Hi all,
I've been playing with POV and I've made a simple sig, here it is:
camera{orthographic location 4-8*z direction 3 look_at 0}light_source{4-8*x,
2}light_source{20+30*x,1}union{box{-.1,z+.1}box{-.1,x+.1}box{z-y-.1,z+.1}box
{x-.1,x+y+.1 clipped_by{plane{1-2*x,-.3}}}pigment{rgb<.8,.2,1>}}
It's off-center and the camera statement is too long, but careful
positioning of the camera and light sources is needed... Well, what do you
think about it? Any ideas to shorten it and "hide" it? :)
Ignacio __ Fernández Galván
Linux user / / \
#289967 / / /\ \ PGP Pub Key
/ / /\ \ \ 0x01A95F99
/ /_/__\ \ \
/________\ \ \
\___________\/
Jellby <jel### [at] m-yahoo com> wrote:
> direction 3
"angle 15" seems to work equally well.
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
how about this
camera{orthographic location 4-8*z look_at
0}light_source{4-8*x,2}light_source
{20+30*x,1}union{box{-x-z-.4,-x+3*z+.4}box{-x-z-.4,3*x-z+.4}box{-x+3*z-4*y-.
4,
-x+3*z+.4}box{3*x-z-.4,3*x-z+4*y+.4
clipped_by{plane{-x-z+4-8*x,-1.2}}}pigment{rgb<.8,.2,1>}}
it didn't actually shorten it, but it's centered
Kruger
Shorten:
camera{orthographic location 4angle 15look_at 0}union{light_source{9*<5,4
2>1}box{x-1.1.1-z}box{-z-.1.1}box{-.1x+.1}light_source{4*y
1}box{x-.1x+y+.1clipped_by{plane{2*y-1,-.3}}}pigment{rgb<.8.2,1>}}
Obfuscate (slightly):
camera#macro A(B,C)box{B-.1B+C+.1#end{orthographic location 4angle 15look_at
0}light_source{4*y,1}light_source{9*<5,4,2>1}union{A(x-1y)}A(-z,z)}A(0x)}A(x
y)clipped_by{plane{2*y-1,-.3}}}pigment{rgb<.8.2,1>}}
Actually that was no lossless compression.
merge{#local i=-11;#while(i<11)#local
i=i+.1;sphere{<i*(i*i*(.05-i*i*(4e-7*i*i+3e-4))-3)10*sin(i)30>.5}#end
pigment{rgbt 1}interior{media{emission x}}hollow}// Mark Weyer
Thanks, Warp and Kruger
I've moved the camera and look_at to center the view, and the lights to make
them shorter (but the effect is not spoiled, at least in my display), and
changed the order. Now it's centered, shorter, has linebreaks where spaces
are needed and fits very nicely in 74 colums ;)
light_source{y,1}light_source{9+7*x,1}camera{orthographic location 9/4-4*z
angle 30 look_at (1-y)/4}union{box{z-y-.1,z+.1}box{-.1,z+.1}box{x-.1,1.1-z
clipped_by{plane{4+y-8*x,0}}}box{-.1,x+.1}pigment{rgb<.8,.2,1>}}/*Jellby*/
71, this time lossless in the picture, though not in the scene:
union{box{-.1.1+x}box{z-y-.1.1+z}box{x-.1.1-z+1clipped_by{plane{4+y-8*x
0}}}box{.1z-.1}pigment{rgb<.8.2,1>}}light_source{9+7*x,1}light_source{y
1}camera{orthographic location 9/4-z*4angle 30look_at(1-y)/4}/*Jellby*/
Entre otras cosas, Mark Weyer tuvo a bien escribir:
>> make them shorter (but the effect is not spoiled, at least in my
>> display), and changed the order. Now it's centered, shorter, has
>> linebreaks where spaces are needed and fits very nicely in 74 colums ;)
Great! Thank you very much, I've been fidling with the macro version too, I
had tried that but didn't manage to get it shorter... Well, I hope you
don't mind if I take your code and alter the order in a couple of places,
hehe. :)
0}}}box{.1z-.1}pigment{rgb<.8.2,1>}}light_source{y,1}light_source{9+7*x
1}camera{orthographic location-z*4+9/4look_at(1-y)/4angle 30}/*Jellby*/
> Well, I hope you
As long as you show me the result ;-)
> hehe. :)
While my version is not short enough to be a sig, I had fun making it as:
#macro S(I,G)#macro a(_ J E L B Y)_,y-J,z-E,L-x,B-y,Y#end,max(x-a(max(I.x
,G.x)max(I.y,G.y)max(I.z,G.z)min(I.x,G.x)min(I.y,G.y)min(I.z,G.z))-z)#end
light_source{y 1}light_source{9+7*x 1}isosurface{function{min(max(y*5+z*4
-x*4S(x-.1.1-z+1))S(-.1+t.1+x)S(z-y-.1.1+z)S(z-.1.1+t))}contained_by{box{
-2 2}}pigment{rgb<.8.2>+z}}camera{orthographic location-z*4+9/4look_at(1-
y)/4angle 30}
ABX
> > Well, I hope you
It was the sig in the previous post, anyway, here it is the new one, with 71
columns again, but with a better lighting.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
> y)/4angle 30}
Woot! That's insane! :) Thanks it's a nice version.
This is a new - but similar - one, I'd like it to be just 3 lines, is it
possible? :)
light_source#macro Z(Y)difference{X(.2)X(x)X(y)X(z)plane{-Y*y,0}rotate
Y*(3*y+z)pigment{rgb<1,.8.2>}no_shadow}#end{99*(1-y)1}light_source{9*x
1#macro X(T)box{-T-z/4-1T+z/4+1}#end}camera{orthographic look_at 0angle
30location x*10}Z(15)Z(-15)
> possible? :)
light_source{99#macro Z(Y)difference#macro X(T)box{-T-z/4-1T+z/4+1}#end{X(.2
)X(x)X(y)X(z)plane{-Y*y.0}rotate Y*(3*y+z)pigment{rgb<on.8.2>}no_shadow}#end
*(1-y)1}light_source{x*9on}camera{angle.3location x*1e3look_at 0}Z(15)Z(-15)
ABX
Thank you very much, I've modified it slightly to:
camera#macro Z(Y)difference#macro X(T)box{-T-z/4-1T+z/4+1}#end{X(.2)X(x)X(y)
X(z)plane{-Y*y.0}rotate(y+z/3)*Y*9pigment{rgb<on.8.2>}no_shadow}#end{look_at
0location+x*1e3angle.3}Z(-5)light_source{x*9on}Z(5)light_source{99*(1-y)1}
It's just a shuffle and a slight macro change.
