POV-Ray : Newsgroups : povray.general : Version 0.1 of my Ray Tracer released Server Time
2 Nov 2026 18:47:28 EST (-0500)
  Version 0.1 of my Ray Tracer released (Message 1 to 28 of 28)
Subject: Version 0.1 of my Ray Tracer released
Date: 24 Oct 2002 16:09:00
Message: <3db8535b@news.povray.org>
Finally I got my little ray-tracer to a stage where I think that releasing
it to the public could make sense. Its web home is at
 http://www.povworld.org/raytracer/
You find there the (more or less well commented) source and a more detailed
description of its features with some example pictures. You can also have a
look at the API there. The ray-tracer is written in C++. It comes with some
features that I would like to see in a future version of POV-Ray.
Note that this is a realease for programmers only. The ray tracer does not
come with a parser so the only way to create new scenes is by programming
them. That is also why providing pre-compiled binaries does not make much
sense.
If there is enough interest in discussing about the source code or further
developping of it I can set up an appropriate communicating media. Maybe
this project is interesting for you if you are not familiar with the POV
3.5 code, you prefer object-oriented programming and you do not want to
wait for POV-Ray 4 to come out of the planing stage.
Feature List:
# Object
    * Box
    * Sphere
    * Plane
    * ''fast'' Isosurface using polynom-extrapolation
# Bounding Boxes
    * Hierarchy
# CSG
    * Union
    * ''fast'' Merge and Intersection, speed in the same order as union
    * CSG copy by reference
# Pigment
    * Patterns
    * Pigment Maps
    * Camera-is-a-Pigment principle
# Texture
    * Phong
    * Transparency
# Media
    * absorbing, emitting, scattering
    * Density Mapping
    * ''fast'' Media using advanced integration technique and light cache
      (experimental!)
# Light Source
    * Point Light
# Output
    * Write to PPM format file
As said you find some more info on
http://www.povworld.org/raytracer/features/.
Happy programming!
- Micha Riser
objects.povworld.org - The POV-Ray Objects Collection
book.povworld.org    - The POV-Ray Book Project
Subject: Re: Version 0.1 of my Ray Tracer released
Date: 24 Oct 2002 16:18:23
Message: <3db8558e@news.povray.org>
How about some example images and their render times?
Date: 24 Oct 2002 16:26:21
Message: <3db8576d@news.povray.org>
There are example images on:
http://www.povworld.org/raytracer/node6.html
http://www.povworld.org/raytracer/node12.html
http://www.povworld.org/raytracer/node16.html
http://www.povworld.org/raytracer/node21.html
For the render times: If you compile the source you get a binary which can
make the scenes showed on the pages above.. so you can see yourself.
Date: 24 Oct 2002 16:55:41
Message: <3db85e4d$1@news.povray.org>
None of the links work.
Cheers!
Chip Shults
Date: 24 Oct 2002 16:56:53
Message: <3db85e95@news.povray.org>
Sorry, I got the links wrong, should be:
 http://www.povworld.org/raytracer/features/node6.html
 http://www.povworld.org/raytracer/features/node12.html
 http://www.povworld.org/raytracer/features/node16.html
 http://www.povworld.org/raytracer/features/node21.html
Date: 25 Oct 2002 06:16:09
Message: <3db919e9@news.povray.org>
Cool... Someone else has done this...
I have also made a raytracer - in Java of all things! (Well, the original
was made with Smalltalk - but who else actually has that?) Again, the only
way to make it render things is to write [miles of] Java code to generate
the appropreate datastructures. I suspect my little effort isn't nearly as
full-featured as yours - but then, I had to reinvent raytracing from first
principles! Considering I've never had a propper algebra lesson in my entire
life, I'm pretty dam impressed I got the ray/shape intersection tests to
work at all!!! (Actually, waaaaay back I tried emailling one of the POV-Team
members about the math, but never got an answer. Hardly suprising - they
probably get daft emails like this every second wednesday...)
It's currently on my webpage. I won't go into features, URL, etc unless
someone else is actually interested. (Unlike yours, mine doesn't do anything
new that POV-Ray doesn't do.)
Andrew.
PS. Isn't building a raytracer with OOP so confusing? Which kind of "object"
are you talking about... ;-)
PPS. If I were God, POV_Ray's SDL would be object-oriented (in the
programming sense).
Date: 25 Oct 2002 09:43:59
Message: <chrishuff-BF6127.09371925102002@netplex.aussie.org>
In article <3db919e9@news.povray.org>,
You mean your original raytracer? Because "the original" raytracer was a
piece of twine. ;-)
If you mean your original, it sounds interesting...I've always been
interested in Smalltalk. I know of another raytracer written in
Objective C, which is basically a halfway point between Smalltalk and C.
> Again, the only
Try a post on one of these newsgroups, maybe advanced-users.
Do what I did for my tracer: physical things are "shapes", objects are
bundles of information/behavior. Gets rid of the ambiguity nice and
neatly.
> programming sense).
It already comes close in some ways. I think it could be made into a
prototype-based OO language with little modification.
http://tag.povray.org/
Date: 25 Oct 2002 11:43:58
Message: <3db966bd@news.povray.org>
Actually I have written it in Java first as well - I needed to learn java
for my study. But it was a factor 3-10 slower than the c++ version.
> entire life, I'm pretty dam impressed I got the ray/shape intersection
While I already had algreba courses I pretty figgured out all the
neccessary transformations for ray tracing myself... The nice thing was
that when I came to think about how isosurfaces and volumetric media works
I could perfectly make usage of the root finding and numerical integration
techniques that I had been taught just before.
Actually I just today started having a graphic course which will bring me a
bit deeper into the things and algorithms behind rendering.
> "object" are you talking about... ;-)
Well, I called the objects' base class 'Object3D'. When you are talking of
'classes' and 'instances' about OOP there is no name conflict.
- Micha
Date: 25 Oct 2002 12:08:16
Message: <3db96c70@news.povray.org>
original
> piece of twine. ;-)
<groans>
Yes, I ment *my* original. And actually, it's just occurred to me - the
*very* _first_ prototype of it was actually done with Borland's Turbo Pascal
5.5 for DOS. (Anyone remember that ol' thing?)
C hurts my head. I tried to make an interpreter for my own OOP language that
I designed... But pointers to arrays of pointers to pointers to functions is
just _not_ fun.
Mmm... will maybe do that sometime... although it's not strictly
POV-related...
"object"
> neatly.
The way my tracer works, a "shape" described the 3-dimensional form of an
object; a "texture" basically maps points to surfaces, and a "surface"
described the object's surface characteristics. (I.e., by the wonder of
polymorphism, subclasses of Surface implements light-sourcing, reflection,
refraction one day, etc.) And "object" itself is the combination of a shape
and a texture. So anyway, I just renamed it to "item"... (Java doesn't like
you declaring classes called "Object"; could have done "Object3D" or
something, but "Item" is less typing ;-)
> > programming sense).
I thought about writing some sorta thingy that would parse an input file in
my own custom-designed language, and spit out a result in ordinary POV-Ray
SDL. But I don't understand POV-Ray's SDL well enought to do it. (Ahhhh...
tell the trueth: you can't write a parser to save your life! :-(
Andrew.
Date: 25 Oct 2002 12:11:18
Message: <3db96d26@news.povray.org>
I'll bet! (The speed part, that is.) Don't like Java much, but it's the only
way to reach a larger audience...
a
Ah, now we did do a term studying computer graphics... Everyone thought the
guy was joking when we said our assignment was to write a program to draw an
antialiased STRAIGHT LINE using Bresenham's Algorithm... Ahh, memories...
(What am I on? It was only 5 months ago!)
Yeah, but Java has a class called "Object". Like you say, "Object3D" would
work fine; I chose "Item" instead - it works better in English as well as in
code...
Andrew.
Date: 25 Oct 2002 12:13:22
Message: <g8riru41dlu3qjg65sjkpg5oltp42i03n9@4ax.com>
On Fri, 25 Oct 2002 17:08:09 +0100, "Andrew Coppin" <orp### [at] btinternetcom>
I don't remember version but that was my first tool for renderings too.
ABX
Date: 25 Oct 2002 15:54:47
Message: <chrishuff-E5BC90.15480825102002@netplex.aussie.org>
In article <3db96c70@news.povray.org>,
> just _not_ fun.
I know what you mean...I just finished redoing the memory management for
G. It now uses some pretty low level pointer magic to use the same
memory block as both stack and data space, function calls have very
little overhead now, but my brain is pretty well fried. The STL helps
sometimes, but in this case a more specialized structure was needed.
> POV-related...
Not POV specific, but raytracing related...post in the programming or
advanced users groups.
My raytracer has a Tracer object instead to manage things, shapes are
mainly concerned with geometry, and it uses a tree of objects to
evaluate the texture.
Thats what CSDL (now Sapphire) was originally supposed to be, just a
translator. The first name was CSDL, for C-like Scene Description
Language, then C-like Simulation Description Language, and then Sapphire
because it isn't limited to either of those and I didn't like the
acronym.
Date: 25 Oct 2002 20:54:22
Message: <3DB9E7FB.ECE938C3@pacbell.net>
> acronym.
http://www.perl.com/pub/a/2000/09/sapphire.html
Ken Tyler
Subject: Sapphire (was: Re: Version 0.1 of my Ray Tracer released)
Date: 25 Oct 2002 22:52:53
Message: <chrishuff-367DC1.22461525102002@netplex.aussie.org>
In article <3DB9E7FB.ECE938C3@pacbell.net>, Ken <tyl### [at] pacbellnet>
Uh-oh...and I was pretty sure the name wasn't taken. I did find out
about some kind of audio editing/generating tool called Sapphire, but it
seemed unrelated enough to not matter. This seems to be a specific
implementation of the Perl API instead of a language...any opinions?
Date: 25 Oct 2002 23:05:04
Message: <3DBA080B.C7088E3@comcast.net>
Kids these days...5.5?  That's kinda late.  I've still got a
copy of version 2 around here somewhere - probably on 5 1/4" floppy.
That's ONE floppy mind you.
And, yes, I had a raytracer I wrote in it too...
Still have it! Originally ran it on a 8Mhz 286.  One scene I gen'd
had 48 glass triangles and took over 80 hours to render at 320x200
on a 20Mhz 386. (Compaq 386 20E)
Guess I'm showing my age...;)
Emory
> ABX
Subject: Re: Sapphire (was: Re: Version 0.1 of my Ray Tracer released)
Date: 26 Oct 2002 01:21:15
Message: <3dba264b@news.povray.org>
Keep the name. It's cool, and there must be hundreds of projects with the
same names.
Anthony
Date: 26 Oct 2002 05:01:48
Message: <3DBA59FD.1090606@ibras.dk>
It seems like most common stones have already been used.
You can check http://www.astrogallery.com to see if you can find some
stone name that hasn't been used for a language project yet.
How about "Schorl"? It doesn't sound like something that is likely to
have been used :)
/Ib
Date: 26 Oct 2002 17:37:51
Message: <chrishuff-2891FB.17310926102002@netplex.aussie.org>
In article <3DB### [at] ibrasdk>, Ib Rasmussen <ib### [at] ibrasdk>
By languages?
> have been used :)
Eh, no thanks.
If this other "Sapphire" is too close, maybe I'll rename it after a
metal...Copper, Iron, Cobalt. Lithium might be a good choice for one of
the "esoteric" languages. Carbon is already used for a common API,
Mercury is probably taken. Or just a substance: Glass (maybe for my VR
simulator). Or maybe a scientific/math constant:
C already exists of course...speed of light in a vacuum.
Pi is obvious.
E
Maybe "V" instead of "G" for my second language, it is going to have
very good support for vector math. (it already fully supports 3D
vectors, it will eventually support vectors of any size)
Maybe "mongoose". (they kill snakes)
Maybe I should make 4 languages named after the 4 elements: earth, air,
fire, and water.
Date: 26 Oct 2002 18:14:37
Message: <3dbb13cc@news.povray.org>
Hmm. Come to think about it, there are pretty good candidates amongst star
names. These are from the apparent brightness Top 20 list:
 Vega, Capella, Rigel, Procyon, Agena, Altair, Acrux, Spica, Antares,
 Deneb, Mimosa...
Or constellations:
 Carina, Lyra, Aquila, Crux...
Or perhaps asteroids (most of these, as well as the names of other
planetary bodies in the Sol system, come from Greek or Roman
mytology):
 Ceres, Pallas, Vesta, Hygeia, Juno...
Or maybe a single Greek letter:
 Zeta, Eta, Lambda, Mu, Xi, Rho, Tau, Phi...
-Johannes
Date: 26 Oct 2002 19:30:57
Message: <3dbb25b1@news.povray.org>
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
> fire, and water.
   Just call it 'Element'
     ~Steve~
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Date: 26 Oct 2002 21:28:58
Message: <chrishuff-C257E7.21221726102002@netplex.aussie.org>
In article <3dbb13cc@news.povray.org>,
>  Deneb, Mimosa...
I actually considered an astronomical body...you have a better list than
mine.
Mu is also Chinese for "nothing", if I remember right...I'll use that
for my mind-reading compiler.
Aleph would also be good, the only thing close is the open source game
AlephOne.
Date: 27 Oct 2002 04:47:10
Message: <3dbbb61e$1@news.povray.org>
>> fire, and water.
...or "LMN-t" (= "El-em-en-t") ;)
Ignacio Fernández Galván
Linux User #289967 (counter.li.org)
PGP Pub Key ID: 0x01A95F99 (pgp.escomplinux.org)
Date: 27 Oct 2002 09:08:55
Message: <3dbbf377@news.povray.org>
> >> fire, and water.
Oooo, cleaver 8^D
Date: 27 Oct 2002 11:27:54
Message: <3dbc140a$1@news.povray.org>
"Jellby" <jel### [at] M-yahoocom> wrote in message
news:3dbbb61e$1@news.povray.org...
> >> fire, and water.
        Nice! I like that better!  :)
      ~Steve~
Date: 27 Oct 2002 11:35:39
Message: <3DBC159E.A377DA7F@pacbell.net>
I didn't mean to start a renaming contest. After a thorough read of that
page it looks like the guy did that programming over 2 years ago and it
was done mainly as an exersize rather than as practical end use product.
Were I you I would try to contact the guy who wrote the perl Sapphire routine
and ask if he minds you using the name. Personnaly I kinda like the name
Sapphire, and no offense to those who have offered alternatives, I still
like it the best.
Ken Tyler
Date: 27 Oct 2002 17:10:38
Message: <3dbc645d@news.povray.org>
>> >> air, fire, and water.
> Oooo, cleaver 8^D
Not really, it's one of the hypotheses for the origin of the word "element".
From www.dictionary.com:
[Middle English, from Old French, from Latin elementum, perhaps ultimately
from lmn, first three letters of the second half of the Canaanite alphabet,
recited by ancient scribes when learning it.]
Date: 6 Dec 2002 14:07:59
Message: <chrishuff-4A50C5.14045306122002@netplex.aussie.org>
In article <3DBC159E.A377DA7F@pacbell.net>, Ken <tyl### [at] pacbellnet>
> like it the best.
Took me a while to get around to it, but I contacted him and he has no
problem with my using the name Sapphire.
Date: 7 Dec 2002 13:38:16
Message: <3DF2407D.A6F94678@pacbell.net>
A happy ending.
Ken Tyler
