POV-Ray : Newsgroups : povray.general : Colour-flip bug? Server Time
13 Jul 2026 03:56:16 EDT (-0400)
  Colour-flip bug? (Message 1 to 10 of 16)
Subject: Colour-flip bug?
Date: 16 Jan 2003 12:13:51
Message: <3e26e84f$1@news.povray.org>
If you render the following scene, the black and white of the checker pattern is
reversed when viewed through the transparent sphere - is this a bug?
Win 2000, p3 733, pov3.5
#version 3.5;
global_settings {
  assumed_gamma 1.0
  location  <0.0, 1.0, -5.0>
  look_at   <0.0, 1.0,  0.0>
plane{y,-0.001 pigment{checker pigment{Black}, pigment{White}}}
sphere{0,1
  translate y*1
  pigment{rgbt 1}
#macro A(V,B,C,R)#while(B-256)#if(V-128/B>=0)sphere{0,.5translate<C-4R-1,9>
pigment{rgb<1-C/8R/2C/8>}}#local V=V-128/B;#end#local B=B*2;#local C=C+1;#
end#end A(234,1,0,2)A(85,1,0,1)A(81,1,0,0)light_source{-5 1}//Tom Melly
Subject: Re: Colour-flip bug?
Date: 16 Jan 2003 12:19:46
Message: <3e26e9b2@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3e26e84f$1@news.povray.org...
It's worth noting that adding a point-light makes no difference, and also I seem
to be seeing some odd artifacts on the sphere.
Date: 16 Jan 2003 12:32:46
Message: <3e26ecbe@news.povray.org>
news:3e26e9b2@news.povray.org...
seem
I've posted an image to images in case it's a local bug - also note that it
doesn't afaik affect any other pattern except checker, and it will happily swap
any two colours.
Date: 16 Jan 2003 12:41:56
Message: <1ird2vkjc7p85nsivpumt0foc1ivlsvnjg@4ax.com>
On Thu, 16 Jan 2003 17:13:50 -0000, "Tom Melly" <tom### [at] tomandlucouk> wrote:
This can be floating point accuracy, but of course needs further
investigation.
ABX
Date: 16 Jan 2003 14:29:26
Message: <3E27094D.6090501@cnedra.org>
Slime wrote:
> See, the potential problem is that the checker pattern has opposite values
> in the y=(0,1] range than it does in the y=(-1,0] range. So *tiny*
> inaccuracies can cause the pattern to return *opposite* values. To avoid
> this, the pattern is pre-translated internally by y*-0.001. Normally that
> fixes it. However, that is *exactly* where you set the surface of your
> plane, so you're reintroducing the original floating point innacuracies.
I can't believe it ! Someone assumed that the checker patern was much
more used with a horizontal plane than with a vertical one ?
I find it rather strange that this correction is internaly code, since
we (users) are used to do corrections ourselves (in case of intersection
  between objects, things like that). Is this documented somewhere ? I
guess we all assumed cubes went from 0 to 1, and so on...
Jul### [at] cnedraorg
http://www.cnedra.org
Date: 16 Jan 2003 14:39:53
Message: <ge2e2vkk0mn0tkmphn3l59po20jcsmngno@4ax.com>
On Thu, 16 Jan 2003 20:34:37 +0100, Julien Gourdon <jul### [at] cnedraorg> wrote:
I'm not sure how you have recognize that this is a horizontal plane and not
vertical ... ;-)
ABX
Date: 16 Jan 2003 14:42:16
Message: <3e270b18@news.povray.org>
"Slime" <slm### [at] slimelandcom> wrote in message
news:3e26fa99@news.povray.org...
Ah - that makes sense (as in now you've explained, rather than, doh, why
didn't I think of that). As a suggestion, it might make more sense to
translate by, say, -0.273 (less likely to be picked than 0.001).
Weird all the same.
Date: 16 Jan 2003 15:26:36
Message: <3E2716B5.7050402@cnedra.org>
> vertical ... ;-)
y normal ? Was not this supposed to be horizontal ? :)
Date: 16 Jan 2003 16:01:22
Message: <3e271da2@news.povray.org>
"Tom & Lu Melly" <all### [at] tomandlucouk> wrote in message
news:3e270b18@news.povray.org...
that
Admittedly, it probably isn't the ultimate perfect solution. For this to be
okay the surface placement needs to begin at 0, such as plane {y,0 material
{...} translate XYZ} so that translate would be used for moving the whole
thing to prevent erroneous happenings. If textures could dynamically
readjust maybe that would be perfect. Maybe not  :-)
0.001 was picked arbitrarily, as I recall. Or maybe because it was already a
value used in the source code, but I'd be speculating about that. I looked
it up and it is not y*-0.001, it's used on all three axes and is positive
not negative. That is if I'm reading the source code correctly. That part is
rather simple though, you can find the checker pattern in pigment.cpp and
the Small_Tolerance used on it in frame.h.
The problem encountered would happen at some user offset no matter what, I
think, and the 0.001 isn't at 0.0 at least where the most common occurances
of surfaces would align. Of course, a smaller number would become ever less
likely to intersect. Just also becomes a little more obscure.
Someone else might know this. There might be very good reasons to not go to
a smaller value for Small_Tolerance in the first place since it is a factor
for the ray tracing itself I guess.
Date: 16 Jan 2003 16:12:37
Message: <3e272045$1@news.povray.org>
My mistake. The texture is actually internally translated by
<-0.001,-0.001,-0.001>. Some of those may be positive, I don't know for
sure.
Thing is, if they didn't do it, hundreds of new users trying out their first
simple reflective-sphere-on-checkered-plane scene would complain to them,
saying it was a bug.
 - Slime
[ http://www.slimeland.com/ ]
