POV-Ray : Newsgroups : povray.general : Offloading some calculations to a GPU Server Time
2 Nov 2026 08:54:48 EST (-0500)
  Offloading some calculations to a GPU (Message 1 to 19 of 19)
Subject: Offloading some calculations to a GPU
Date: 11 Jun 2003 11:30:01
Message: <3ee74af9$2@news.povray.org>
Most modern PCs have a very powerful 3d video card with a GPU that is
hundreds if not thousands of times faster than the CPU for certain
calculations. I was thinking if some of the POV computations could be
offloaded to the GPU, we could speed up renders by a very large factor. The
big question is one of which routines thouse would be and which chunks of
the GPU could be utilized. Certainly matrix operations could be offloaded at
the very least, although I don't know to what extent that would improve
performance. It's just a shame that there is this uber-powerful floating
point processor sitting in most PCs that can't be used to help things move
along. What do others think?
Subject: Re: Offloading some calculations to a GPU
Date: 11 Jun 2003 11:33:04
Message: <3ee74bb0$1@news.povray.org>
In article <3ee74af9$2@news.povray.org> , "Michael Goldshteyn"
You need double precision floating-point processing.  Sorry!
    Thorsten
Date: 11 Jun 2003 11:47:17
Message: <3ee74f05$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3ee74bb0$1@news.povray.org...
The
of
offloaded at
move
>     Thorsten
Sorry, I accidentally e-mailed my reply, instead of posting it.
In any case, a quote from NVIDIA's web site:
And, powered by the second-generation NVIDIA CineFXT 2.0 engine with the
industry's only true 128-bit precision processing--the GeForce FX 5900 GPUs
take cinematic-quality special effects to new levels while providing the
industry's most compatible and reliable gaming platform.
Now, double-precision uses 64-bit floating point, so I think this is more
than enough.
Date: 11 Jun 2003 11:50:01
Message: <web.3ee74ea3d3e4b3b1465fc1770@news.povray.org>
I wanted answer almost identicall but I'm completly dumb in that area so did
quick search in google. It answered there are GPUs with 128-bit
floating-point precision.
ABX
Date: 11 Jun 2003 11:55:55
Message: <3ee7510b$1@news.povray.org>
After doing more reading, the 128 bit precision may refer to 32-bit floating
point times four. So, in fact, the GPU may only be single-precision per
color.
Date: 11 Jun 2003 12:57:34
Message: <3ee75f7e$1@news.povray.org>
In article <web.3ee74ea3d3e4b3b1465fc1770@news.povray.org> ,
No, you simply fall for a good trap their marketing people have set up.  The
GPUs are SIMD processors and the units work with four single precision
floating-point numbers*.  Hence, for a marketing person it works with 128
bits precision using floating-point numbers <sigh>
    Thorsten
* The smallest document on the Nvidia site that details the marketing math
is <http://developer.nvidia.com/docs/IO/3121/ATT/CineFX-TechBrief_v02.pdf>
e-mail: tho### [at] trfde
Date: 11 Jun 2003 14:33:40
Message: <3ee77604$1@news.povray.org>
But do you *really* need it for everything
Kitty5 NewMedia http://Kitty5.com
PGP Public Key
Date: 11 Jun 2003 14:40:24
Message: <pmteevkvm0gutj413ddie2rpdjontfdeeg@4ax.com>
On Wed, 11 Jun 2003 19:31:17 +0100, "Rick [Kitty5]" <spa### [at] kitty5com> wrote:
Single precision floats are used for colors in POV sources.
ABX
Date: 11 Jun 2003 15:37:15
Message: <3ee784eb$1@news.povray.org>
In article <3ee77604$1@news.povray.org> , "Rick [Kitty5]"
You need it for intersection tests.  You cannot store enough data in 32 bits
to perform adequate intersection tests without limiting the geometry.
You seem to misunderstand what precision anything stored in 32 bits can
possibly provide.  From a more conventional perspective, I would suggest to
get a introduction to combinatorics book and read the chapter on the
pigeonhole principle.
    Thorsten
Date: 11 Jun 2003 17:18:07
Message: <cjameshuff-0BE258.16094311062003@netplex.aussie.org>
In article <3ee74af9$2@news.povray.org>,
As others have mentioned, because of precision issues, this isn't useful
for geometry calculations. But more importantly, this isn't like a
floating point coprocessor, it is a video card, and is designed to
efficiently display things. Even if the card can do the operations
faster, it will take far more time to send the data to the card to be
processed and then retrieve it than it would to process the data on the
CPU. There are some things it could accelerate, but typically not what
POV needs.
With more programmable cards becoming available, you can do more
general-purpose things with the card...it may be possible to process
data in large enough chunks that it is worth it to use the card, maybe
even doing all the raytracing on the card. However, you'd most likely
have to design the raytracer around this, I don't see anyone converting
POV to do it. And then you have the hardware dependencies, etc...
http://tag.povray.org/
Date: 12 Jun 2003 17:24:31
Message: <3ee8ef8f$1@news.povray.org>
>     Thorsten
What if... we limited the scene extents (in a seperate
version of POV-Ray, of course) to some small volume
like 1024 cubic units where single-precision floats
would be more viable? One could only render small scenes
or single objects, but when developing single objects
(like people or cars), that's acceptable.
The Tachyon raytracer
http://jedi.ks.uiuc.edu/~johns/raytracer/
has an option to build using
single precision (I imagine typedef'ing POV's DBL type
to float instead of double would be analogous), and
its author reports a 5-20% speed increase even without
hardware leveraging. He had to customize his epsilon
constants but I think it shows that using single precision
is possible. If I was modeling a chair or whatever,
I wouldn't turn down any speed improvement, even if
the occasional triangle had a gap.
POV's bounding slab bbox are already single-precision,
interestingly. BBOX_VAL is type SNGL.
Ray Gardener
Daylon Graphics Ltd.
"Heightfield modeling perfected"
http://www.daylongraphics.com
Date: 12 Jun 2003 20:53:24
Message: <cjameshuff-094936.19450412062003@netplex.aussie.org>
In article <3ee8ef8f$1@news.povray.org>,
1024 units would probably still be a bit large. This has been done
before, and is actually slower on modern systems (there was a thread
about it recently on comp.graphics.rendering.raytracing). You go through
a lot of contortions to get it to work, and get a more limited, lower
quality, slower renderer as a result. Now do you see why?
Yes, so are mesh vertices. In the former case, precision errors are
relatively unimportant. In the second case, it is a matter of practical
storage of large meshes, made possible by the fact that the intersection
calculations don't stress the precision much. There are other objects
that strain the limits of double precision, Tachyon only has spheres,
infinite planes, triangles, rings, cylinders, boxes, a kind of
internally generated fractal height field which is tessellated to a
mesh, quadrics, voxels. Probably the most precision-requiring one is the
generic quadric, a second-order surface. POV supports generic cubics
(third order), toruses and generic quartics (which are fourth-order),
and generic polynomial shapes up to 7th order. Also, blobs, julia
fractals, lathe/sor, prism, sphere sweeps, superellipsoids...you get the
idea.
Date: 13 Jun 2003 03:10:33
Message: <3ee978e9@news.povray.org>
  I think that you misunderstand how floating point arithmetic works.
It's not about the maximum value. It's about precision.
  Granted, single-precision floating point numbers have a smaller upper
limit than double-precision. However, this upper limit is at about 3.4*10^38
(that is, 340000000000000000000000000000000000000), which is certainly
much larger than that 1024.
  That's because a bounding box does not need that much *accuracy*.
The maximum value of single precision is plenty for bounding boxes.
Which demonstrates well the whole point. Actual objects can often need
the extra accuracy in order to render properly.
Date: 13 Jun 2003 17:08:12
Message: <3eea3d3c@news.povray.org>
> This has been done
Hmmm...
To be sure, I downloaded Tachyon and built
double- and single-precision DOS versions and put
them to the test. The results (in seconds,
on a 633 Mhz Celeron):
island (an hf with reflecting water):
  44.131 DP vs. 32.903 SP
teapot (specular material with reflecting plane):
  12.898 DP vs. 9.993 SP
820spheres (a flat but shadowed sphereflake):
  18.135 DP vs. 13.971 SP
I also checked the images to test quality, but found
no discernable difference. No gaps, nothing.
Perhaps the raw computation time for double precision
is as good as or better than single precision, but
the memory latency is lower since half as much
numeric data is being referenced. Well, whatever it
is, there's a difference in favor of SP. I'm going
to try it later today on a modern box which has
a much faster memory bus as well, just to be sure.
As for the primitives, yeah, Tachyon doesn't
have the complex ones, but if it has enough,
and one can get SIMD or GPU assist in the bargain,
then that's not a bad little raytracer for some projects.
I wouldn't mind having a "turbo option" for simple
scenes in POV-Ray.
Ray
Date: 13 Jun 2003 18:51:28
Message: <cjameshuff-D0780B.17425613062003@netplex.aussie.org>
In article <3eea3d3c@news.povray.org>,
> > This has been done
Crap...thought I was replying to something else, and was thinking of
64-bit fixed-point here. Single-precision floating point isn't slower,
and even when the instructions execute in the same time, they take less
cache and RAM space.
Well, the scenes you tried only used planes, triangles, and spheres,
which aren't very precision sensitive. I think you'd have a lot harder
time with something like a torus, and a more complex, "real-world" scene.
> scenes in POV-Ray.
This would be extremely unlikely to happen...it would create a lot more
maintenance work. Many things would have to be separately tuned,
rewritten, or completely disabled for the single-precision version.
Date: 14 Jun 2003 16:40:51
Message: <3eeb8853@news.povray.org>
"Michael Goldshteyn" <mgo### [at] n-o-s-p-a-m-earthlinknet> wrote in
message news:3ee7510b$1@news.povray.org...
floating
> color.
Actually, the color on an FX5900 should be able to be set to 128bit instead
of 32bit (ie, 32bits per channel, as opposed to the typical 8).  However,
the vertex operations (ie, matrix transforms) are still single precision.
...Chambers
Date: 14 Jun 2003 16:41:41
Message: <3eeb8885@news.povray.org>
"Rick [Kitty5]" <spa### [at] kitty5com> wrote in message
news:3ee77604$1@news.povray.org...
No, just vertices.  Attempts have been made in the past using single
precision, and it's just not enough for raytracing.
...Chambers
Date: 14 Jun 2003 16:45:19
Message: <3eeb895f@news.povray.org>
"Ray Gardener" <ray### [at] daylongraphicscom> wrote in message
news:3ee8ef8f$1@news.povray.org...
> >     Thorsten
You seem to think the size of the scene matters.  This is the reason we use
*floating* point - the actual size doesn't matter, just the difference
between the largest and smallest objects.
Ie, two spheres that are 10,000,000 units across will render just as
accurately as two spheres that are 1 unit across.  However, if you put a
third sphere that's one unit across between the two spheres, then you'll
need the extra precision.
...Chambers
Date: 14 Jun 2003 16:47:17
Message: <3eeb89d5@news.povray.org>
message news:3ee74af9$2@news.povray.org...
The
at
The GPU itself is designed for a different pipeline.  It's not like a
coprocessor; that is, you can't just send vertices to it and get the
transformed vertices back.  You *can* process the vertices on the card, and
then have the card draw them.
...Chambers
