POV-Ray : Newsgroups : povray.general : rand question Server Time
2 Nov 2026 14:33:03 EST (-0500)
  rand question (Message 1 to 37 of 37)
Subject: rand question
Date: 11 Feb 2003 12:03:29
Message: <3e492ce1@news.povray.org>
How many numbers are in the rand stream before it repeats itself, or is this a
meaningless question?
#macro A(V,B,C,R)#while(B-256)#if(V-128/B>=0)sphere{0,.5translate<C-4R-1,9>
pigment{rgb<1-C/8R/2C/8>}}#local V=V-128/B;#end#local B=B*2;#local C=C+1;#
end#end A(234,1,0,2)A(85,1,0,1)A(81,1,0,0)light_source{-5 1}//Tom Melly
Subject: Re: rand question
Date: 11 Feb 2003 12:22:57
Message: <3e493171$1@news.povray.org>
Repitition is inherent in randomness.
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3e492ce1@news.povray.org...
this a
> #macro
Date: 11 Feb 2003 12:28:32
Message: <3e4932c0$1@news.povray.org>
"Harold" <bai### [at] 3dculturecom> wrote in message
news:3e493171$1@news.povray.org...
but isn't it a pseudo random string? - i.e. the repitition is predictable.
Date: 11 Feb 2003 13:16:45
Message: <3e493e0c@news.povray.org>
  Test it?
Date: 11 Feb 2003 13:48:31
Message: <3e49457f$1@news.povray.org>
news:3e493e0c@news.povray.org...
>   Test it?
I sort of am (I'm trying to get a specific sequence of numbers from a random
stream - don't ask).
Date: 11 Feb 2003 14:03:24
Message: <3e4948fc$1@news.povray.org>
random
Wh.........
*realises he's just been told not to ask*
John
Run Fast
Run Free
Run Linux
Date: 11 Feb 2003 14:20:42
Message: <3E494D23.7C164DC@hotmail.com>
> is this a meaningless question?
#declare rsA=seed(0);
#declare rsB=seed(0);
#local sA=0;#local sB=-1;
#local cR=0;
#while(sA!=sB)
#local sA=rand(rsA);
#local sB=rand(rsB);
#local cR=cR+1;
#debug concat("Seed repeats after ",str(cR,0,0)," repetitions.\n"
Date: 11 Feb 2003 14:25:54
Message: <3e494e42$1@news.povray.org>
this a
I assume we're talking about pseudo random numbers generators here, right?
The number you are talking about is known as the period of a generator and
is one of its most important properties... The two best generators that I
know are RANDMAR (with period 2^144; I use this one in my projects), and
R250 (with period 10^250, i.e. 1e251).
BTW, the "before it repeats itself" actually applies to the sub-sequences,
and not to individual numbers... RNGs' internals make it possible for many
different numbers to follow any given number. For instance, the following
sequence is easily possible with many RNGs:
1 2 3 4 2 9
Notice that 2 is first followed by 3, and then by 9. But if the period of
this generator is 6 :-), then 9 will be followed by 1 -- it is here that the
actual repetition takes place.
Oh well, I just figured out that that's p.g, so you probably meant POV-Ray
streams. Sorry for an off-topic post. Follow-ups to p.programming.
Date: 11 Feb 2003 16:17:14
Message: <3e49685a$1@news.povray.org>
"John VanSickle" <evi### [at] hotmailcom> wrote in message
news:3E4### [at] hotmailcom...
I'll take your word for it ;) Many thanks...
Date: 11 Feb 2003 17:52:44
Message: <3e497ebc@news.povray.org>
John VanSickle <evi### [at] hotmailcom> wrote:
> #while(sA!=sB)
  Are you completely sure that the same number will not appear twice
in the stream without looping back to the beginning?
  Naturally this might be so, but if the random number generator is made
even with the slightest quality, the same number can repeat many times
in the stream before it loops over.
Date: 12 Feb 2003 05:04:43
Message: <3e4a1c3b@news.povray.org>
"Mark Wagner" <mar### [at] gtenet> wrote in message
news:pan### [at] gtenet...
> On Tue, 11 Feb 2003 12:03:28 -0500, Tom Melly quoth:
> 4.29 billion (2^32, to be exact).
Many thanks (so I shouldn't have given up at 500000 then? ;)
Date: 12 Feb 2003 05:06:09
Message: <3e4a1c91@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3e497ebc@news.povray.org...
> > #while(sA!=sB)
Once I'd worked out what the code did, the same thought occured - is there
something in the way the stream is generated that makes that impossible? For
example, that a particular number is always followed by another fixed number?
Date: 12 Feb 2003 09:59:22
Message: <3e4a614a@news.povray.org>
  This depends a lot on how the random number generator is implemented.
There are (good) random number generators where the period is a lot larger
than the value range (eg. you get numbers between 0 and 2^64-1 from it, but
it gives you for example 2^256 numbers before starting over, which of course
means that the same number appears in the stream several times).
  As I don't have any idea what kind of algorithm pov's generator uses,
I can't say how it works there. Very simple generators start repeating
over immediately when the same number which has appeared before appears
again.
Date: 12 Feb 2003 10:00:01
Message: <3e4a6171@news.povray.org>
  Do you have any concrete proof or demonstration of this?
Date: 12 Feb 2003 10:06:09
Message: <3e4a62e1@news.povray.org>
>> there something in the way the stream is generated that makes that
>> impossible? For example, that a particular number is always followed by
<snip>
> again.
I found following in POV's express.cpp
static DBL stream_rand(int stream)
  next_rand[stream] = next_rand[stream] * 1812433253L + 12345L;
  return((DBL)(next_rand[stream] & 0xFFFFFFFFUL) / 0xFFFFFFFFUL);
An iterated random generator like this obiously cannot have a longer period
than 2^sizeof(int).
- Micha
POV-Ray Objects Collection: http://objects.povworld.org
Date: 12 Feb 2003 10:08:44
Message: <3E4A665E.6070700@informatik.uni-freiburg.de>
There is such proof. From the source (texture.cpp, don't know why there):
   static unsigned long int next_rand = 1;
   int POV_RAND()
     next_rand = next_rand * 1812433253L + 12345L;
     return((int)(next_rand >> 16) & RNDMASK);
I turned this into a program for testing the period as follows:
   #include <iostream.h>
   void main() {
     static unsigned long int count = 0;
     do {
       count++;
     } while (next_rand!=1);
     cout << count;
which returned 0. Now if you think this over, that means that it
is a full period generator.
max_trace_level 256media{absorption.02}camera{location<1,.3,1.7>}sphere{0
.8pigment{color.6}interior{media{emission<2,2,-2>absorption 2}}hollow}#macro
p(f,n)plane{n f-1finish{reflection<f,1f>}}#end p(1y)p(1z-x)p(-1,-z)p(1x-y)
// Mark Weyer
Date: 12 Feb 2003 10:15:59
Message: <3E4A6812.4000107@informatik.uni-freiburg.de>
 From Micha Reiser's post I conclude that I might have looked in the
wrong place. The generator is the same, however.
// Mark Weyer
Date: 12 Feb 2003 10:27:51
Message: <3e4a67f6@news.povray.org>
  If this is so, then it means that there's actually just one single
fixed stream of pseudo-random numbers in POV-Ray, and with seed() you
just tell where to start taking numbers from this stream.
  (On implication of this is that if you have two streams generated
with different seed() values, they will both eventually start to give
the same numbers as the other.)
Date: 12 Feb 2003 10:35:34
Message: <3e4a69c6$1@news.povray.org>
AFAIK, preventing such behaviuor was never a desing goal of multiple RNG
streams in POV-Ray... They are there simply to protect scenes that rely on
RNG in placing/scattering objects etc.
On the other hand, the implication you point out may easily become of
importance for other scenes... IMHO one possible solution is to use the
RANDMAR generator I mentioned in my other post; it was specially designed to
provide users with ~32k independent streams.
Date: 12 Feb 2003 11:46:24
Message: <cjameshuff-638296.11461512022003@netplex.aussie.org>
In article <3e4a67f6@news.povray.org>, Warp <war### [at] tagpovrayorg>
Correct.
Not correct. They will both repeat, and repeat the same sequence, but if
they are initialized with different seeds, they will always have
different numbers at any moment. Assuming you pull random numbers from
each at an equal rate, anyway.
http://tag.povray.org/
Date: 12 Feb 2003 12:05:44
Message: <3e4a7ee8$1@news.povray.org>
I think the notion of "any moment" is not particularly applicable here...
Imagine a scene similar to one generated with Chris Colefax's City
Generator. The implication that Warp (probably; me -- certainly) meant is
that is if you, say, use different streams *and* different seeds for each
block, you may still end up with very similar blocks since the sub-sequences
your RNGs generate may still overlap.
To be even more specific: think about blocks with scattered trees. If your
streams' sub-sequences overlap, you may end up with many *equally* (not even
"similarly") shaped and located trees in different blocks. Hope you got the
idea...
Date: 12 Feb 2003 12:22:56
Message: <3e4a82f0$1@news.povray.org>
"Vadim Sytnikov" <syt### [at] rucom> wrote in message
news:3e4a7ee8$1@news.povray.org...
> idea...
True - however the sheer length of the stream would make this unlikely. Also,
consider:
#declare R1 = seed(3245);
#declare R2 = seed(7342);
#while(true)
    #declare A1 = rand(R1);
    #declare A2 = rand(R2);
    #declare A3 = rand(R2);
Because R2 is hit twice, but R1 only once, A1 and A2 will never show the same
sequence (afaik).
Date: 12 Feb 2003 12:25:08
Message: <3e4a8374@news.povray.org>
news:3e4a82f0$1@news.povray.org...
<snip>
Meanwhile, I'm still looking for my 3 numbers in a row.
Here's the code (and a clue;)....
#declare Found = false;
#declare Seed1 =  0;
#declare Count = 1;
#declare Searching = true;
#while(Searching)
  #declare Rand1 = seed(Seed1);
  #declare Val = rand(Rand1)*235;
  #if(int(Val) = 234)
    #if(int(Val) = 85)
      #debug concat(str(Count,0,0),": B: ",str(int(Val),0,0), "\n")
      #declare Count = Count + 1;
      #if(int(Val) = 81)
        #debug concat("C: ",str(int(Val),0,0), "\n")
        #debug concat("\n", "Seed = ",str(Seed1,0,0),"\n")
        #declare Searching = false;
  #declare Seed1 = Seed1 + 1;
Date: 12 Feb 2003 13:05:42
Message: <3e4a8cf6$1@news.povray.org>
Well, I would say, completely impossible things are all around! :-)
In the Knuth's Vol2 I metnioned the author gives a very educative account of
his early experience with designing RGNs. By then, he was young enough :-)
to try to invent the best (no less!) RNG in the world. So he came up with an
utterly sophisticated, if not cryptic, scheme.
Guess what? His RNG repeated itself on step 18! (IIRC; in either case, the
number was around 20...). That taught him... many important things. :-)
Which I hope I have absorbed while reading his excellent books.
BTW, in this respect, Knuth was not alone. One of IBM's RNGs (shipped as
part of FORTRAN libraries for 360's, I believe) appeared to produce series
that, if interpreted as 3D coordinates, would form points all lying on just
several planes in 3D space.
So... :-)
Date: 12 Feb 2003 14:26:24
Message: <3e4a9fe0@news.povray.org>
  In the man page of rand() in some Unix variant (don't remember which)
there was a note that the lowest bit of the number returned by rand() should
not be used because it alternates between 0 and 1 in successive calls.
  Makes one wonder if it wouldn't be better to fix the problem instead
of documenting it... :)
Date: 12 Feb 2003 14:34:43
Message: <cjameshuff-598297.14343212022003@netplex.aussie.org>
In article <3e4a7ee8$1@news.povray.org>,
That was a bit vague, I was in a hurry. I meant that if you took two
streams with different seeds (which internally are different positions
on one stream), and keep taking random numbers from both, you will never
reach a point where both produce the same sequence.
The random number generator POV uses is not that great, for example: a
given number can only occur once in the sequence. It is sufficient for
most uses, though, and fast and simple.
> idea...
Actually, because of the way tree algorithms work, a little difference
can produce an entirely different tree, even if the random stream is
almost the same. They are often quite chaotic. But I get what you
mean...it is possible, but the period is large enough to make it
unlikely.
Date: 12 Feb 2003 15:20:08
Message: <3e4aac78@news.povray.org>
BTW, in the same vein... Can't remember who (Knuth? Deikstra? Wirth?) said
that, but I liked it very much:
"Anyone who considers arithmetic means of producing random numbers is, of
course, in a state of sin."
Date: 12 Feb 2003 16:40:42
Message: <cjameshuff-F016FD.16403212022003@netplex.aussie.org>
In article <3e4a9fe0@news.povray.org>, Warp <war### [at] tagpovrayorg>
Maybe there was some other constraint that kept them from doing
so...performance, etc. Or maybe they just didn't know anything about
PRNG's.
In any case, I never use rand(). I occasionally use random(). From the
manpage:
     The random() function uses a non-linear additive feedback random
     number generator employing a default table of size 31 long
     integers to return successive pseudo-random numbers in the range
     from 0 to (2**31)-1.  The period of this random number generator
     is very large, approximately 16*((2**31)-1).
     The random() and srandom() functions have (almost) the same
     calling sequence and initialization properties as the rand(3) and
     srand(3) functions.  The difference is that rand(3) produces a
     much less random sequence -- in fact, the low dozen bits generated
     by rand go through a cyclic pattern.  All the bits generated by
     random() are usable.  For example, `random()&01' will produce a
     random binary value.
It is pretty simple to create a wrapper class for it. Usually I use a
Mersenne Twister class I wrote. (Meaning of course that I wrote the
class, much of the code is very close to the original implementation by
Makoto Matsumoto and Takuji Nishimura.)
This is the random number generator I used in Sapphire.
Date: 12 Feb 2003 16:52:17
Message: <3e4ac211@news.povray.org>
  If what you need are random floating point numbers, then drand48() should
do the job.
DESCRIPTION
     This family of  functions  generates  pseudo-random  numbers
     using  the  well-known linear congruential algorithm and 48-
     bit integer arithmetic.
     Functions  drand48()  and  erand48()   return   non-negative
     double-precision floating-point values uniformly distributed
     over the interval [0.0, 1.0].
     Functions lrand48() and nrand48() return  non-negative  long
     integers uniformly distributed over the interval [0, 2**31].
     Functions  mrand48()  and  jrand48()  return   signed   long
     integers uniformly distributed over the interval [-2**31 , 2
    **31 ].
     Functions srand48(), seed48(), and lcong48() are initializa-
     tion  entry  points,  one  of which should be invoked before
     either  drand48(),  lrand48(),  or  mrand48()   is   called.
     (Although  it  is not recommended practice, constant default
     initializer  values  will  be  supplied   automatically   if
     drand48(), lrand48(), or mrand48() is called without a prior
     call to an initialization entry point.) Functions erand48(),
     nrand48(),  and  jrand48()  do not require an initialization
     entry point to be called first.
     All the routines work by generating  a  sequence  of  48-bit
     integer  values,  Xi  , according to the linear congruential
     formula
           X n+1= (aX n+c)  mod m n>=0.
     The parameter m = 2**48; hence 48-bit integer arithmetic  is
     performed. Unless lcong48() has been invoked, the multiplier
     value aand the addend value care given by
               a = 5DEECE66D16 = 2736731631558
               c = B16 = 138 .
     The value  returned  by  any  of  the  functions  drand48(),
     erand48(),  lrand48(), nrand48(), mrand48(), or jrand48() is
     computed by first generating  the  next  48-bit  Xi  in  the
     sequence.  Then the appropriate number of bits, according to
     the type of data item to be returned, are  copied  from  the
     high-order  (leftmost)  bits  of Xi and transformed into the
     returned value.
     The functions drand48(), lrand48(), and mrand48() store  the
     last  48-bit  Xi generated in an internal buffer. Xi must be
     initialized prior to being invoked. The functions erand48(),
     nrand48(), and jrand48() require the calling program to pro-
     vide storage for the  successive  Xi  values  in  the  array
     specified  as  an  argument  when the functions are invoked.
     These routines do not have to be  initialized;  the  calling
     program  must place the desired initial value of Xi into the
     array and pass it as an argument. By using  different  argu-
     ments,  functions  erand48(), nrand48(), and jrand48() allow
     separate modules of a  large  program  to  generate  several
     independent  streams  of pseudo-random numbers, that is, the
     sequence of numbers in each stream will not depend upon  how
     many times the routines have been called to generate numbers
     for the other streams.
     The initializer function srand48() sets  the  high-order  32
     bits  of  Xi  to  the 32 bits contained in its argument. The
     low-order 16 bits of Xi  are  set  to  the  arbitrary  value
     330E16 .
     The initializer function seed48() sets the value  of  Xi  to
     the  48-bit  value specified in the argument array. In addi-
     tion, the previous value of  Xi  is  copied  into  a  48-bit
     internal  buffer,  used  only  by seed48(), and a pointer to
     this buffer is the value returned by seed48(). This returned
     pointer,  which can just be ignored if not needed, is useful
     if a program is to be restarted from a given point  at  some
     future  time  - use the pointer to get at and store the last
     Xi value, and then use  this  value  to  reinitialize  using
     seed48() when the program is restarted.
     The initialization function lcong48()  allows  the  user  to
     specify  the  initial  Xi  the  multiplier  value a, and the
     addend value c. Argument array elements  param[0-2]  specify
     Xi, param[3-5] specify the multiplier a, and param[6] speci-
     fies the 16-bit addend c. After lcong48() has been called, a
     subsequent call to either srand48() or seed48() will restore
     the ``standard'' multiplier and  addend  values,  a  and  c,
     specified above.
Date: 12 Feb 2003 17:08:18
Message: <3e4ac5d2@news.povray.org>
  That's not even what I claimed.
  What I claimed was that eventually one of the streams will start giving
the same numbers as the other streams gave to start with. And also the
other way around.
  This means that if you use two streams to position objects, it may
happen that after a certain time one type of objects begins to appear
in the exact same places as the other type of objects started to
appear at the beginning.
Date: 12 Feb 2003 17:41:44
Message: <cjameshuff-3CE5BE.17413412022003@netplex.aussie.org>
In article <3e4ac5d2@news.povray.org>, Warp <war### [at] tagpovrayorg>
> other way around.
Ok, I understand. Yes, that will happen.
Right. But that won't happen for any number of objects you are likely to
hit.
Date: 12 Feb 2003 17:50:59
Message: <3E4ACFD3.285EF175@hotmail.com>
> > #while(sA!=sB)
#local rsA=seed(0);
#local rsB=seed(rand(rsA));
#if(rand(rsA)=rand(rsB))
  #debug "Yes, I am sure.\n"
#else
  #debug "No, I am not sure.\n"
John
Date: 12 Feb 2003 17:56:24
Message: <3e4ad118$1@news.povray.org>
Google helped, as always... It was John von Neumann.
(and the exact quote is "Anyone who considers arithmetical methods of
producing random digits is, of course, in a state of sin").
Date: 12 Feb 2003 19:09:02
Message: <3e4ae21d@news.povray.org>
> hit.
  It depends a lot on your initial seed values. If you are very unlucky,
the second number you get from stream 1 will be the same as the first
number you got from stream 2, and it will then begin to give the same
numbers from that point forward.
  Of course in theory the chance of this happening is 1/(2^32), that is,
extremely unlikely, but possible. :)
Date: 12 Feb 2003 22:33:11
Message: <3E4B14F5.9080605@alphalink.com.au>
>>other way around.
The problem being, as I understand it, that there is only one sequence
of random numbers in POV (if m follows n in one run, m will always
follow n), as stated earlier.
Could this not be easily worked around by the following:
Where you want two sequences that are ordered differently, use four
random sequences with the seeds a1, a2, b1 and b2. To get a random
number for your first sequence add the two 'a' seqences modulo 2^32,
likewise for the second sequence add the two 'b' seqences modulo 2^32.
This would probably introduce more problems than it solves for some
purposes, leading to even less randomness in the low bits, and to some
values never being visited and others being visited disproportionately
frequently.
Alternately you could implement your own PNG in POV-SDL.
Date: 13 Feb 2003 02:13:39
Message: <3e4b45a3@news.povray.org>
  When dealing with random number generators, it's a very common principle,
that trying to make a good RNG better by adding more clutter to it usually
makes it a lot worse. (The natural way of thinking that "a more complicated
function will probably lead to a more complicated result" is usually quite
false when dealing with RNGs. Usually when trying to make the function
"more complicated" you end up with an extremely poor RNG.)
Date: 13 Feb 2003 02:49:48
Message: <3E4B511B.4060706@alphalink.com.au>
Oh, absolutely, I wasn't trying to make a better PRNG, indeed I stated
that it would be worse for many situations. The only benefit it provides
is providing different sequences, so if the number 1929474638 follows
92928 in one sequence, the same will not necessarily occur in another.
Obviously if you need really good psuedo-random numbers in POV there are
far better options if you're prepared to put in a little effort.
