POV-Ray : Newsgroups : povray.general : Turquoise spots, PovRay v3.5 Server Time
2 Nov 2026 15:22:01 EST (-0500)
  Turquoise spots, PovRay v3.5 (Message 1 to 11 of 11)
Subject: Turquoise spots, PovRay v3.5
Date: 19 Jan 2003 19:26:40
Message: <3e2b4240@news.povray.org>
I am attempting to render gemstones with dispersion and have run into some
difficulties using PovRay v3.5.
In the finish statement I set the reflection color_reflection_min to the
square of (ior -1.0) / (ior + 1.0), the color_reflection_max to 1.0 and
turned on fresnel.
According to the help file when the amount of reflected light changes, the
amount of transmitted light should also change. To achieve this
conserve_energy keyword was added to the finish statement.
In the interior statement is the ior value and dispersion and its value.
When the gemstone is rendered there are hundreds of unwanted turquoise
colored spots.
How do I conserve energy and have dispersion without the turquoise spots?
Dick Conley
dic### [at] localaccesscom
Subject: Re: Turquoise spots, PovRay v3.5
Date: 19 Jan 2003 19:43:33
Message: <3e2b4635@news.povray.org>
Increase photon_count or decrease photon_spacing?
--Tim Cook
Version: 3.12
Date: 21 Jan 2003 12:49:48
Message: <3e2d883c$1@news.povray.org>
So far I have had only one reply which did not solve the problem.
Further testing revealed that these turquoise spots are present with or
without photons when both conserve_energy and dispersion are present. Photon
spacing has no effect. With or without photons, remove either
conserve_energy or dispersion and the spots are gone.
With all the experts out there hopefully someone can show me how to have
conserve_energy and dispersion without the spots.
Dick Conley
"Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote in message
news:3e2b4635@news.povray.org...
spots?
> --Tim Cook
> http://empyrean.scifi-fantasy.com
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
Date: 21 Jan 2003 16:27:11
Message: <3e2dbb2f@news.povray.org>
Try increasing the dispersion count?  (hehe this one's probably
useless too, like my last one)
--Tim Cook
Version: 3.12
Date: 21 Jan 2003 18:27:48
Message: <3e2dd774@news.povray.org>
Is max_trace_level large enough? Is radiosity used? No coincident surfaces?
It might be easier to diagnose if a minimal scene is given so it can be
rendered by others.
Date: 22 Jan 2003 14:46:48
Message: <3e2ef528$1@news.povray.org>
I forgot to uncomment conserve_energy before I sent the scene. Sorry.
You will need to uncomment conserve_energy to see the turquoise spots.
 Dick Conley
Subject: please cancel your message with the files
Date: 22 Jan 2003 16:33:52
Message: <3e2f0e40$1@news.povray.org>
Thanks for the files but you made a mistake by posting them into a
non-binaries group here at povray.general. You should have put them at
povray.binaries.scene-files. See the announce.f-a-q group for posting
guidelines.
Sorry if I misled you into thinking that attachments were okay here. To
cancel it in Outlook, select your message then go to the Message menu (main
menu), Cancel.
I'll be looking at the render and script to see if I can help.
Date: 22 Jan 2003 17:07:56
Message: <3e2f163c@news.povray.org>
"Dick Conley" <dic### [at] localaccesscom> wrote in message
news:3e2b4240@news.povray.org...
> colored spots.
Having now rendered your scene file I can only say that it seems a limit of
some kind is reached. I don't see anything like you describe though. What I
get is a charcoal diamond, shades of dark gray. When I lower ior to 1.5 a
portion in the middle turns white. I can't say it is a bug, only that it
looks like a limitation and could be a possible bug. To make matters worse
is that our renders do not show us the same thing occuring.
With any luck maybe someone else could tell more about this.
Date: 25 Mar 2003 14:16:03
Message: <3e80aaf3$1@news.povray.org>
It has been over 2 months, my problem has not been resolved and I have not
heard from anyone. Is this problem being investigated? Is there a problem
with PovRay? If PovRay is OK, what am I doing wrong? Would someone please
give me an update. It is frustrating waiting for answers and not knowing if
anything is being done to solve my problem.
Dick Conley
> turned on fresnel.
> colored spots.
> Dick Conley
Date: 26 Mar 2003 04:37:38
Message: <3e8174e2$1@news.povray.org>
news:3e80aaf3$1@news.povray.org...
Is this the same bug that's being discussed in "Bug with dispersion" in this
group? It does seem to be confirmed as a bug - perhaps a minimal scene that
demonstrates it and a post to bugreports?
BTW I'm sure it's not your intent, but your posts come across as rather bossy.
Date: 26 Mar 2003 12:55:57
Message: <3e81e9ad@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3e8174e2$1@news.povray.org...
not
problem
please
if
this
that
bossy.
Yes, this is the same problem I reported over 2 months ago including a
minimal scene. I kept watching my thread and found no further news. Now I
find from the post you mentioned that indeed it is a bug. Thanks for
informing me of the other thread. I am anxiously awaiting the fix.
Dick Conley
