POV-Ray : Newsgroups : povray.general : Isosurface functions Server Time
22 Oct 2026 19:13:09 EDT (-0400)
  Isosurface functions (Message 1 to 12 of 12)
Subject: Isosurface functions
Date: 24 Sep 2002 10:47:20
Message: <3d907af8$1@news.povray.org>
Help please.
Can anyone suggest functions for:
A pipe (i.e. a cylinder with a hole running through it and a configurable
wall-thickness).
A brain-like effect.
Also, with a function like:
(f_hex_x(x,y,z,1) - 2/3)*-1
how would I go about wrapping this around a sphere? (if such a thing can be
done).
#macro A(V,B,C,R)#while(B-256)#if(V-128/B>=0)sphere{0,.5translate<C-4R-1,9>
pigment{rgb<1-C/8R/2C/8>}}#local V=V-128/B;#end#local B=B*2;#local C=C+1;#
end#end A(234,1,0,2)A(85,1,0,1)A(81,1,0,0)light_source{-5 1}//Tom Melly
Subject: Re: Isosurface functions
Date: 24 Sep 2002 11:04:06
Message: <3D907EE6.6D9AB5C4@gmx.de>
Tom Melly wrote:
> Help please.
> wall-thickness).
http://www-public.tu-bs.de:8080/~y0013390/pov/ic/docu02.html#Cylinder_Hole
Pardon?
> done).
Sure, the keyword is spherical coordinates, have a look at the f_r(),
f_ph() and f_th() functions in functions.inc.  For a start try something
like:
#declare f_1=function { (f_hex_x(x,y,z,1) - 2/3)*-1 }
isosurface {
  function { f_1(y, f_th(x, y, z)*5, 0) }
  contained_by {box {<-5,-5,-5>,<5,5,5>}}
  pigment { color NeonBlue }
  finish { specular 0.3 }
Date: 24 Sep 2002 11:19:07
Message: <3d90826b@news.povray.org>
news:3D907EE6.6D9AB5C4@gmx.de...
> Pardon?
Your restraint is commendable ;) - an iso-surface that looks like the surface of
a brain?
As for the rest - many thanks...
Date: 24 Sep 2002 11:25:39
Message: <3D9083F2.F8FC175B@gmx.de>
> > Pardon?
> a brain?
You could try the crackle pattern with non standard form vectors and maybe
other patterns.  But if you really want something looking like a human
brain i suggest taking some real data for it.
Date: 24 Sep 2002 11:30:01
Message: <3d9084f9$1@news.povray.org>
news:3D9083F2.F8FC175B@gmx.de...
Well, it's a brain-coral I'm aiming for, but I don't require realism, just the
effect.
Date: 24 Sep 2002 12:10:25
Message: <3d908e71$1@news.povray.org>
Maybe you could try sphere sweeps controlled by a macro.  I suspect that
something like a "maze-drawing" algorithm combined with the sweeps would give a
nice "brainy" look.
Cheers!
Chip Shults
Date: 24 Sep 2002 12:21:19
Message: <3d9090ff$1@news.povray.org>
"Sir Charles W. Shults III" <aic### [at] cflrrcom> wrote in message
news:3d908e71$1@news.povray.org...
a
> nice "brainy" look.
The thought had occured - as to an iso-surface solution, I remain (probably
stupidly) convinced that there must be some way of randomly deforming surfaces
where the randomness remains consistent (to generate something like a maze,
although not necessarily with a "solution").
Take a function like:
  #declare Bed_func = function(x,y,z){
    y +
    5 +
    (sin(x*5 - sin(z + f_noise3d(x,0,z))*1)/20) -
    (sin((x+z)*1 -
    sin(z + f_noise3d(x,0,z))*1)/30)
But have less regularity in the sin waves, both in frequency and amplitude (if
I've got the terminology right), but without any wave crossing or intersecting
with another.
Date: 24 Sep 2002 19:04:08
Message: <3D90EFB0.9010406@aol.com>
Maybe a couple of interfering radial patterns with a scallop_wave and
some turbulence?
Date: 24 Sep 2002 23:13:33
Message: <pan.2002.09.25.03.12.40.741776.211@gte.net>
On Tue, 24 Sep 2002 12:21:19 -0400, Tom Melly quoth:
>>     that
>> would give
> a
>> nice "brainy" look.
> (probably stupidly) convinced that there must be some way of randomly
> deforming surfaces where the randomness remains consistent (to generate
> something like a maze, although not necessarily with a "solution").
Someone came up with a crackle-based pattern that forms a square maze
about a year ago.  If you could apply a suitable wavy distortion to that
pattern, you'd probably get what you are looking for.
Mark
Date: 25 Sep 2002 12:31:27
Message: <chrishuff-370EA5.12285325092002@netplex.aussie.org>
In article <3d90826b@news.povray.org>, "Tom Melly" <tom### [at] tomandlucouk>
> of a brain?
Try messing around with functions using abs(). This:
function {pow(abs(f_noise(x, y, z)*2 - 1), 0.5)}
should be a good start. The noise function is usually "rounded" on each
"side" of 0.5, this adjusts the range to make the lower half negative
and then "folds" the negative part back to positive, making a bumpy,
creased effect. The pow() function adjusts the falloff. Watch out for
grid artifacts though
http://tag.povray.org/
Date: 26 Sep 2002 07:06:46
Message: <3d92ea46$1@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3d907af8$1@news.povray.org...
> Help please.
Help received....
Many thanks for all the suggestions and tips....
Date: 27 Sep 2002 14:50:42
Message: <3D94A881.CF1A55FD@my-deja.com>
Sorry for the slow reply.
Tom Melly wrote:
> Help please.
It's not an isosurface, but in <3B8E7BA0.8E2BDE71@my-deja.com> I gave
some patterns that look good from certain angles.  (Also used a similar
one on the Shortest Code Contest 2).  They were made with normals, so
they may not be useful for what you want.
Hope it helps.
Tom A.
When scientist say they're making a "quantum leap" it
means they are going out to catch some rays.  - Dr. Science
Deja mail is gone.  Look for me at raugost at yahoo . com
