If you render the following scene, the black and white of the checker pattern is
reversed when viewed through the transparent sphere - is this a bug?
Win 2000, p3 733, pov3.5
#version 3.5;
global_settings {
assumed_gamma 1.0
location <0.0, 1.0, -5.0>
look_at <0.0, 1.0, 0.0>
plane{y,-0.001 pigment{checker pigment{Black}, pigment{White}}}
sphere{0,1
translate y*1
pigment{rgbt 1}
#macro A(V,B,C,R)#while(B-256)#if(V-128/B>=0)sphere{0,.5translate<C-4R-1,9>
pigment{rgb<1-C/8R/2C/8>}}#local V=V-128/B;#end#local B=B*2;#local C=C+1;#
end#end A(234,1,0,2)A(85,1,0,1)A(81,1,0,0)light_source{-5 1}//Tom Melly
"Tom Melly" <tom### [at] tomandlu co uk> wrote in message
news:3e26e84f$1@news.povray.org...
It's worth noting that adding a point-light makes no difference, and also I seem
to be seeing some odd artifacts on the sphere.
news:3e26e9b2@news.povray.org...
seem
I've posted an image to images in case it's a local bug - also note that it
doesn't afaik affect any other pattern except checker, and it will happily swap
any two colours.
On Thu, 16 Jan 2003 17:13:50 -0000, "Tom Melly" <tom### [at] tomandlu co uk> wrote:
This can be floating point accuracy, but of course needs further
investigation.
ABX
Slime wrote:
> See, the potential problem is that the checker pattern has opposite values
> in the y=(0,1] range than it does in the y=(-1,0] range. So *tiny*
> inaccuracies can cause the pattern to return *opposite* values. To avoid
> this, the pattern is pre-translated internally by y*-0.001. Normally that
> fixes it. However, that is *exactly* where you set the surface of your
> plane, so you're reintroducing the original floating point innacuracies.
I can't believe it ! Someone assumed that the checker patern was much
more used with a horizontal plane than with a vertical one ?
I find it rather strange that this correction is internaly code, since
we (users) are used to do corrections ourselves (in case of intersection
between objects, things like that). Is this documented somewhere ? I
guess we all assumed cubes went from 0 to 1, and so on...
Jul### [at] cnedra org
http://www.cnedra.org
On Thu, 16 Jan 2003 20:34:37 +0100, Julien Gourdon <jul### [at] cnedra org> wrote:
I'm not sure how you have recognize that this is a horizontal plane and not
vertical ... ;-)
ABX
"Slime" <slm### [at] slimeland com> wrote in message
news:3e26fa99@news.povray.org...
Ah - that makes sense (as in now you've explained, rather than, doh, why
didn't I think of that). As a suggestion, it might make more sense to
translate by, say, -0.273 (less likely to be picked than 0.001).
Weird all the same.
> vertical ... ;-)
y normal ? Was not this supposed to be horizontal ? :)
"Tom & Lu Melly" <all### [at] tomandlu co uk> wrote in message
news:3e270b18@news.povray.org...
that
Admittedly, it probably isn't the ultimate perfect solution. For this to be
okay the surface placement needs to begin at 0, such as plane {y,0 material
{...} translate XYZ} so that translate would be used for moving the whole
thing to prevent erroneous happenings. If textures could dynamically
readjust maybe that would be perfect. Maybe not :-)
0.001 was picked arbitrarily, as I recall. Or maybe because it was already a
value used in the source code, but I'd be speculating about that. I looked
it up and it is not y*-0.001, it's used on all three axes and is positive
not negative. That is if I'm reading the source code correctly. That part is
rather simple though, you can find the checker pattern in pigment.cpp and
the Small_Tolerance used on it in frame.h.
The problem encountered would happen at some user offset no matter what, I
think, and the 0.001 isn't at 0.0 at least where the most common occurances
of surfaces would align. Of course, a smaller number would become ever less
likely to intersect. Just also becomes a little more obscure.
Someone else might know this. There might be very good reasons to not go to
a smaller value for Small_Tolerance in the first place since it is a factor
for the ray tracing itself I guess.
My mistake. The texture is actually internally translated by
<-0.001,-0.001,-0.001>. Some of those may be positive, I don't know for
sure.
Thing is, if they didn't do it, hundreds of new users trying out their first
simple reflective-sphere-on-checkered-plane scene would complain to them,
saying it was a bug.
- Slime
[ http://www.slimeland.com/ ]
to
factor
For some objects defined by high-order equations, .001 is as low as you can
safely go.
However, I wouldn't think that'd be the case with most objects that have
flat edges... I'd expect a smaller tolerance to be used. *shrug*
- Slime
For those of us belonging to "CAD school" (like yours truly), the answer is
DEFINITELY NO! :-)
Since it's arbitrary, I agree that it should be a value which is much
less likely to be used by anyone by chance. 0.001 is such a value that it's
extremely likely that someone will use some day. However, if it was
something like 0.00139263205, then the odds are practically nonexistent.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
it's
Oh, you know how it is. *Some* jerk would find it and complain. ;)
- Slime
On Thu, 16 Jan 2003 21:31:49 +0100, Julien Gourdon <jul### [at] cnedra org> wrote:
> > vertical ... ;-)
When you lie in bed and your view is rotated about 90 degrees, horizont is
still at the same place, not rotated. The appearance of view by itself does
not define horizontal and vertical things. Meaning of 'horizontal' is relative
and is influenced by assumptions about envirionment. More accurate thinking is
probably something like: "it is horizontal plane becouse 'sky' keyword in
camera statement was not changed and therefore default sky can be reached
going along y. the plane normal is also y but has nothing to do with this."
ABX
"Slime" <slm### [at] slimeland com> wrote in message news:3e273eaf$1@news.povray.org...
Arguably, it's better to have it rare, but not too rare - of course you could
make it pow(-1,0.5) ;)
