POV-Ray : Newsgroups : povray.general : Trace from a surface? Server Time
23 Aug 2025 07:05:20 EDT (-0400)
  Trace from a surface? (Message 1 to 4 of 4)
Subject: Trace from a surface?
Date: 4 Dec 2002 22:38:33
Message: <3deeca39$1@news.povray.org>
What is pov going to do if you do a trace call from a point that is exactly
on a surface--
i) always report that surface,
ii) always report the next one it hits in your specified direction,
or
iii)  give haphazard results
Subject: Re: Trace from a surface?
Date: 4 Dec 2002 23:14:58
Message: <chrishuff-CD6CFC.23115404122002@netplex.aussie.org>
In article <3deeca39$1@news.povray.org>,
> on a surface--
> or
D) intersections too close to the start of the ray are ignored. You
should still be careful with it though...
http://tag.povray.org/
Date: 4 Dec 2002 23:15:44
Message: <pan.2002.12.05.04.14.37.312521.222@gte.net>
On Wed, 04 Dec 2002 22:37:15 -0500, Greg M. Johnson quoth:
> exactly on a surface--
> ii) always report the next one it hits in your specified direction, or
Depends on the surface, but in general, iii) give haphazard results
Mark
Date: 6 Dec 2002 07:16:20
Message: <3df09514@news.povray.org>
  If that would be true, then any surface with reflections or refractions
would look wrong.
  The reflected/refracted rays start exactly from the surface of the object.
(Internally there's an epsilon value added to the start point of the ray
to avoid problems, and I suppose that trace() works in the exact same way.)
