POV-Ray : Newsgroups : povray.general : ball bearing geometry => Re: Is there a math formula for making... Server Time
13 Jul 2026 02:29:10 EDT (-0400)
  ball bearing geometry => Re: Is there a math formula for making... (Message 1 to 1 of 1)
Subject: ball bearing geometry => Re: Is there a math formula for making...
Date: 2 Feb 2003 01:33:09
Message: <3e3cbba5@news.povray.org>
"Patrick Dugan" <pat### [at] netinsnet> wrote in message
news:3e3c554a@news.povray.org...
> I couldn't explain the request within the subject line so I'll try to
> explain it here.  I am trying to create several sets of cylinders. The
first
> cylinder is located dead center <0,0,0> and has a radius of 1.5.  I want
to
> place smaller (maybe 80% or so smaller) cylinders around the outside edge
so
> that the cylinders all touch each other and touch the middle cylinder.
> (perhaps nine or so.) Then I want to make another set outside the last of
> cylinders (a little smaller still) that all touch each other and the
> cylinders below them.  I want to get smaller and smaller cylinders until
> they are very small (perhaps 0.1 or so) at a distance of +6 from center.
I
> am including a small (very poor) drawing of what I'm trying to accomplish
> (although I want the cylinders to go all the way around.)
> Is there some math formula that would correctly create these?
> Patrick (math impaired) Dugan
This is fairly simple ...
You have three related variables that depend on each other.
Radius of the 'shaft', radius of each cylinder in the surrounding ring,
and - most importantly - the number of cylinders in the surrounding
ring.
I've appended a sample scene that sets N (number of cylinders in ring)
and the radius of each cylinder in the ring. Then, the shaft radius is
calculated.
You can re-write the order of things so that you set any other two variables
and calculate the third - but you will find these things are almost always
designed by setting N first.
Play with this code by changing N and r.
Adding a second ring of cylinders and changing the dependent variable
is left as an exercise to the reader because it's good for you.
Anyway -
// first just some scene basics
global_settings {  assumed_gamma 2.2 }
#include "functions.inc"
#include "math.inc"
#include "consts"
#ifndef(cam_loc) #declare cam_loc=<0.00, 0.00, -10.00>; #end
#ifndef(cam_look) #declare cam_look=<0.00, 0.00, 0.00>; #end
#ifndef(focal_length) #declare focal_length=1.00; #end
#declare focal_length = 30;
#declare origin       = <0.000, 0.000,  0.000>;
#declare cam_loc      = <1.000, 1.000, -1.000>;
#ifndef(scene_cam)
 #declare scene_cam=
  camera{
   location  cam_loc * focal_length
   look_at  cam_look
#ifndef(main_light)
 #declare main_light=
   light_source{
    cam_loc * focal_length, color rgb <1.000, 1.000, 1.000>
camera{scene_cam}
object{main_light translate <0.000, 10.000, 0.000>}
plane{ z,  30.000 pigment{color White}}
plane{ y, -30.000 pigment{color White}}
//light_source{< 10.00, 40.00, -20.00>, color rgb<0.00, 0.20, 0.70>
spotlight point_at origin}
//light_source{<-10.00, 40.00, -20.00>, color rgb<0.00, 0.70, 0.20>
// main section defining objects
#declare N =32;
#declare r =0.5;
#ifndef(N)    #declare N = 12; #end
#ifndef(r)    #declare r =  1; #end
#ifndef(cylZ) #declare cylZ = 10.000; #end
#declare d = 360/N;
#declare sin_d = sin(radians(d/2));
#declare R = (r/sin_d) -r;
#declare core =
 cylinder{
  origin, <0.000, 0.000, cylZ>, R
  open
  pigment{color rgb Yellow}
#declare ring_element =
 cylinder{
  origin, <0.000, 0.000, cylZ>, r
  open
  pigment{color rgb Orange}
// make the objects
object{core         no_shadow}
#declare n = 0;
#while (n<N)
  object{
   ring_element
   no_shadow
   translate <R + r, 0.000, 0.000>
   rotate <0.000, 0.000, n * d>}
  #declare n = n +1;
