POV-Ray : Newsgroups : povray.general : FEATURE REQUEST: Exclude light Server Time
2 Nov 2026 19:43:00 EST (-0500)
  FEATURE REQUEST: Exclude light (Message 1 to 22 of 22)
Subject: FEATURE REQUEST: Exclude light
Date: 13 Oct 2002 22:41:46
Message: <3daa2eea@news.povray.org>
I was reading the 1996 edition of Digital Character Animation.   They made a
passing remark that implied that the major 3D packages then all had the
ability to turn off light interactions with individual objects.  I request
this for povray because:
1) I saw an inference that the big guys had it in 1996.
2) The book pointed it as having some utility in faking radiosity.
3) It would allow me to do 2D toons, by cranking up the specular reflection
to max.
Subject: Re: FEATURE REQUEST: Exclude light
Date: 13 Oct 2002 23:31:32
Message: <chrishuff-658EAD.23263213102002@netplex.aussie.org>
In article <3daa2eea@news.povray.org>,
Ever hear of light groups?
http://tag.povray.org/
Date: 14 Oct 2002 08:54:41
Message: <3daabe91$1@news.povray.org>
cool.  What'll they think of next?
Perhaps an example of this should go into that exhaustive and useful web
page of pov features (Christoph's??).
Perhaps an example scene file (perhaps even showing off cartoony effect
possible with specular 10000)  should be added to example scenes.
I may work on the latter, if just for my own fun...
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
Date: 14 Oct 2002 09:13:49
Message: <3DAAC30C.5700ED17@gmx.de>
What? My web page exhaustive? Probably only in terms of server space...
I never actually used light groups so i'm probably the wrong person to ask
for a tutorial on that.
There is a light groups sample scene in the distribution BTW.
Date: 14 Oct 2002 23:55:03
Message: <web.3dab9116ee9636d5d02c7b870@news.povray.org>
On the topic of lighting, here's an idea for something to include in the
next version: Negative Lighting.
What this negative lighting would do is, it would make the texture
dark/transparent where it is hit by light, and bright in shadow. This would
be handy for making special effects, or for lights on the nightside of a
planet. In the case of the nightside lights, it would be a lot easier than
having to use objects for the different sides of the planet.
The option for using negative lighting would be something like this:
sphere{<0,0,0> 2
  pigment{
    image_map{
      png "nightlights.png"
      map_type 1 // I think that's spherical mapping
    negative_light on
I don't know what kind of special effects could be made using this, but you
did include no_image, no_reflection, no_shadow, etc, and they can be used
to make special effects.
Rohan _e_ii
Date: 15 Oct 2002 00:15:57
Message: <3dab967d@news.povray.org>
You mean like
light_source {
  Position,
  rgb -1
Try it. Make sure to have some positive light sources, or full ambient
lighting.
 - Slime
[ http://www.slimeland.com/ ]
Date: 15 Oct 2002 05:44:45
Message: <3dabe38d$1@news.povray.org>
"Slime" <slm### [at] slimelandcom> wrote in message
news:3dab967d@news.povray.org...
> light_source {
>   Position,
>   rgb -1
> lighting.
Nope, sorry, doesn't work exactly right unfortunately. Shadows aren't
correct. This just came to my attention recently and before that I had never
noticed a problem using negative light source colors. So, I don't know if
something changed or I just had not seen a shadow of one under the right
circumstances. I've used positive and negative lights in v3.1 media without
any apparent problem, although I can't remember what shadows there might
have been from them.
That would mean a reworking of light sources to correct this problem (which
isn't one, being outside the usual usage).
Date: 15 Oct 2002 08:46:42
Message: <3dac0e32@news.povray.org>
>>lighting.
> correct.
If I may ask, how do you tell if shadows are correct or not with
something that cannot exist in nature?  There is no such thing as
a negative light source, except perhaps a black hole, which emits
its own radiation.
Tim Cook
Version: 3.12
Date: 15 Oct 2002 09:27:48
Message: <3dac17d4$1@news.povray.org>
"Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote in message
news:3dac0e32@news.povray.org...
> > correct.
> its own radiation.
In the context I meant it would just be anti-light for POV scenes, light
subtraction. No shadowing, only removal of positive color light. I guess if
negative lights were to do as expected of such a thing, though, then they'd
actually illuminate shadows, or be a anti-shadow. They currently don't do
either I think. But as they are now it does subtract positive color lights
and ambience from the scene, except for strange artifacts left in the shadow
regions I guess.
Far as reality goes...?
I suppose some analogy could be made to the wave properties of light. Black
holes don't really shine outward, they vacuum inward and remove ordinary
light, but the interfering waves of regular light can diminish the photons
in regions.
Although you could set up a series of positive color area-spotlights to get
some bright and dark boundaries, a negative color light can counteract
within the same area-spotlight instead of needing masking objects and such.
More of a CSG for light sources idea than anything else perhaps.
Date: 15 Oct 2002 10:24:23
Message: <chrishuff-5C6A48.10192915102002@netplex.aussie.org>
In article <3dac17d4$1@news.povray.org>,
 "hughes, b." <omn### [at] charternet> wrote:
> I guess if negative lights were to do as expected of such a thing,
> though, then they'd actually illuminate shadows, or be a anti-shadow.
Why? Ordinary lights don't darken shadows, they just fail to illuminate
them.
> But as they are now it does subtract positive color lights and
> shadow regions I guess.
What artifacts? Shadowed areas are shadowed from the "antilight" just as
they are from light.
Date: 15 Oct 2002 11:19:05
Message: <3dac31e9$1@news.povray.org>
> them.
I'd say a logical anti-light would illuminate the shadow regions, behaving
exactly opposite of a regular light. I think know what you're saying though,
that non-light doesn't mean illumination of any sort.
I'll post an example of what I see as a problem with shadows when a pair of
lights, one positive color, other negative color, are shone upon an object
and the shadow created by that. See p.b.i., if you will, please.
Subject: Re: my error, not POV's
Date: 15 Oct 2002 11:50:00
Message: <3dac3928@news.povray.org>
I was too quick to judge the so-called problem until I went and did an
example of negative lighting again. It was a case of my bad perception with
something I didn't check into too far.
Posted the image file to p.b.i anyway.
Date: 15 Oct 2002 12:25:23
Message: <3dac4172@news.povray.org>
> subtraction.
  Well, regular light sources cause 0 lighting to shadows. What is the
negative of 0?
  That's right: 0. :)
Date: 15 Oct 2002 12:30:05
Message: <3dac428c$1@news.povray.org>
  A logical anti-light would not work that way. A logical anti-light
substracts light from its surroundings (light which is casted by regular
light sources). That is, they act as negated light sources.
  Regular light sources have no effect whatsoever on shadows. Negating
the effect of doing nothing is still doing nothing (it's the same in
math and in logic: -0 = 0; if you haven't done anything, there's nothing to
undo, so you still do nothing).
  Thus, a POV-Ray light source with negative color works very well as
a logical anti-light.
Date: 15 Oct 2002 14:28:37
Message: <3dac5e55@news.povray.org>
news:3dac428c$1@news.povray.org...
behaving
I can agree with that, yes. But I have to look differently at the way it
works to get your point about that. I was thinking of a light source as
being the controlling factor of shadows, i.e. have light, have shadow. If
ignoring the existence of radiosity anyhow.
So in that way I was thinking of it as shadows being areas non-illuminated
by regular (positive color) light and illuminated by negative color light.
Although that idea is actually different than what I really expect POV
should do anyhow, I was only wondering what such a thing might be like were
negative lights worked into the program source code.  Affecting shadows in
that way could be interesting, and I'd guess potentially problematic to work
with transparency, to name one of many things.
Anyway, I can see now that negative values for lights do what they should.
That being, subtracting positive light and not affecting shadows (where no
light appears).
Date: 15 Oct 2002 16:22:10
Message: <3dac78f1@news.povray.org>
> them.
This brings Terry Pratchett to my mind. Normal darkness is just the absence
of light, but Discworld Darkness is negated light :D
OK, there are at least two ways of thinking about negative lights. If normal
lights lighten illuminated zones and don't affect shadows, negative lights
could:
1.- Darken "illuminated" zones, don't touch shadows. (This is the most
logical approach)
2.- Lighten shadows, don't touch illuminated zones. (It has its logic too,
don't you think so?)
Is there a way to achieve the second way in POV-Ray? If there isn't (and if
there's any chance of implementing it someday), I suggest calling it
"inverted" light.
Date: 15 Oct 2002 16:45:13
Message: <3dac7e59$1@news.povray.org>
Perhaps a shadowless light projected_through the union of the entire scene,
but then it'd have the side effects of shadowless lights (no specular
reflection, a few other things).
 - Slime
Date: 16 Oct 2002 08:22:50
Message: <3DAD5A23.60203@free.fr>
>>them.
> could:
> logical approach)
> "inverted" light.
You are thinking about 'positive' and 'negative' light source as the
only way to touch the image.
You are forgetting 'Ambient' settings.
For:
  1. Do not touch ambient, add negative light
  2. add negative light and compensate the negative light with a raise
of ambient light. It might be tricky if many textures have different
ambient ratios.
Date: 16 Oct 2002 08:30:14
Message: <3dad5bd6$1@news.povray.org>
You can already do this with the 'projected_through' option for lights.
-tgq
Date: 16 Oct 2002 15:59:00
Message: <3dadc503@news.povray.org>
>> normal lights lighten illuminated zones and don't affect shadows,
>> negative lights could:
>> logical approach)
>> too, don't you think so?)
> For:
> ambient ratios.
The problem with ambient is that it's object-based, and not
light-source-based.
I like the 'projected_through' option better (I had forgotten about it). I
don't know if it would be really practical, but that's the idea, I think.
Anyway, I was just brainstorming, I'm not planing on using these 'inverted'
lights or anything, it's just that the idea came to my mind.
Jellby
Date: 21 Oct 2002 22:30:04
Message: <web.3db4b7d5ee9636d518ccf4f70@news.povray.org>
I've just tried using light groups and negative rgb values for the lights,
and it does work. The problem with what I was trying, was that I didn't
realise at the time was that the dark spots (from the texture used) would
obscure parts of the lower sphere.
A better soloution would be "transparency lighting". By using the
appropriate keyword in the pigment{} code, the texture becomes more
transparent with more light. Now this would be best for creating nightside
lights.
sphere{<0,0,0> 2
  pigment{
    image_map{
    transparent_light transmit 0,1
    // or use this for filter transparency
    // transparent_light filter 0,1
"transparent_light" - keyword for using transparent light
transmit/filter - transparency method to use
0,1 - transparency for no light, full brighness (e.g. 0.5,0.9 gives 50%
transparency in full darkness, and 90% transparency in full light)
This could be handy for creating special effects. In the case of the
nightside lights, they would fade in over the terminator, and be full
brighness on the dark side of the Earth. I think this is what you would see
looking at the terminator of Earth at night, the lights getting brighter as
it gets darker, as more people start turning on their lights.
Rohan _e_ii
Date: 22 Oct 2002 00:04:57
Message: <3db4ce69@news.povray.org>
"Rohan Bernett" <rox### [at] yahoocom> wrote in message
news:web.3db4b7d5ee9636d518ccf4f70@news.povray.org...
Got to use a widespread transparency if the image doesn't have sharp
boundaries of color.
Interesting idea, yeah. Same thing for shadows might also be useful. At
least I can't think of any reasons for not having such a feature, at the
moment anyway.
