POV-Ray : Newsgroups : povray.general : Formula please Server Time
22 Oct 2026 18:19:30 EDT (-0400)
  Formula please (Message 1 to 7 of 7)
Subject: Formula please
Date: 1 Oct 2002 12:30:37
Message: <3d99cdad@news.povray.org>
Can anyone give me a formula for an isosurface consisting of a y plane with
ripples emmanating from a central point with the ripples growing wider apart
as they get further from the center. I spent some hours on it but its beyond
my math I'm afraid :-(
Mick
Subject: Re: Formula please
Date: 1 Oct 2002 12:51:46
Message: <3d99d2a2$1@news.povray.org>
#version 3.5;
#include "functions.inc"
 location < 0,20,45>
 look_at < 0, 0, 0>
light_source {<50,5,0> color White}
light_source {<-50, 150,-75> color White*0.35}
background { color <0.094,0.184,0.337> }
#declare arrr=function{pow((pow(x,2)+pow(z,2)),0.25)}
isosurface {
 function {y- sin(0.1+100/arrr(x,y,z))}
        threshold 0
 max_gradient 1.05
 contained_by{ box {-100,100}}
        accuracy      0.0001
 pigment{rgb <.6,.6,.2>}
 finish{ambient 0.3}
Date: 1 Oct 2002 12:55:40
Message: <3d99d38c$1@news.povray.org>
"Greg M. Johnson" <gregj:-)565### [at] aolcom> wrote in message
news:3d99d2a2$1@news.povray.org...
<snip>
Hmm, I got as far as:
#declare Rip_func = function(x,y,z){
  y - ( sin( pow(pow(x,2) + pow(z,2),0.5) ) )
#declare Rip_test =
isosurface {
  function { Rip_func(x*5, y, z*5) - 1 }
  contained_by {sphere{0,5}}
  accuracy 0.001
  max_gradient 10
  pigment{Red}
object{Rip_test}
... getting there.
Date: 1 Oct 2002 13:21:31
Message: <3d99d99b@news.povray.org>
Thanks fellas
Most grateful
Mick
"Mick Hazelgrove" <mic### [at] mhazelgrovefsnetcouk> wrote in message
news:3d99cdad@news.povray.org...
with
apart
beyond
> Mick
Date: 1 Oct 2002 13:28:22
Message: <3d99db36@news.povray.org>
Perhaps something like this:
#declare Ripples =
  function { y-sin(pow(x*x+z*z,1/3)+pi/4) }
camera { location <0,15,-20> look_at 0 angle 35 }
light_source { <100,200,-50>, 1 }
isosurface
{ function { Ripples(x*10,y,z*10) }
  contained_by { box { -<15,1,15>, <15,1,15> } }
  max_gradient 3.4
  scale <1,.5,1>
  pigment { rgb z }
  finish { specular .5 }
  The key value which controls the rate of change of the ripples is the
1/3 in the exponent of the function. 1/2 (ie. square root) will give ripples
at equal distances. Values larger than 1/2 will make the ripples to increase
frequency farther away from the origin, while values smaller than 1/2
(eg. the used 1/3) will decrease the frequency.
  (Note that changing the exponent will also change the overall frequency,
so the factors in the function call (inside the isosurface) will probably
need to be adjusted accordingly.)
Date: 1 Oct 2002 14:11:34
Message: <3d99e556@news.povray.org>
Thanks Warp thats the one I needed
Thanks again
Mick
news:3d99db36@news.povray.org...
> #declare Ripples =
> isosurface
>   max_gradient 3.4
>   scale <1,.5,1>
>   pigment { rgb z }
ripples
increase
x]
Warp -
Date: 1 Oct 2002 15:59:05
Message: <chrishuff-171B6F.15562501102002@netplex.aussie.org>
In article <3d99cdad@news.povray.org>,
Well, distance from the y axis is sqrt(x*x + z*z). Since you want them
wider apart at a distance, you could use the inverse or inverse square
of this...that is simple to do, just remove the sqrt() and divide 1 by
this value. Use sin() or cos() to get waves, and multiply by some value
to adjust the number of waves. Now you have something like:
#declare Ripple = function (x, y, z, n) {cos(n/(x*x + z*z))}
The n/r or n/(r^2) starts out at infinity at r = 0, and gets closer and
closer to 0 as r goes towards infinity, passing through 1 when r == n.
The infinity will cause problems, you could make sure it never gets
above n by offsetting r by 1:
#declare Ripple = function (x, y, z, n) {cos(n/(x*x + z*z + 1))}
The n value adjusts the number of ripples, you could also lower the
offset amount to get more ripples. Multiply the result to adjust the
height of the ripples, and add or subtract from a plane. For multiple
ripples, call Ripple() multiple times, adding/subtracting values to the
xyz coordinates to move the centers around.
isosurface {
    function {y - Ripple(x, y, z, 7)*0.2}
    threshold 0
This is all untested code, but it should get you started. Another thing
you should probably do is make the ripple size decrease with distance,
you should be able to figure out how to do that from this code.
http://tag.povray.org/
