I have about 350 megs of RAM. How many triangle faces will I likely be able
to use in a scene?
-Shay
Megabyte byte byte megabyte one more.
One more megabyte memory.
One more mega megabyte for me.
In article <3d91e9b3@news.povray.org>, "Shay" <sah### [at] simcoparts com>
> to use in a scene?
As many as you can.
It depends on the meshes. Using two copies of a mesh, you can double it
with only a very small increase in memory use. Also, if multiple
triangles share a vertex, only one vertex is stored, so meshes with
different geometries but the same number of triangles can take up
different amounts of space. And then there is overhead, OS, other
programs, virtual memory, etc...
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
Christopher James Huff <chr### [at] mac com> wrote in message
news:chr### [at] netplex aussie org...
> As many as you can.
Could you even give a ballpark guess? I'm at the point in a scene where I
have to make some decisions based on what my computer's capabilities are. Do
you think I could handle 1 million vertices? Maybe if I purchased a little
more RAM?
-Shay
> to use in a scene?
It depends a lot in the mesh.
If all the triangles are separate (ie. they don't share vertex points with
any other triangle), then they will take more memory than if each triangle
shares each of its vertices with lots of other triangles.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
Warp <war### [at] tag povray org> wrote in message news:3d92096a@news.povray.org...
with
I guess I should have asked how many vertices I might be able to use. Most
of my triangles share each vertex with 5 other triangles.
-Shay
A mesh with 500 000 vertices and 1 000 000 triangles uses 200 MB of RAM.
_____________
Kari Kivisalo
Kari Kivisalo <pro### [at] luxlab com> wrote in message
news:3D921470.F20996FD@luxlab.com...
OUCH!! Time to do some shopping and some re-thinking for my project. Thank
you for the data.
-Shay
"Shay" <sah### [at] simcoparts com> wrote in news:3d9219ce@news.povray.org
>> RAM.
> Thank you for the data.
BUT the power of POV-RAY is to use shapes to describe many 'triangles'
i.e. nice sphere can use 256x256 = 65536 triangles in triangles-based-
renderer
whiel in POV it is 1 shape < 1 kB
>to use in a scene?
I've got 376Mb of RAM, and the highest number of faces that I've managed
to use in a scene at once without the memory starting to swap is
481,868,158.
Some of the mesh2 objects that appear in the scene occur more than once.
One of them occurs 14,030 times. The actual number of distinct triangle
faces in the source code is only 73,376.
The resulting image is at
<http://www.econym.demon.co.uk/pictures/thecorporation.jpg>
Peak memory used: 211,619,975 bytes
Mike Williams
Gentleman of Leisure
> 481,868,158.
yeah, but how many FACES? ;)
-tgq
How long did it take to render?
8 minutes 38.0 seconds on a 850MHz machine at 1024*768 with AA 0.3, of
which 34 seconds was parse time.
Mike Williams
It would be really nice to know how this compares to other renderers.
I have absolutely no idea how fast other renderers are with these amounts
of triangles...
