POV-Ray : Newsgroups : povray.general : Direction dependent glass? Server Time
2 Nov 2026 10:36:24 EST (-0500)
  Direction dependent glass? (Message 1 to 14 of 14)
Subject: Direction dependent glass?
Date: 18 Apr 2003 10:35:43
Message: <3ea00d3f@news.povray.org>
Anyone know how to get the effect of that dark glass that's often used in
large buildings? You know the stuff... practically opaque from the outside,
almost as clear as normal glass on the inside?
Subject: Re: Direction dependent glass?
Date: 18 Apr 2003 10:41:38
Message: <di30avsdhmc0ajt2t6t4o69lsjl4q7bqt0@4ax.com>
http://www.povray.org/documentation/view/193/
ABX
Date: 18 Apr 2003 19:25:22
Message: <3EA08A77.5C623C47@Rapidnet.com>
Theoretically.
difference {
    box { <-1.5, -3.0, -0.125> <1.5, 3.0, 0.75> }
    box { <-1.5625, -3.0625, -0.15625> <1.5625, 3.0625, 0.0> texture { NBglass
        texture { NBglass pigment { color rgbf <0.75, 0.75, 0.75, 0.015625> }
Theoretically, this should render the type of semi-silvered glass used in
observation and interogation rooms.
Anthony D. Baye
Date: 19 Apr 2003 03:10:30
Message: <3ea0f666$1@news.povray.org>
> ABX
Normally glass is modeled with thickness and not just as one surface so
slope or object pattern might be better.
Date: 19 Apr 2003 13:26:38
Message: <cjameshuff-0AA0C1.13254619042003@netplex.aussie.org>
In article <3ea0f666$1@news.povray.org>,
Neither of those will be of any help in making one-way glass. If you
make a box with one side dark and the other side light, you will either
see the dark side directly or through the light side. I'm not sure how
you plan to use the slope pattern...I think it is idependant of the side
of the surface it is evaluated at.
Anyway, in a one-way glass window, you are unlikely to be able to tell
the difference between thick glass and single-surface glass. With smart
lighting and reflection values, you should be able to get an acceptable
effect, otherwise using interior_texture or actually changing the
texture depending on the camera location is probably the best way to go.
http://tag.povray.org/
Date: 19 Apr 2003 14:17:21
Message: <3ea192b1$1@news.povray.org>
Conserve_energy could be helpfull here don't you think?
the part of light which is reflected is not transmitted.
Inside building is darker than outside so less light comes from inside.
Isn't it how it works?
Marc
"Christopher James Huff" <cja### [at] earthlinknet> a écrit dans le message
de news: cja### [at] netplexaussieorg...
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Date: 19 Apr 2003 16:32:17
Message: <3ea1b251@news.povray.org>
Ah, I didn't think of that. But one could use the slope or object
pattern in the interior texture.
In a one-way glass window you wouldn't need the effect.
Date: 23 Apr 2003 20:21:41
Message: <cjameshuff-CC8B6D.20214123042003@netplex.aussie.org>
In article <3ea1b251@news.povray.org>,
Wha...? Why not just use the interior texture? And what possible use
would the object pattern have?
The effect is a way to achieve one-way glass! The idea is that you use
interior_texture to get one-way glass, not that you use one-way glass to
avoid using interior_texture.
Date: 23 Apr 2003 20:26:53
Message: <cjameshuff-4B56BF.20265223042003@netplex.aussie.org>
In article <3ea192b1$1@news.povray.org>,
I don't think it would be much help in this particular case, but it's
worth checking out. The idea's that the window is partially reflective,
has a dark room on one side and a light room on the other. From the dark
side, the transmitted light washes out the reflected light. From the
light side, it is the other way around.
Date: 24 Apr 2003 09:12:18
Message: <3ea7e2b2@news.povray.org>
> > Wha...?
A one-way glass window does only make sense if you will be able to see
it from both sides and if you see it from both sides you will be able to
tell the difference between a thick glass and a single-surface glass
thus you need a way to archieve one-way thick glass which with interior
texture alone wont work, the interior texture needs to be transparent
but the outside texture only needs to be transparent on one side which
you can archieve with the object or slope pattern.
Date: 24 Apr 2003 10:11:40
Message: <cjameshuff-18E917.10112824042003@netplex.aussie.org>
In article <3ea7e2b2@news.povray.org>,
> it from both sides
Right. Otherwise you could just change the texture.
Say, from a mirror in the room on the "subject" room, with the camera in
the "observer" room.
> you will be able to tell the difference between a thick glass and a
Uh...why? You would still need a close look at it.
Well, as I've been saying, you can probably get a reasonable one-way
effect by good lighting. But I don't see how the slope pattern can help
here. Are you using the object pattern to only silver one side of the
glass? That's a little overkill in flexibility, and gradient would
probably be as fast, but it would work.
Date: 24 Apr 2003 11:50:18
Message: <3ea807ba@news.povray.org>
It's not about being able to see both surfaces but about the rays not
ending up parallel. You could use a lower ior to compensate for this but
this will make fresnel reflection look all wrong.
lightning?
The same way object or gradient(if the window is flat) pattern can help.
Date: 24 Apr 2003 14:15:03
Message: <cjameshuff-638BC7.14145924042003@netplex.aussie.org>
In article <3ea807ba@news.povray.org>,
> ending up parallel.
Parallel? Rays that start out parallel will stay parallel.
Ah, you are thinking of using ior. With a single-surface window, you
would obviously not use an ior.
Why are you using fresnel reflection?
> lightning?
No, lighting.
I now see how you were applying the object pattern, but not the slope
pattern. What are you using it for?
Date: 24 Apr 2003 14:27:21
Message: <3ea82c89@news.povray.org>
>>ending up parallel.
When you use ior the ray that enters the glass should be parallel to the
one leaving the glass (in case of a flat window) which is not the case
with a single surface. I think I'm so used to using ior and fresnel
reflection with glass that I didn't even think of not doing so and
simply using a single-surface as the refraction probably wont be visible
anyways.
>>lightning?
> No, lighting
I know that you ment lighting and also wanted to say that but I dont
know what you ment? (Does that make sense?)
For the same purpose. Make one side of the glass (the outside texture on
one side) non transparent, highly reflective, or whatever...
