POV-Ray : Newsgroups : povray.general : heightfields, 16bit images and isosurfaces Server Time
22 Oct 2026 07:08:28 EDT (-0400)
  heightfields, 16bit images and isosurfaces (Message 1 to 29 of 29)
Subject: heightfields, 16bit images and isosurfaces
Date: 7 Jun 2003 22:15:13
Message: <3ee29c31$1@news.povray.org>
-Are 16bit TIFFs not supported in height_field?
It does work (no error), but the result looks like 8bit.
When I convert the TIFF to PNG first, it looks much smoother.
The TIFF was generated by Picture Publisher 10.
It this an issue with TIFFs in general, or only with TIFFs generated
by Picture Publisher?
-Is there a version of POV-Ray that supports more than 8bit/channel
in pigments, so that it is possible to make an iso-heightfield from
an 16bit grayscale image? (function{pigment{image_map{...}}})
I tried MLPov with an hdr image (converted with HCRedit), but still
the result didn't look as smooth as the 16bit PNG heightfield.
Maybe MLPov converts it back to 8bit when it is used inside a function?
Lutz-Peter
Subject: Re: heightfields, 16bit images and isosurfaces
Date: 7 Jun 2003 23:15:05
Message: <cjameshuff-5320EE.22062807062003@netplex.aussie.org>
In article <3ee29c31$1@news.povray.org>,
Probably not. From memory, POV supports 16-bit PNG grayscale, POT (some
odd kind of 16-bit GIF), and a little hack where it uses the red and
green channels of an RGB TGA file to store a 16-bit gray value.
Maybe neither. There've been problems with TIFF support before, it is
apparently quite common for software to not support it fully, and POV
does not mention it in the section on 16-bit formats.
Color math in POV is done as single precision floating point. The 8/16
bit limitation is internal to the file formats, not to POV.
I'm not sure how HDR images store the values, they may just not have the
precision you are expecting. They cover a wider dynamic range, and small
levels are useless in much of that range, so to save memory it may
distribute the levels more densely at the lower intensities. I'm not
sure what you're trying to do using them for a height field or
isosurface, if you want more precision you should just use a 16 bit
image. (And why compare a HDR isosurface to a PNG height field?) One
more thing: make sure you have bilinear interpolation turned on, the
isosurface solving algorithm doesn't deal well with the infinite
gradients between solid pixels.
http://tag.povray.org/
Date: 8 Jun 2003 03:44:10
Message: <3ee2e94a$1@news.povray.org>
In article <3ee29c31$1@news.povray.org> , Lutz-Peter Hooge <lpv### [at] gmxde>
They are not support anywhere, not only not in height_fields.  In fact, I
don't think 16bit PNG is support either...
If you use a 16 bit PNG and have verbose output turned on, you should see a
warning "Converting PNG image map to 8 bits/sample from higher bit depth."
    Thorsten
e-mail: tho### [at] trfde
Date: 8 Jun 2003 03:52:40
Message: <3EE2EB70.A5CC1158@gmx.de>
The hdr format is not a good idea for heightfields at all.  In official
POV you can currently only use ascii pgm for this purpose, next MegaPOV
will also support 16 bit binary pgm.
You can of course always use the trick of two separate image maps for
HSB/LSB.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 8 Jun 2003 04:03:40
Message: <3ee2eddc$1@news.povray.org>
In article <3ee2e94a$1@news.povray.org> , "Thorsten Froehlich"
Never mind, it is actually support, but the way it is supported is so
obfuscated and far more complicated than it needs to be...
    Thorsten
Date: 8 Jun 2003 09:35:29
Message: <3ee33ba1$1@news.povray.org>
> isosurface,
A highly detailed heightfield uses lot of memory.
My idea was to use a image for the rough structure and add the little
details as functions.
> image.
As already said, that doesn't work, the only place where 16bit seems
to be supported (with the special TGA format and PNG) are heightfields.
see above.
Lutz-Peter
Date: 8 Jun 2003 09:38:20
Message: <3ee33c4c@news.povray.org>
> HSB/LSB.
Is there a software that can split a TIFF or PNG into this kind of
thing?
Lutz-Peter
Date: 8 Jun 2003 10:13:12
Message: <cjameshuff-130585.09043408062003@netplex.aussie.org>
In article <3ee33ba1$1@news.povray.org>,
> > isosurface,
That still doesn't explain why you chose the HDR format. They're for
storing color data with a high dynamic range, a feature that is entirely
useless for height fields.
> > image.
Did you use a grayscale image? When I was poking through that code, I
saw code for loading 16 bit grayscale, but I don't recall seeing 16-bit
RGB. And did you make sure to use bilinear interpolation?
BTW, the TGA format *is* supported, but image maps load it as an
ordinary color TGA, because that's what it is. You need to use .hf to
get a grayscale value computed from the red and green channels:
#declare MyHFImgFn = function {pigment {image_map {tga...}}}
#declare MyHFFn = function {MyHFImgFn(x, y, z).hf}
Date: 8 Jun 2003 10:23:31
Message: <3ee346e3@news.povray.org>
Because I guessed it is just another 16bit format.
I'll try again with grayscale, but IIRC I did already.
Yes, I DID use bilinear interpolation.
> ordinary color TGA,
Thats the same as not supported, isn't it?
Interpolation would scew it up.
Lutz-Peter
Date: 8 Jun 2003 11:10:43
Message: <3ee351f3@news.povray.org>
  But why? I can't understand.
Date: 8 Jun 2003 12:19:12
Message: <cjameshuff-BC6AC2.11103508062003@netplex.aussie.org>
In article <3ee346e3@news.povray.org>,
> > ordinary color TGA,
No. The interpolation is a weighted average, with the weights
independant of the pixel values. Basically the same goes for the
conversion. It's a very inefficient way to do it, requiring
interpolation of three values when only one would do, but it will work.
ar, ag: red and blue of pixel A
br, bg: red and blue of pixel B
w1, w2: weights of the pixels
Method 1: Combining then interpolating:
(ar*255 + ag)*w1 + (br*255 + bg)*w2
Method 2: Interpolating then combining:
(ar*w1 + br*w2)*255 + (ag*w1 + bg*w2)
Which equals:
ar*w1*255 + br*w2*255 + ag*w1 + bg*w2
Rearrange:
ar*w1*255 + ag*w1 + br*w2*255 + bg*w2
Which equals this, the same as method 1:
Date: 8 Jun 2003 16:08:34
Message: <3ee397c2$1@news.povray.org>
You're right, it does work.
I uploaded a table with my tests:
<http://www.lutz-peter.hoogi.de/extern/hfield/>
So a POV-generated TGA (or 2 seperate images) seems to be the only way
to get it working.
However it would be much nicer if POV directly supported 16bit PNG
(or TIFF)...
Lutz-Peter
Date: 8 Jun 2003 17:10:41
Message: <cjameshuff-25A869.16020408062003@netplex.aussie.org>
In article <3ee397c2$1@news.povray.org>,
I notice you didn't use smoothing on the height field...why?
> to get it working.
Since the .hf feature is independant of the file format, you could use
it with other 8-bit color formats as well, you just need a way to
generate them. You could generate a RG-encoded-gray TGA and convert it
to PNG to save space, for example.
> (or TIFF)...
In addition, the whole arrangement of having TGA handled specially in
height fields seems unsatisfactory. For one thing, there are 24 bits
available in most RGB images, but 8 are wasted. Height fields internally
store values as short ints, but there are other uses now such as
isosurfaces, so might as well put that third byte to use.
The hf_gray_16 option generally looks badly designed, it seems really
out of place in global_settings when other file output options are part
of the command line or .ini file. I would have done it as a file output
option useable with any format, and a special toggle to make the height
field load an RG/RGB-encoded-grayscale instead of an ordinary RGB file.
Date: 8 Jun 2003 18:09:13
Message: <3ee3b409@news.povray.org>
In article <cja### [at] netplexaussieorg> ,
>> (or TIFF)...
Yes.  These options simply were created over time, and the really relevant
changes were not made in time.  In 3.5 a lot of this way changes as support
for true 16 bit grayscale and image data was added.  However, the image
reading hasn't been updated to support this yet.  Only function images use
this feature so far.  For PNG this will be in 3.51, but some of the other
formats don't offer such an easy interface to 16 bit image data that could
be used in POV-Ray :-(
    Thorsten
Date: 8 Jun 2003 18:50:44
Message: <3ee3bdc4$1@news.povray.org>
Because like this it is more comparable to the iso-version.
Also, it doesn't help much in making the 8bit version look better.
Lutz-Peter
Date: 8 Jun 2003 19:43:21
Message: <cjameshuff-24DED7.18344408062003@netplex.aussie.org>
In article <3ee3bdc4$1@news.povray.org>,
Actually, it would be more comparable. The isosurface isn't composed of
flat surfaces.
I see.
i wonder how it would work with the height field macros...their
smoothing function is designed for continuous functions, I never really
tested it with interpolated image maps. It wouldn't fix the stepping
problem, but meshes use single-precision floats to store vertices, which
might be useful if the short integer used in the height field isn't
enough.
Date: 8 Jun 2003 21:18:47
Message: <3ee3e077$1@news.povray.org>
> flat surfaces.
It is composed of _nearly_ (they are flat if the 4 adjactant vertices
are coplanar) flat surfaces when bilinear interpolation is used.
Smoother then unsmoothed height_field, but much less smooth than a
smoothed one.
With "interpolate 4" (normalized distance) they aren't flat anymore, but the
surface isn't continuous. For a really smooth surface something like bicubic
interpolation would be needed.
Lutz-Peter
Date: 9 Jun 2003 04:44:17
Message: <3EE44909.EA042497@gmx.de>
Thorsten Froehlich wrote:
> [...]For PNG this will be in 3.51, but some of the other
As i said for ppm/pgm there is a patch in next MegaPOV.
Date: 9 Jun 2003 17:30:47
Message: <3ee4fc87@news.povray.org>
> flat surfaces.
Here are some pictures to compare the different interpolations in
isosurfaces.
<http://www.lutz-peter.hoogi.de/extern/hfield/interp.html>
I implemented bicubic as a function, however there is still some problem
with it, causing some artifacts.
btw, is there a reason bicubic interpolation isn't in POV?
Yesterday I succeeded in compiling (Mega-)POV, I think implementing
bicubic interp. would be a good exercise.
Lutz-Peter
Date: 9 Jun 2003 18:17:10
Message: <cjameshuff-0DC847.17083809062003@netplex.aussie.org>
In article <3ee4fc87@news.povray.org>,
> > flat surfaces.
> isosurfaces.
Normalized distance doesn't work too well for this...interesting result
on the bilinear, I hadn't exactly expected those patches, though it is
obvious now that I think about it. They aren't flat, you can see the
curvature if you have two opposite points "higher" than two others
(where the isosurface shows its diagonals the most strongly), but the
discontinuous normal does make them more comparable to an unsmoothed
isosurface. It is an improvement...I wonder how difficult it would be to
implement a bilinear patch method for the height field primitive...or at
least a better smoothing method. The current one looks far from ideal.
What were the render times like?
It definitely looks the best.
Only that it isn't implemented. Type 3 is actually "cubic spline", it
just isn't implemented. Similarly, the supported mappings are plane,
sphere, cylinder, and torus, but there are declarations in the code for
parabolic, hyperbolic, and piriform.
Date: 9 Jun 2003 21:04:54
Message: <3ee52eb6@news.povray.org>
For 512x384 without AA:
bilinear:               14s
bilinear as function: 1m05s
bicubic as function:  4m10s
So bicubic is about 4 times slower (not unexpected, it uses 16 samples
instead of 4 in bilinear).
Lutz-Peter
Date: 9 Jun 2003 22:31:37
Message: <cjameshuff-0F92F9.21230509062003@netplex.aussie.org>
In article <3ee52eb6@news.povray.org>,
> bilinear:               14s
I was actually wondering about isosurface vs. height field.
An isosurface solver optimized for the constraints of a height field
might be worth it...I've done some experiments with this before in my
little test-bed tracer, I might revive that work. With an image as the
data source, it could do some things to further speed computation.
For example, I'm thinking about a quad-tree structure storing the min
and max heights of areas to allow them to be skipped in the intersection
search. (If a ray enters and exits a partition above or below the range
of the height field, an intersection is not possible.) This optimization
should also be possible for mesh-based height fields, but I suspect
wouldn't be much of an improvement over a more straightforward quad-tree
method.
There are a few other improvements that could be made to the existing
primitive. At least one thing which has already been done by someone
else: switch the orientation of the two-triangle patches depending on
the direction the surface is curving. This way, the diagonals follow the
contours of the curves and the artifacts are much less jarring. Better
smoothing would also be nice, I find it hard to believe the current
smoothing is optimal. And a couple more ideas...I kind of like the
bilinear patch effect of the isosurface, and am going to try to figure
out how to test intersections directly. And there's a point-cloud
raytracing algorithm that I've been looking at which might work nicely
on height field data.
Date: 9 Jun 2003 22:57:35
Message: <3ee5491f$1@news.povray.org>
~1s for heightfield
Would that still work if the surfaces is modified with some other
function?
> Better smoothing would also be nice, I find it hard to believe the current
SlimePOV also has an additional smoothing algorithm.
It does not look much different in this testscene, however, but maybe in
bigger, more complicated heightfields. I havn't tried that yet.
Lutz-Peter
Date: 9 Jun 2003 23:34:07
Message: <cjameshuff-8FE465.22253509062003@netplex.aussie.org>
In article <3ee5491f$1@news.povray.org>,
> function?
Depends on the modification function and the optimizations.
That's the one with the smart triangle orientation, I think.
Date: 10 Jun 2003 01:28:50
Message: <3ee56c92$1@news.povray.org>
> bilinear:               14s
Patched version:
bilinear: 14s (I expected the MingW-Version to be
               significantly slower then the official...)
bicubic:  25s
Seems to be faster (relative to bicubic) than I expected.
Also no artifacts problem in the patched version :-)
Added picture to
Lutz-Peter
Date: 10 Jun 2003 10:08:05
Message: <cjameshuff-EE0CE5.08593510062003@netplex.aussie.org>
In article <3ee56c92$1@news.povray.org>,
> Patched version:
> bicubic:  25s
About twice as fast as I would have guessed...nice.
Well, only very faint artifacts. A huge improvement over smoothed height
fields, but I wonder if those normal discontinuities could be removed...
Are you going to post the code somewhere?
That normalized distance method just doesn't look very effective.
Date: 10 Jun 2003 14:35:05
Message: <3ee624d9@news.povray.org>
I was referring to that black-spots-problem.
There is a faint grid structure visible, but I don't see any
discontinuities. There should't be any, unless there is a bug in my code.
Yes, I will post it later, I just want to clean it up and maybe
optimize it (if possible) before.
btw, what would be the correct group for this?
.programming or .unofficial.patches?
Lutz-Peter
Date: 10 Jun 2003 15:41:56
Message: <cjameshuff-FCCEA0.14332810062003@netplex.aussie.org>
In article <3ee624d9@news.povray.org>,
The discontinuities I mentioned are in the normals, not the surface. The
function is continuous, but not all its derivatives are. That's why you
can see sharp changes in shading. The Perlin noise function used to have
a similar problem, I wanted to see the code to see if a similar fix
could be implemented for interpolation.
The scene code should go in povray.binaries.programming. The other two
groups are for discussion.
Subject: 16bit PNG and TIFF Patch (was: heightfields, 16bit images and isosurfaces)
Date: 27 Jun 2003 21:36:08
Message: <3efcf108@news.povray.org>
I updated my custom POV version to include suppport for 16bit PNGs
and 16bit grayscale TIFFs.
PNG support should be complete, it also fixes the bug with grayscale
images <8bpp beeing almost black, and transparent 8bpp grayscale
PNGs should be more memory-efficient (they where converted to RGB
before).
The TIFF Patch is more limited, it at least allows reading
uncompressed 16bit grayscale TIFFs exported from Picture
Publisher 10, but I can't guaranty for anything more  ;-)
(extracting anything else than 8bit RGBA from LibTiff seems
to be quite complicated...)
Downloads:
<http://www.lutz-peter.hoogi.de/extern/lppov_usr.zip>
Win32 executable (MingW) and sample scenes
<http://www.lutz-peter.hoogi.de/extern/lppov_diff.zip>
Just the changed files needed to apply the patches to megapov 1.0
<http://www.lutz-peter.hoogi.de/extern/lppov_src.zip>
Full source code (minus support libs) including makefiles for
MingW (windows and windows console) and BCC 5.5
Lutz-Peter
