POV-Ray : Newsgroups : povray.general : Bezier-Splines Updated! Server Time
18 Aug 2025 17:23:36 EDT (-0400)
  Bezier-Splines Updated! (Message 1 to 5 of 5)
Subject: Bezier-Splines Updated!
Date: 17 Feb 2003 16:50:41
Message: <3e515931@news.povray.org>
I'm not sure if anyone actually uses these macros
of mine, but I've updated my Bezier-Splines macros,
which (from my point of view) provide a very intuitive
approach on spline-modelling.
The update introduces 2. Order continuancy, meaning
that tangential forces may vary for different sections of
a spline.
What does that mean?
Actually, one section is built with 4 vectors: 2 nodes defining
beginning and end point, and 2 directions defining tangents
for each point.
The Macros would take always a pair of 4 vectors and calculate
a section off of that. So, adding another 2 (1 node + 1 direction)
to the already existing four, the macro would create a section
curving from the end-point of the last section with its tangent to
the new one.
But the tangential force (its length) defines a very essential part
of the curving, and when using a strong force for one section,
it would have impact on the next.
So just yesterday I read a paragraph about the Bezier-Splines,
and stumbled upon this 2. Order continuancy. Basically, it states
that the splines' sections will still join smoothly if the tangent
stays the same, even though its force changes. That what I
implemented with the 4th component of the vectors.
Well, enough rambling. If anyones interested, its uploaded on
my homepage, if not, well... Don't know. Go play! :-)
Tim
Tim Nikias
Email: Tim### [at] gmxde
Subject: Re: Bezier-Splines Updated!
Date: 17 Feb 2003 21:09:50
Message: <3e5195ee$1@news.povray.org>
Hi. Could you post an example scene that used your spline macro to translate
the position of the camera?
thanks much,
Dennis
"Tim Nikias" <tim### [at] gmxde> wrote in message
news:3e515931@news.povray.org...
> a spline.
> for each point.
> the new one.
> Regards,
> Tim
> Tim Nikias
> Homepage: http://www.digitaltwilight.de/no_lights/index.html
Date: 18 Feb 2003 07:04:28
Message: <3e52214c@news.povray.org>
Little scene uploaded, its in the ZIP-File.
Tim
Tim Nikias
> thanks much,
> Dennis
Date: 18 Feb 2003 11:16:02
Message: <3e525c42$1@news.povray.org>
Ya, I did see that, but it doesn't apply the spline to camera movement so I
wonder which declaration I would use, for example, in a camera translate
statement, or is that the right approach?
best,
d.
news:3e52214c@news.povray.org...
> Regards,
> Tim
> Tim Nikias
translate
> > thanks much,
> > Dennis
Date: 18 Feb 2003 19:28:01
Message: <3e52cf91@news.povray.org>
No, I meant, I've added a new little scene in there, cam_spl.pov,
along with the old bspline_ex.pov.
What you actually do is access the spline using
BSpline_Pos( Spline, Mover)
with Spline being the identifier of the spline-array,
and Mover being a value ranging from 0 to 1 (beginning
to end of spline).
BSpline_Pos returns a simple <x,y,z>-vector, so you may
use it like this:
camera{
 location BSpline_Pos(My_Spline, clock)
 look_at <0,0,0>
(Just an example)
Tim
Tim Nikias
"Dennis Miller" <dhm### [at] attbicom> schrieb im Newsbeitrag
news:3e525c42$1@news.povray.org...
> best,
> d.
> > Regards,
> > Tim
> > Tim Nikias
> translate
> > > thanks much,
> > > Dennis
