Remco made me aware of this astonishing fact in p.b.a. Here is a scene
file that makes it obvious.
A compact stack of 250 cylinders renders in 73 seconds.
A compact stack of 250 spheres renders in 6 seconds.
// Persistence of Vision Ray Tracer Scene Description File
// File: ?.pov
// Vers: 3.5
// Desc: Basic Scene Example
// Date: mm/dd/yy
// Auth: ?
#version 3.5;
global_settings {
assumed_gamma 1.0
location <0.0, 0.5, -4.0>
direction 1.5*z
look_at <0.0, 0.0, 0.0>
sky_sphere {
gradient y
color_map {
[0.0 rgb <0.6,0.7,1.0>]
[0.7 rgb <0.0,0.1,0.8>]
light_source {
<0, 0, 0> // light's position (translated below)
color rgb <1, 1, 1> // light's color
translate <-30, 30, -30>
plane {
y, -1
pigment { color rgb <0.7,0.5,0.3> }
blob{threshold 0.4
#declare n=0;
#while(n<250)
sphere {0,.4,1 scale <1,0.1,1> translate 0.005*y*n-0.5*y }
//cylinder {0,y,.4,1 scale <1,0.1,1> translate 0.005*y*n-0.5*y }
#declare n=n+1;
radial
frequency 8
color_map {
[0.00 color rgb <1.0,0.4,0.2> ]
[0.33 color rgb <0.2,0.4,1.0> ]
[0.66 color rgb <0.4,1.0,0.2> ]
[1.00 color rgb <1.0,0.4,0.2> ]
finish{
specular 0.6
I don't see what's so astonishing in this. One would expect that a more
complicated shape would render slower than a simpler one, and that's what
happened.
Of course the difference in speed is a bit large, but still not
astonishing...
Subject: Re: Spherical blob components render faster
Date: 2 Nov 2002 15:21:57
Message: <3dc433e5@news.povray.org>
"Greg M. Johnson" <gregj:-)56590@ao:-)l.com> wrote in message
news:3dc41962$1@news.povray.org...
Why is this astonishing? What did you expect?
Not only are cylinders harder to solve for, using more complex math, but
bounding is much less effective. An unscaled sphere always fills the
majority of its bounding box, a cylinder can fill a very small percentage.
And I think the blob components are sphere bounded, which would make
cylinders even less efficient. Of course they are slower...
I think it would be astonishing to presume that the average user would
know the internal workings of POV-Ray enough to come to the same
conclusion :)
Ken Tyler
Date: 2 Nov 2002 16:24:46
Message: <3dc4429e@news.povray.org>
"Ken" <tyl### [at] pacbell net> wrote in message
news:3DC### [at] pacbell net...
> conclusion :)
OK, point taken, but even without all that, it seems like it should be
expected that a more complex shape is going to be slower. Being "astonished"
at it seems very strange...am I missing some meaning and reading things too
literally?
> > conclusion :)
> literally?
From the average user vantage point I fail to see where a blob constructed
from cylinders is any more complex than a blob constructed from spheres.
After all, they are both simple basic shapes, are they not?
Ken Tyler
Date: 2 Nov 2002 20:09:05
Message: <3dc47731@news.povray.org>
"Christopher James Huff" <cja### [at] earthlink net> a écrit dans le message
de news: 3dc4429e@news.povray.org...
> > conclusion :)
"astonished"
too
> literally?
It's just that for the layman a cylinder is not a more complex shape than a
sphere. Even for a non-layman in fact... Both equations are very similar
after all. I don't dispute the fact that it's computationally more
expensive, but the difference in rendering time reported by Greg is really
big (x 10 !!!).
G.
http://www.oyonale.com
- Graphic experiments
- Posters
news:3DC46EBA.AC7C405A@pacbell.net...
exactly.
Date: 2 Nov 2002 22:43:57
Message: <3dc49b7d@news.povray.org>
"Gilles Tran" <git### [at] wanadoo fr> wrote in message
news:3dc47731@news.povray.org...
a
> sphere.
Hmm...maybe I'm just looking at it differently, but having two spherical
caps and a cylinderical section seems intuitively more complex than a
sphere.
> after all.
And for an isosurface function with axis-aligned cylinders, a cylinder
function is simpler...understandable confusion there. There are other
complications in the case of blob components which I don't expect "laymen"
to understand, but isosurfaces are more of an advanced user feature anyway.
> big (x 10 !!!).
That did catch me off guard, it seemed suspicious until I took bounding into
account, which I don't expect the average user to think of. The fact that
one is slower than the other just seems pretty expected to me, I'd be very
surprised if any two primitives were exactly the same as far as speed, and
without looking at the math I'd guess that the cylinder is the slower one.
An idea: use "hierarchy off" and compare the speeds then...it should
eliminate the bounding differences, leaving only the blob calculation
differences. If my guess is right, the sphere component blobs will slow down
more than the cylinder component ones, bringing them closer to equal.
On Sun, 3 Nov 2002 10:47:49 -0500, "Christopher James Huff"
>sphere.
It's not two caps and a cylinder, actually. It's just that the
distance function used computes the distance to a segment, 's all.
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] vip bg
TAG e-mail : pet### [at] tag povray org
Date: 3 Nov 2002 09:30:42
Message: <3dc53312$1@news.povray.org>
"Peter Popov" <pet### [at] vip bg> wrote in message
news:4c0asug9885shf979rnrq15pmtksuj117g@4ax.com...
I know the mathmatical definition of the function, but if I'm reading the
code correctly, it *is* a cylinder section and two hemispheres as far as the
intersection code is concerned, and that's what it looks like to someone who
doesn't know the math.
> > It's just that the
The two are mathematically equivalent anyway. I couldn't think of any way of
calculating the former without using the latter.
- Slime
[ http://www.slimeland.com/ ]
Date: 3 Nov 2002 11:39:40
Message: <3dc5514c$1@news.povray.org>
"Slime" <slm### [at] slimeland com> wrote in message
news:3dc550bd$1@news.povray.org...
of
Right, it's the method I used for the cylinder component of my new blob
pattern patch. I don't see any other way to do it.
I had figured out long ago that it was distance to a line segment. It is
just wacky that there's a 10x difference. I'm creating a smooth blobman jaw
with 30+ blob components and was shocked. at the render difference.
"Christopher James Huff" <cja### [at] earthlink net> wrote in message
news:3dc53312$1@news.povray.org...
the
who
Well, if you think about it: What is the function which returns the
distance to a point? And the function which returns the distance to a
line segment (which is a bit more complicated than the distance to a line)?
