POV-Ray : Newsgroups : povray.general : Are cheap fonts likely to not work in povray? Server Time
18 Aug 2025 13:52:17 EDT (-0400)
  Are cheap fonts likely to not work in povray? (Message 1 to 5 of 5)
Subject: Are cheap fonts likely to not work in povray?
Date: 23 Mar 2003 16:38:44
Message: <3e7e2964$1@news.povray.org>
I downloaded a cheap font,  CLOWNS.TTF, and tried to use one of the
characters as a text object that was then used in an object pattern.  No
matter what letter I used in the command, I ended up with the same
character.  The font seemed to work okay in Wordpad.   Are cheap fonts just
prone to be misread by povray?
sample code below.
#declare blacktext=texture{pigment {Yellow} finish{phong 0.4 }}
#declare Mobj=  text {ttf "CLOWNS.ttf" "a" 1, 0  scale 0.75*<-1,1,3>  scale
10 translate <-2.5,6.2,0>  }
#declare clothtext1=
texture{object{Mobj
        texture{clothtext}
        texture{blacktext}}
Subject: Re: Are cheap fonts likely to not work in povray?
Date: 23 Mar 2003 21:51:26
Message: <3e7e72ae$1@news.povray.org>
It depends,
from what I see is this:
1. No camera Definition
2. No Lightsource
3. clothtext texture not defined.
"Greg M. Johnson" <gregj;-)565### [at] aolcom> wrote in message
news:3e7e2964$1@news.povray.org...
just
> sample code below.
scale
> texture{object{Mobj
>         texture{clothtext}
>         texture{blacktext}}
Date: 23 Mar 2003 23:20:42
Message: <3e7e879a$1@news.povray.org>
Sorry, see:
http://news.povray.org/povray.binaries.images/30955/
I didn't want to include all of the files. My system is getting a bit
complicated.
The guy on the left has the letter "a" as a text object  object pattern.  No
matter what letter I type in there, it always shows the same character from
the font file.  I think however that the font file works okay in Wordpad.
"Wheredragon" <whr### [at] nothnbutnet> wrote in message
news:3e7e72ae$1@news.povray.org...
> It depends,
> 2. No Lightsource
> just
> > sample code below.
> scale
> > texture{object{Mobj
> >         texture{clothtext}
> >         texture{blacktext}}
Date: 24 Mar 2003 14:14:35
Message: <3e7f591b$1@news.povray.org>
Greg M. Johnson <gregj;-)565### [at] aolcom> wrote in message
news:3e7e879a$1@news.povray.org...
> complicated.
No
from
Are you somehow redfineing something later on that causes "a" to be used?
Have you tried using a different font within this same exact povray code and
does it work then? Have you saved the file after changing "a" to whatever
you want?
Date: 24 Mar 2003 22:56:40
Message: <3e7fd378$1@news.povray.org>
Okay,  get the CLOWNS.TTF font at:
http://desktoppub.about.com/library/fonts/db/uc_clownsketches.htm
and then compare how timrom.ttf works vs. CLOWNS.TTF with *this* code:
#declare shirtpig=pigment{rgb 0.4*<   0.3, 0.6,0.6>}
#declare clothtext=texture{pigment{shirtpig} normal {bumps scale
0.1}finish{ambient 1}}
#declare logopig=pigment{rgb <0.7,.9,0.9>}
#declare blacktext=texture{pigment {logopig} finish{phong 0.4 ambient 1 }}
#declare Mobj=  text {ttf "CLOWNS.ttf" "D" 1, 0  scale 0.75*<-1,1,3>
translate 0*<-0.25,0,-0.25> scale 10   }
//#declare Mobj=  text {ttf "timrom.ttf" "e" 1, 0  scale 0.75*<-1,1,3>
texture{object{Mobj
        texture{clothtext}
        texture{blacktext}}
sphere {0,10 texture{clothtext1 } }
camera {location -10*z }
