POV-Ray : Newsgroups : povray.general : Plant Studio question Server Time
23 Oct 2026 10:12:22 EDT (-0400)
  Plant Studio question (Message 1 to 11 of 11)
Subject: Plant Studio question
Date: 5 May 2003 14:33:20
Message: <3eb6ae70@news.povray.org>
Hi there,
I've recently started using PlantStudio (which is now free, btw), but
I've run into a problem.  While it's a brilliant piece of software it
seems to be missing the option of exporting smooth meshes, resulting in
nasty jagged edges all over the leaves.  I see two ways out of this -
take the time and energy to create leaves with a large number of
triangles and then import them into PlantStudio (it has a simple 3D
format), or find a utility to subdivide the output from PS.  Has anyone
else had similar troubles and found a way round them?  Does anyone know
of a utility suitable for this?
If no-one has found a better way I expect I'll try and find a way of
using JVS's surface subdivision suite to smooth the leaves out.
Andrew
Subject: Re: Plant Studio question
Date: 6 May 2003 12:31:48
Message: <cjameshuff-EEB512.12314806052003@netplex.aussie.org>
In article <3eb6ae70@news.povray.org>,
 "Andrew" <ast### [at] hotmailcom> wrote:
> While it's a brilliant piece of software it seems to be missing the
> option of exporting smooth meshes, resulting in nasty jagged edges
Smooth triangles only affect the shading, they will not help with the
jagged edges. For that, you need to actually subdivide the geometry into
more triangles.
http://tag.povray.org/
Date: 6 May 2003 12:59:29
Message: <3eb7e9f1$1@news.povray.org>
into
> more triangles.
True enough.
I guess subdivision is by far the better option, especially as I could
import a subdivided mesh into PlantStudio.  Smooth_triangles would be
nice too, but the problem is that they have to be generated after the
program has produced its output.
Date: 6 May 2003 13:36:46
Message: <3EB7F2AF.CED1ADD2@mail.com>
As far as I remember there was a bug in smooth_triangle
(it didn't work properly on object edges).
Therefore I refrained from using it in POV-Tree.
Was it fixed?
Gena.
Andrew wrote:
> Hi there,
> Andrew
Date: 6 May 2003 14:06:08
Message: <nrtfbvonf0cj3ucqvhads0ihe4kmur9sk3@4ax.com>
Smooth triangles are refered in following reports:
http://news.povray.org/povray.bugreports/7423/
http://news.povray.org/povray.bugreports/7693/
http://news.povray.org/povray.bugreports/7725/
and all are connected with 3.1 version. Current official is 3.5. I do not
remember similiar report for 3.5. Can you describe more which bug you mean ?
ABX
Date: 6 May 2003 14:32:51
Message: <3EB7FFD4.A4A2B95B@mail.com>
See the thread in povray.binaries.images with subject: 'Smoothed mesh bug'
Gena.
> ABX
Date: 6 May 2003 15:15:59
Message: <3eb809ef$1@news.povray.org>
That is not a bug.  Use double_illuminate as explained in that thread.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 6 May 2003 15:42:35
Message: <3eb8102b@news.povray.org>
With a tree generator and leafs this might not be an option.
Date: 6 May 2003 15:51:29
Message: <3eb81241$1@news.povray.org>
In article <3eb8102b@news.povray.org> , Simon Adameit
If you abuse meshes, don't expect them to react friendly.  They are
"meshes", not "collections of individual, unconnected triangles".
    Thorsten
e-mail: tho### [at] trfde
Date: 6 May 2003 17:25:25
Message: <3EB82846.39CC99CD@mail.com>
Here is the description of the problem:
http://www.povray.org/documentation/view/358/
As a matter of fact I didn't know about that problem and implemented
export of smooth_triangle mesh in POV-Tree and faced the problem.
First, I also thought that my algorithm is wrong and that I "abuse" mesh
I checked the code and it was correct then I found that post. So I
decided to stay away from smooth_triangles because double illuminate
doesn't work for trees in most cases (also it doubles filesize :)
Hopefully
POV-Ray 4.0 will resolve the problem.
Gena.
Date: 7 May 2003 02:49:51
Message: <miahbvsrb9ntv0b7t7on5jqg1p3jgs0l9l@4ax.com>
Known behaviour of algorithm is not a bug. Do not create urban legends ;-)
ABX
