurface object. To me, it looks much smoother, kind of "more organic"
than the linear blobs shown below.
What about adding an "exponential" keyword to the blob object? All it would
have to do is toconvert the objects in a suitable function and then
calculate the isosurface.
(But probably I'm not the first one with that idea.)
All the best,
Matthias
Subject: Re: [feature suggestion] exponential blobs
Date: 23 Jun 2003 04:53:13
Message: <3EF6BFF9.AC4BD0DC@gmx.de>
http://www.tu-bs.de/~y0013390/pov/ic/docu02.html#EBlob
Last updated 17 Jun. 2003 _____./\/^>_*_<^\/\.______
Date: 23 Jun 2003 06:49:00
Message: <3ef6db1c@news.povray.org>
Hi Christoph,
thank you! That's looking quite good!
Matthias
Date: 23 Jun 2003 22:50:09
Message: <cjameshuff-21B547.21390723062003@netplex.aussie.org>
In article <3ef6bed8$1@news.povray.org>,
The blobs in POV-Ray are not linear. Linear functions do not "blob", I'm
not really sure what you meant. The shading problems are due to
discontinuities in the second derivative of the function. Also, it's not
clear what function you are using...but if the function is not bounded,
each new component will affect the entire blob, making computation
slower and the entire blob less controllable.
The root solver used by the blob object is very special-purpose. Using a
more general solver similar to that used by isosurfaces makes many more
primitives possible, but it would be better to make an entirely new
object to take advantage of that flexibility: a "superblob" or "blob2"
primitive.
http://news.povray.org/povray.advanced-users/28049/
http://news.povray.org/povray.binaries.images/28102/
http://news.povray.org/povray.binaries.images/28197/
I now have a working version of the shape patch I described in that last
one. (though the pattern is currently non-functional) It currently
supports spheres, boxes, and toruses, but I'm planning to eventually
implement cylinders, cones, superellipsoids, shells, tubes, and
function-based primitives, as well as the ability to define the falloff
curve with a function. The solver is a custom one I wrote from scratch,
nothing based on the isosurface primitive code. If anyone wants more
details, I'll start a thread in *.programming.
http://tag.povray.org/
