POV-Ray : Newsgroups : povray.general : How to model a realistic rope ? Server Time
13 Jul 2026 08:01:56 EDT (-0400)
  How to model a realistic rope ? (Message 1 to 9 of 9)
Subject: How to model a realistic rope ?
Date: 13 Nov 2002 08:20:45
Message: <3dd251ad@news.povray.org>
I would like to know how to model a rope?
I have tried various combinations of interwined coils, but
the result is not realistic enough. Also, I would like to be
able to make the rope follow any path (e.g. a spline). So
basically, I need to figure out what an elementary part of
a rope could be modelled as, and then I can use a macro
to actually duplicate this elementary part along the path.
(much like one creates a hanging chain out of small links)
Cheers.
Maxime.
Subject: Re: How to model a realistic rope ?
Date: 13 Nov 2002 09:24:53
Message: <3dd260b5@news.povray.org>
hey!
you may want to try the new sphere_sweep feature.
hth,
florian
Date: 13 Nov 2002 09:38:47
Message: <3dd263f7@news.povray.org>
"Maxime Labelle" <max### [at] freesurffr> wrote in message
news:3dd251ad@news.povray.org...
I was going to point you over to Chris Colefax's web pages but I get a Not
Found for it. Just in case it works later or for you instead:
http://www.geocities.com/SiliconValley/Lakes/1434/
Date: 13 Nov 2002 09:53:02
Message: <3DD26757.42A14F5B@pacbell.net>
I have no problem accessing the site in question.
Ken Tyler
Date: 13 Nov 2002 10:04:59
Message: <kbq4tugdt5au92rah6s5qpledbqiuv4fa3@4ax.com>
On Wed, 13 Nov 2002 14:26:50 +0100, "Maxime Labelle"
http://news.povray.org/povray.binaries.images/21635/
ABX
Date: 13 Nov 2002 12:50:06
Message: <web.3dd28ffa9a38f71336f787750@news.povray.org>
OK, excellent.
Thanks to all.
>ABX
Date: 13 Nov 2002 12:56:07
Message: <3dd29237@news.povray.org>
Maxime <max### [at] freesurffr> wrote in message
news:web.3dd28ffa9a38f71336f787750@news.povray.org...
> OK, excellent.
> Thanks to all.
The disadvantage of the methods mentioned so far is that you will not be
able to easily map your rope texture onto the strands. I would suggest
building three mesh strands twisted together.
 -Shay
Date: 13 Nov 2002 15:21:28
Message: <3dd2b448$1@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3DD26757.42A14F5B@pacbell.net...
Same here... now. Thanks for checking, almost broke a sweat thinking Chris's
site had gone under.
Bob H.
Date: 14 Nov 2002 06:45:04
Message: <web.3dd38c3d9a38f71336f787750@news.povray.org>
Hi Shay,
OK, I understand.
As far as I'm concerned, my rope only has got one
texture applied to all threads, which is fine.
However, I couldn't find a way to make the rope
follow exactly a given path. There seems to be lacking
the bezier_spline type for a spline, although this
is available for a lathe object. Am I missing something?
In that case, how can I impose some tangents in some
predefined points to the the curve I want the rope
to follow.
> -Shay
