POV-Ray : Newsgroups : povray.general : mesh CSG woes Server Time
22 Oct 2026 15:44:06 EDT (-0400)
  mesh CSG woes (Message 1 to 6 of 6)
Subject: mesh CSG woes
Date: 2 Dec 2002 18:23:51
Message: <3debeb87@news.povray.org>
Hi all,
somewhat to my surprise I discovered that a mesh (in this case a character
from Poser) doesn't work properly in CSG operations. After a little thought,
i think this had something do to with the mesh not having an 'interior'. is
this correct? and how would alter the mesh to make CSG work properly?
thanks
jim
Subject: Re: mesh CSG woes
Date: 2 Dec 2002 19:30:45
Message: <3debfb35$1@news.povray.org>
James,
I think mesh2 was designed to take care of this problem.  3DWin, PoseRay,
ObjUVPov and Pose2POV all support mesh2 and should convert the model for
you.  Make sure that inside_vector is specified.
autowitch
http://www.autowitch.org
"James Taylor" <jim### [at] blueyondercouk> wrote in message
news:3debeb87@news.povray.org...
> Hi all,
thought,
is
> thanks
> jim
Date: 2 Dec 2002 19:39:16
Message: <chrishuff-B554ED.19363002122002@netplex.aussie.org>
In article <3debfb35$1@news.povray.org>,
The mesh2 feature has nothing to do with it, it is just an alternate
syntax for the same object.
http://tag.povray.org/
Date: 2 Dec 2002 19:42:28
Message: <chrishuff-2CE69B.19394202122002@netplex.aussie.org>
In article <3debeb87@news.povray.org>,
The inside_vector feature will let POV determine "insideness" of a point
for well-behaved meshes, ones without open areas. There is a bug when
using it in differences as anything but the first object or when using
inverted meshes, otherwise it should work with a properly chosen
inside_vector.
Date: 3 Dec 2002 07:08:50
Message: <3dec9ed2@news.povray.org>
  It's good to read the section "6.5.2.3.1 Solid Mesh" of the POV-Ray
documentation for details.
Date: 4 Dec 2002 14:37:32
Message: <3dee597c$1@news.povray.org>
thanks, I'll take a look
jim
