Povray support the true displacement?
My curiosity borned from here:
http://cube.phlatt.net/forums/spiraloid/viewtopic.php?TopicID=9
Cheers,
Manuel
If you explain what you mean with this someone might be able to answer.
Remember POV-Ray is a renderer, not a modeller.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Yes, no and even more :-)
Yes - you can displace vertices and subdivide triangles in meshes if necessary
with smart macros in your favorite way and then it works similiar to the way
triangle based modelers handle it.
No - you can't freely displace primitives due to mathematical formulas used to
tracing them but they are not available in trangle based modelers so it is not
aplicable to comparison.
Even more - you can displace isosurface in easy way with better quality than
triangle based meshes but it takes computation power.
ABX
In article <3ed31707$1@news.povray.org> , "Manuel" <man### [at] tin it>
You apparently misunderstand how POV-Ray works. For a quick answer please
read this manual section, which gives a sufficiently short explanation:
9.1.1.11 How can I bend a object?
<http://www.povray.org/documentation/view/307/>
Thorsten
Thorsten Froehlich
e-mail: mac### [at] povray org
I am a member of the POV-Ray Team.
Have you a sample for "yes" and "even more" cases?
thx,
Manuel
"yes"
Documentation: 7.12.1.1 The HF Macros
"even more"
http://news.povray.org/povray.binaries.images/29800/211748/f_teapot.png
http://news.povray.org/povray.binaries.animations/23891/167475/wip.mpg
and a lot from Tor Olav Kristensen
http://news.povray.org/search/advanced/?s=Kristensen&g=povray.binaries.images&a=1
but that good operating with possibilities of 'yes' and 'even more' cases
require understaing of 'no' answer.
ABX
In article <il96dvkapmn1ngjhhuc2dsol7likpnr3ar@4ax.com> , ABX
BTW, did you ever finish the morphing texture or make the scene source
available?
Thorsten
e-mail: tho### [at] trf de
On Tue, 27 May 2003 12:57:49 +0200, "Thorsten Froehlich" <tho### [at] trf de>
> available?
Current irtc animation topic asks me the same
and I hope I will say 'yes' some day.
ABX
It might be easy to *you*... ;)
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
Indeed, for those interested there is tiny macro in isocsg prepared:
http://www-public.tu-bs.de:8080/~y0013390/pov/ic/docu02.html#Displace
ABX
I've found this:
http://www.geocities.com/ccolefax/pcm.html
impressive!
To answer your question: No. POV-Ray can not displace your objects easily
and on-the-fly. You have 2 options:
(1) Make an isosurface. In many cases you can displace it nicely, and memory
usage is very low. But it's not for imported meshes, so you're lost in case
with the dinosaur. You could transfer the object you want to displace to a
DF3 file, then isosurfaces can handle it, but then the memory usage would go
op. Rendering isosurfaces are also rather slow, compared to solution 2:
(2) Import a mesh that is already displaced. This renders quickly. The only
drawback is the memory usage, that is easily huge.
Hugo
memory
case
go
Thanks!
What's DF3 file??
Oops.
I've try DF3 here!
http://www.povray.org/documentation/view/195/#s06_07_11_11
Sorry for stupid question :-(
Ciao,
Manuel
> I've try DF3 here!
Yes, and you may also want to see the recent post in the images group, from
Tor Olav Kristensen, named "fast preview for complex isosurfaces - 2
attachments".
Hugo
