POV-Ray : Newsgroups : povray.general : PoV-Ray 3.5: Sin() works incorrect Server Time
22 Oct 2026 07:05:00 EDT (-0400)
  PoV-Ray 3.5: Sin() works incorrect (Message 1 to 19 of 19)
Subject: PoV-Ray 3.5: Sin() works incorrect
Date: 24 May 2003 04:54:06
Message: <3ecf332e@news.povray.org>
Hi.
This is my first Message to news.povray, so be nice ;). I use Pov-Ray for
Windows 98 3.5 and try to make my first animations. My Plan is to rotate the
cap point of a cylinder around the z-axis, while the base point is <0, 0, 0>
Because I want to know the new coordinates of the cap point, i can't simply
use the rotate-command, right?
However, I have to work with the sin()-Function. But my PoV-Ray caculates
the most stupid coordinates I ever seen when I use it. I checked my formulas
100 times, and so I'm shure that it is correct.
Now to my question(s):
How can i rotate a cylinder manually without the sin()-command?
And (because the answer of the first question will be: its impossible) can I
detect the new coordinates of the cap point when I use the rotate-command?
Subject: Re: PoV-Ray 3.5: Sin() works incorrect
Date: 24 May 2003 05:07:28
Message: <3ecf3650@news.povray.org>
I have the strong feeling that you are working with angles in degree while
POV-Ray wants them in radians for the sin() function!
- Micha
POV-Ray Objects Collection: http://objects.povworld.org
Date: 24 May 2003 05:12:48
Message: <Xns93857295E1104seed7@povray.org>
in news:3ecf332e@news.povray.org The Brain wrote:
> can I
> rotate-command?
have a look at the vector function vrotate(A,B) in "6.1.4.6  Vector
Functions"
Ingo
Date: 24 May 2003 05:15:30
Message: <3ecf3832@news.povray.org>
Oops, right ^^
Thanks
Date: 24 May 2003 05:42:44
Message: <3ecf3e94@news.povray.org>
aah, this is is exactly that what I need. Thx.
Subject: What if...
Date: 24 May 2003 06:11:20
Message: <3ecf4548@news.povray.org>
And what if I use the Rotate_Around_Trans macro instead of the simple
rotate?
Subject: Re: What if...
Date: 24 May 2003 06:41:17
Message: <Xns9385819674110seed7@povray.org>
> rotate?
Brain,
If you take a look at the actual macro, you'll see that it is just a
'simple' rotate plus two translations.
Actually, I'm starting to wonder what it is you want to acheive? In
youre first post you want to rotate a cylinder, with one cap in the
origin, around the z-axis:
cylinder {
  <0,0,0>, <cap_somewhere>, 1
  rotate <0,0,clock*360>
Then you want to know the position of the other cap after rotation:
#declare CapPosition = vrotate(<cap_somewhere>,<0,0,clock*360>)
Now you want to use Rotate_Around_Trans, so ...?
Ingo
Date: 24 May 2003 06:46:39
Message: <3ecf4d8f@news.povray.org>
Thx. As from now I wont ask stupid questions.
I want to make several clinders, linked with spheres.
Date: 24 May 2003 06:55:08
Message: <Xns938583EFA4929seed7@povray.org>
There are no stupid questions. It's just sometimes difficult to
interpret what's going on in someone others brain through a line in a
message.
You could put a sphere and a cylinder in a union, that way you don't
have to use vrotate.
union {
  cylinder {
    <0,0,0>, <other_cap>,1
  sphere {
    <somewhere_and_related_to_other_cap>,1
  rotate <0,0,360*clock>
Ingo
Date: 24 May 2003 07:03:38
Message: <3ecf518a$1@news.povray.org>
"The Brain" <rag### [at] univalde> wrote in message
news:3ecf4d8f@news.povray.org...
> I want to make several cylinders, linked with spheres.
Gee, try not to get paranoid or anything  ;-)  ingo was just wondering, I'm
sure.
But anyway, stupid questions belong in the povray.newusers group. Only
joking! Second time within a matter of minutes. Seriously though, it seems
you might have actually overlooked that group so thought I'd point it out.
And if you believe the question merits asking in povray.general instead
anyway, at least you didn't post it to povray.advanced. :-)
Bob H.
Date: 24 May 2003 11:45:44
Message: <3ecf93a8$1@news.povray.org>
> message.
I know. It was only a joke. I know that my questions are intelligent :))
(sometimes to intelligent ;))
Would be possible, but remember that I want to start a new cylinder in the
rotated point. So I need it anyway.
Date: 24 May 2003 11:46:12
Message: <cjameshuff-6A1C7D.10471824052003@netplex.aussie.org>
In article <3ecf4548@news.povray.org>, "The Brain" <rag### [at] univalde>
> rotate?
From the other messages in this thread, it looks like you've figured out
how to do what you need using CSG, but if you ever need to do stuff like
this you can use the vtransform() macro in transforms.inc.
http://tag.povray.org/
Date: 24 May 2003 17:29:48
Message: <3ECFE44B.3040903@hotpop.com>
When doing a 2D rotation:
   X = Radius*cos(radAngle)
   Y = Radius*sin(radAngle)
Where Radius is the distance from origin you want and radAngle the angle
of rotation in radians.
HTH,
   Xilo
Dedicated to audio/visual and interactive artwork.
http://www.geocities.com/simonlemieux/
Date: 25 May 2003 06:04:47
Message: <3ED0956A.9020000@informatik.uni-freiburg.de>
That sounds to me like sphere_sweep with linear_spline.
In any case it suffices to ONLY know the points.
merge{#local i=-11;#while(i<11)#local
i=i+.1;sphere{<i*(i*i*(.05-i*i*(4e-7*i*i+3e-4))-3)10*sin(i)30>.5}#end
pigment{rgbt 1}interior{media{emission x}}hollow}//  Mark Weyer
Date: 25 May 2003 06:48:27
Message: <3ed09f7b@news.povray.org>
lol, i'm a newbe. Don't make my head explode with that expert-formulars
Date: 25 May 2003 12:59:42
Message: <3ed0f67e@news.povray.org>
expert-formulars
S-U-P-E-R-E-L-L-I-P-S-O-I-D
It seems like you know a lot already, and be sure to look into splines
sometime, they're very handy.
-Peter
PS: I know superellipsoid is not an expert-only thing, but it sounds
hard if you haven't heard of it.
Date: 25 May 2003 17:12:52
Message: <3ed131d4$1@news.povray.org>
Mark Weyer <wey### [at] informatikuni-freiburgde> wrote in message
news:3ED### [at] informatikuni-freiburgde...
Actually, Mark's suggestion sounds like exactly what you describe... and not
an expert subject at all. Sphere_sweeps are quite simple, they're actually
the first object I learned in POV (And I'm definitely NOT an expert!)  As he
said, you only need the points. No rotations, no math.
Check the docs, section 6.5.1.10  Spheresweep
RG
Date: 26 May 2003 14:21:54
Message: <3ed25b42$1@news.povray.org>
^^ I mean all the i's and the *'s and the ('s and the )'s, and the
combination of all :))
Date: 26 May 2003 17:29:26
Message: <3ed28736@news.povray.org>
Oh, (assuming you don't know) that's a signature. Copy it to a new file
in POV-Ray and render it. There are a lot of cool ones around!
-Peter
