POV-Ray : Newsgroups : povray.general : Asking for suggestions... Server Time
22 Oct 2026 17:34:56 EDT (-0400)
  Asking for suggestions... (Message 1 to 5 of 5)
Subject: Asking for suggestions...
Date: 20 Oct 2002 16:58:17
Message: <3db318e9@news.povray.org>
Most of you know that I'm creating a lot of noise generator features. I've
created a new syntax for these:
noise_generator {
 4
 slice 10
 repeat 20
 match_second_derivatives on
This works great for patterns.
I realized, though, that people will want something to replace
f_noise3d(x,y,z). So I figured the best solution to this would be to create
a noise_generator function type:
function my_noise_gen {
 noise_generator {
  4
  slice 10
  repeat 20
which could later be used like my_noise_gen(x,y,z).
I've spent most of today turning the noise generator into an actual object
so that I should be able to do this next. However, one problem remains:
internal functions. These functions (like f_ridged_mf) currently take a
noise generator *number* as an argument. However, this makes it impossible
to use the extra features.
So what I need is some sort of syntax to let the user decide what noise
generator to use with an internal function. I can't come up with anything.
Any suggestions?
 - Slime
[ http://www.slimeland.com/ ]
Subject: Re: Asking for suggestions...
Date: 20 Oct 2002 17:05:08
Message: <3db31a84@news.povray.org>
>  noise_generator {
>   4
>   slice 10
>   repeat 20
Heh, this should be
#declare my_noise_gen = function {
My brain was in Javascript mode. =)
 - Slime
Date: 20 Oct 2002 19:11:02
Message: <chrishuff-B4984F.19061520102002@netplex.aussie.org>
In article <3db318e9@news.povray.org>, "Slime" <slm### [at] slimelandcom>
> Any suggestions?
Maybe we should collaborate. I want to completely redo the noise
generator syntax, and dump the existing noise_generator code entirely
(it is too hard to make additions and extensions).
#declare Perlin =
function {perlin_noise {NOISE_GENERATOR_STUFF}}
#declare OldNoise =
function {old_noise {rescale on|off NOISE_GENERATOR_STUFF}}
#declare Lewis =
function {
    lewis_noise {
        cos|cone|scurve|function
        impulses NUM_IMPULSES
#declare Perlin4D =
function {
    perlin_4d_noise {
        slice TIME_PARAM
NOISE_GENERATOR_STUFF would be:
seed SEED
For creating generators with different seeds.
range MIN, MAX
For setting the output range. Default would be either [-1, 1] or [0, 1].
To use a declared generator:
#declare val = Perlin(1, 2, 3);
#declare val = Perlin4D(1, 2, 3);
#declare val = Perlin4D(1, 2, 3, 4);//slice parameter overridden
pigment {bozo noise_generator Lewis}
function {OldNoise(x, y, z)}
You wouldn't need to declare it:
pigment {bozo noise_generator lewis_noise {...}}
Oh, and any function could be used as a noise generator:
pigment {bozo noise_generator function {pow(sin(Lewis(x, y, z)), 2)}}
I think this could be pulled off without breaking existing scenes.
No scenes depended on the discontinuous second derivatives, so that
option would be removed (or the old function could be kept as a faster
option). Don't know what to do about the repeating. It'd be nice if it
could be done for all the generators without slowing them down.
http://tag.povray.org/
Date: 21 Oct 2002 15:48:51
Message: <3db45a23@news.povray.org>
Hmm, I like some of these things you propose, and I don't like some of them.
You seem to want to bypass the noise_generator keyword altogether.
Personally, I think that it's a good idea to keep it as a middleman. Here's
what I have working right now:
#declare mynoisegen = noise_generator {
 3
 match_second_derivatives off
#declare mynoisegenfunc = function {
 noise_generator{mynoisegen}
sphere {
0,1
function {mynoisegenfunc(x,y,z)}
Notice how noise generators are an object that can be declared like any
other, and passed as macro parameters, etc. On a related note, anyone
interested in making fun of me may want to read my last night's blog entry
about the implementation of this ( http://www.slimeland.com/ ).
> seed SEED
Well, the way the noise generator code works now, the random values are
predetermined when POV-Ray starts up. This makes things a lot faster than if
they were being calculated on the fly: they're merely pulled out of an
array. So I don't think specifying an alternate seed is really a good
option... unless perhaps it were done via a command line parameter or
something...
Anyway, to be honest, my patch was originally just going to be a couple of
bugfixes so that I could do something that POV-Ray's limitations were
preventing me from doing. Now that I've fixed the bugs and made a couple
workarounds, I'm anxious to finish the patch and get back to regular POVing.
Maybe you'll want to download my source code when I release it.
 - Slime
Date: 21 Oct 2002 17:10:42
Message: <chrishuff-62CDCA.17043521102002@netplex.aussie.org>
In article <3db45a23@news.povray.org>, "Slime" <slm### [at] slimelandcom>
I'm not surprised. :-)
No, look at the later examples. The noise_generator keyword is used to
set the noise generator for patterns (and potentially other noise-using
things). It just seemed kind of redundant to use it for every kind of
noise generator functions.
My first syntax idea had the outer "function {}" block eliminated, which
would be very similar to that. It fits in with the other special
functions more this way.
Neither version has more capabilities, just the amount of typing.
> something...
The values would be calculated when the noise generator was created, it
wouldn't slow anything down but parsing, and that wouldn't take long.
I've done this in my own tracer, and it works fine.
Alright.
