Hello,
Have you ever felt that the standard scaling is not what you need? I was
thinking about that and it occurred to me that it could be interesting to
be able to grow or shrink an object not relative to the origin (as with the
standard scaling) but perpendicularly to its surface. Does this have any
sense? It would be equivalent for some simple shapes: sphere, cube... but
for others it would be like changing the threshold value (for blobs), or
altering the minor radius (for tori)...
I know this is more than probably not easy (impossible?) to do, and maybe
it's not interesting at all, but well, I lose nothing by writing it here :)
Regards
Ignacio Fernández Galván
Linux User #289967 (counter.li.org)
PGP Pub Key ID: 0x01A95F99 (pgp.escomplinux.org)
I think the way POV-Ray works does not make
this possible. Perhaps using functions, or Horman's
isoCSG, but I'm not too sure about that. After all, you
are talking about a double step: find the surface, get
the normal, and then move surface in opposite direction
to normal...
This may work very easy with meshes, but not with
mathematical solutions, and especially not a jumbled
mess of them (which a union/merge normally is)...
Tim Nikias
Email: Tim### [at] gmx de
"Jellby" <jel### [at] M-yahoo com> schrieb im Newsbeitrag
news:3dfce408@news.povray.org...
> Hello,
the
> Regards
the
It's been thought of before, and while possible with some shapes, it's very
difficult (and analytically impossible for certain shapes).
Mega-POV's "proximity pattern" did this, I think.
- Slime
[ http://www.slimeland.com/ ]
In article <3dfd0c76@news.povray.org>, "Slime" <slm### [at] slimeland com>
Sort of: the proximity pattern used the average or minimum distance to
the surface. Theoretically, this could be used in an isosurface to do
this "inflate" effect, but the original pattern was almost unuseably
slow in textures (on computers of that time), as an isosurface function
it would be extremely slow. I'm working on an updated version that has
optimized object-specific proximity methods in addition to the
ray-sampling method.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
Subject: Re: Another kind of scaling or "growing"
Date: 16 Dec 2002 08:20:48
Message: <3dfdd330@news.povray.org>
Write your own macro to do this using the trace function.
This confusing double-set of coordinates made use of CorelDream3D a
confusing waste of time...
Date: 17 Dec 2002 11:37:25
Message: <3DFF52DD.9060003@free.fr>
Jellby wrote:
> Hello,
It's been done already (as a patch of 3.1) for mesh,
see http://jgrimbert.free.fr/pov/patch/tessel/index.html#displace
It works better with smoothed mesh, because otherwise the
displacement/growth along the normal create a lot of holes in the mesh
(but that can be a desired effect...)
Given the way Pov works, your idea is only possible with mesh and
mesh-compatible objects.
OK, thanks for the replies.
I understand it's difficult/impossible to implement in POV, and I didn't
intend to suggest that, I was just trying to start a conversation about it
I guess meshes (and macros) would be the way to go for this. How hard would
be to take into account the possible spliting of the object? It's been a
long time since I last made anything in POV, and I don't have much time
now, so this is just a "thought experiment".
