Hello everyone
I'm working on an image for the current IRTC stills round 'Frozen
Moment', and I'd like to indicate somehow that a particular object in
the scene is moving. Now, motion blur would probably be ideal for this,
but I'm using POV-Ray 3.5 and I'm not currently aware of any motion blur
patches for it. I could try moving to MegaPOV 0.7, but I'm not sure how
much of the scene I'd have to alter to make it compatible, and I don't
really want to have to go down that route if I can avoid it as it's
needless extra work.
So, are there any other ways to indicate movement of an object?
Unfortunately it's not one that has anything that flaps or trails behind
it. Or can one simulate motion blur with any reasonable expectation of a
half-decent effect?
Thanks
In article <3dcaf724$1@news.povray.org>,
> half-decent effect?
You could imitate it by using multiple transparent copies of the object,
which is how the patch actually did its work. I think transmit will give
the most correct results in this case. The original patch kind of
treated the body of the motion blur statement as the body of a loop, and
parsed it several times with different clock values. Just make sure to
set the max_trace_level high enough...
The only other way I can think of would be to somehow indicate the
object's motion by its effect on the rest of the scene, a rubber ball
with a falling stack of cans behind it for example. You really need
motion blur for a realistic effect...
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
Christopher James Huff wrote:
> You really need motion blur for a realistic effect...
Not in a perfectly "frozen moment"... ;)
Jaime Vives Piqueres
http://www.ignorancia.org
Depending on the render times, you can render multiple copies of your
scene with the object moving a little and then average them together.
The averaging part can be done in POV using image_maps and the average
pattern, so you can stay within the rules of the IIRC.
You can also only render the part of the scene where your object
appears, then use some clever (function-based, most likely) texturing
to paste it into POV - it all depends on your render times.
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] vip bg
TAG e-mail : pet### [at] tag povray org
Why not just post a screen shot of POV, with the 0 pph included? ;)
Tim Cook
Version: 3.12
Wrong. The patch did not add any transparency anywhere. It simply traced
the same object several times, transforming the object with the given
transformations at each sample, and then averaged the results.
This gives a lot more realistic result. Using semitransparent objects
will give you unrealistic results. For instance, using semitransparent
objects will make the interior of the object partially visible, which is
usually very unwanted.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
In article <3dcbd026@news.povray.org>, Warp <war### [at] tag povray org>
By "how the patch actually did its work" I was referring to the multiple
copies part, which *is* what the patch did. It didn't trace one object
multiple times, it traced multiple copies of the object.
Which is why I said "most correct" results instead of "correct" results.
Maybe I didn't make it clear enough, but this is just a way to imitate
the blur effect without a patch.
The practical difference being...?-)
What I meant was that it traces the object as-is, without modifying the
surface properties of the object (eg. making it partially transparent).
It's just that from your post one could get the idea that the suggested
solution is exactly what the MegaPov patch did but just internally and a
bit faster. It's not like that.
In article <3dcbddde@news.povray.org>, Warp <war### [at] tag povray org>
You could use it as a loop, and do other stuff besides simply
transforming the object. For example, you could make an isosurface
changing shape or a moving texture have motion blur, or even completely
change the type of object or remove some "copies" entirely. In normal
usage there was little difference, though.
Right, I didn't mean to imply that it did.
Hmm...I didn't intend that. Sorry.
Use those elements of composition that imply movement. An automobile
viewed head on in an orthographic projection in the exact center of the
image does **not** imply movement.
Avoid tacking blurring special effects.
"Matt Walton" <mat### [at] alledora co uk> wrote in message
news:3dcaf724$1@news.povray.org...
In article <3dcb8f48@news.povray.org>,
Hmm...in an animation, perhaps. Or if (as I mentioned before) there is
some other way of telling it is in motion, which can be pretty difficult
to do. Otherwise, it more often looks like the object is either hovering
or just sitting still...the motion blur is a valuable visual cue.
"Christopher James Huff" <chr### [at] mac com> wrote in message
news:chr### [at] netplex aussie org...
: In article <3dcb8f48@news.povray.org>,
: Jaime Vives Piqueres <jai### [at] ignorancia org> wrote:
: > Not in a perfectly "frozen moment"... ;)
: Hmm...in an animation, perhaps. Or if (as I mentioned before) there is
: some other way of telling it is in motion, which can be pretty difficult
: to do. Otherwise, it more often looks like the object is either hovering
: or just sitting still...the motion blur is a valuable visual cue.
: Christopher James Huff <cja### [at] earthlink net>
: http://home.earthlink.net/~cjameshuff/
: POV-Ray TAG: chr### [at] tag povray org
: http://tag.povray.org/
Some high-speed photography shows a truly frozen
moment, yet the motion is pretty clear to me without
motion blur:
http://www.rit.edu/~andpph/photofile-c/splash-4.jpg
=Bob=
In article <3dcc0579@news.povray.org>, "=Bob=" <bob### [at] threestrands com>
> motion blur:
Nice picture, but it quite clearly shows motion without blur. Not only
is it an image that is instantly associated with movement, you can see
that the droplets have just separated from the main body of the water.
Am I just not being clear enough? If you can use these elements (an
image that is associated with motion, or the past and current effects of
the motion on other objects) in your scene to show motion, motion blur
isn't necessary to get a sense of movement. It isn't always easy or
possible to do this though. I never said it was impossible to avoid
using motion blur.
And motion blur isn't cheating or unrealistic: the human eye is not a
high speed camera, what you see will be blurred. You can avoid blur for
an interesting effect like that image shows, but it won't be more
realistic.
Ok, I used the word "transformed", which was unambiguous in this case.
I meant that the object is generated with a new clock value for each
ray (as it would be done for each frame of an animation). Of course the
object can be modified in many other ways using the clock value besides
using transformations (ie. translate, rotate, scale...).
: In article <3dcc0579@news.povray.org>, "=Bob=" <bob### [at] threestrands com>
: wrote:
: > Some high-speed photography shows a truly frozen
: > moment, yet the motion is pretty clear to me without
: > motion blur:
: Nice picture, but it quite clearly shows motion without blur. Not only
: is it an image that is instantly associated with movement, you can see
: that the droplets have just separated from the main body of the water.
: Am I just not being clear enough?
I was agreeing with you...motion blur is not essential...
=Bob=
This is true, but we're generally used to seeing motion blur in
photography, and in my (admittedly limited) experience, a raytraced
image is usually interpereted as a photograph would be.
I've had another idea for how I can portray motion without using motion
blur, so I'll see how that works out.
