POV-Ray : Newsgroups : povray.general : ATTN Gilles Tran: your Library includes crash POV Server Time
2 Nov 2026 20:47:33 EST (-0500)
  ATTN Gilles Tran: your Library includes crash POV (Message 1 to 26 of 26)
Subject: ATTN Gilles Tran: your Library includes crash POV
Date: 21 Sep 2002 16:57:16
Message: <3d8cdd2c@news.povray.org>
following causes a parse error: illegal escape sequence in string
with the default "fonts.txt" file...
// Initialises the font list
#declare nFonts=0;
#fopen fFonts "fonts.txt" read
#while (defined(fFonts))
         #read(fFonts,dummy)      // <-- this line while parsing gives
                      // #read(tFonts,dummy"C:\windows\fonts\times.ttf"
                      // parse error: illegal escape sequence in string
         #declare nFonts=nFonts+1;
#fclose fFonts
#declare bookFonts=array[nFonts]
#declare i=0;
         #read(fFonts,dummy)
         #declare bookFonts[i]=dummy
         #declare i=i+1;
#fclose fFonts
Tim Cook
Version: 3.12
Subject: Re: ATTN Gilles Tran: your Library includes crash POV
Date: 21 Sep 2002 17:09:33
Message: <3D8CE00D.EC83202A@gmx.de>
That include file probably neither designed nor updated for POV-Ray 3.5 so
you should expect to have to apply certain changes like to all other
script files made for earlier versions of POV-Ray.
In this case it's probably sufficient to change the backslashes in
fonts.txt into double backslashes or forward shashes (or even better: not
to use explicit path names at all).
Date: 21 Sep 2002 17:38:17
Message: <3d8ce6c9$1@news.povray.org>
Woohoo, that worked (and I fixed the other minor errors POV was
complaining about ALL BY MYSELF.  ain't I cool)
Tim Cook
Version: 3.12
Date: 21 Sep 2002 18:05:38
Message: <3d8ced32@news.povray.org>
I now have the following problem:
how do I move the output of the macro around? O.o
Tim Cook
Version: 3.12
Date: 21 Sep 2002 19:57:04
Message: <3d8d0750$1@news.povray.org>
In article <3d8cdd2c@news.povray.org> , "Timothy R. Cook"
Please note:  An error reported by POV-Ray is *not* a crash!!!
It is extremely important to use the correct terminology in this case as
using the wrong terminology will cause confusion sooner or later!
    Thorsten
Date: 21 Sep 2002 20:34:40
Message: <3d8d1020@news.povray.org>
"Timothy R. Cook" <tim### [at] scifi-fantasycom> a écrit dans le message de
news: 3d8cdd2c@news.povray.org...
Well, sorry about that. As Christoph said some of the POV-Ray 3.1 code has
some (minor) problems with 3.5. I did update all the Megapov objects, scenes
and macros to 3.5 but I somehow didn't think that 3.1 scenes would have
problems too. I'll look into that and correct it. The fact is that the
MakeLibrary suite would benefit a lot from 3.5 features so that I wanted to
improve it a little instead of just fixing it.
object{ TheMacro(blah,blah,blah,blah) translate blah blah blah}
(see the library_new.pov and library_old.pov if you missed them)
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 21 Sep 2002 20:41:58
Message: <3d8d11d6$1@news.povray.org>
Gomen!  You're right, it wasn't a crash... ^_^;
Tim Cook
Version: 3.12
Date: 21 Sep 2002 20:48:02
Message: <3d8d1342@news.povray.org>
Ooh, thankee!
By the way, some of the book patterns aren't exactly what I'd call
compatible with text on the spine...and the book generator only puts
one title per book type??(??) so you get a lot of duplicate books
with the same pattern and title instead of same pattern, different
title...might be something I overlooked, but there it is.
Plus I don't think POV likes unicode-format text files O.o
*sigh* Unicode is such a cool idea!  Why doesn't more software support
it?!
Tim Cook
Version: 3.12
Date: 21 Sep 2002 22:28:44
Message: <chrishuff-0CB658.22264421092002@netplex.aussie.org>
In article <3d8d1342@news.povray.org>,
> it?!
Did you bother to check the documentation?
http://www.povray.org/documentation/view/365/
"Any ASCII or Unicode character, depending on the charset setting in
global_settings."
http://www.povray.org/documentation/view/219/
"The option utf8 is a special Unicode text encoding and it allows you to
specify characters of nearly all languages in use today."
http://tag.povray.org/
Date: 21 Sep 2002 23:18:29
Message: <3d8d3685@news.povray.org>
> global_settings."
File: MakeBook.inc  Line: 33
#while (defined(fTitles)) // read once to get the number of titles
         #read(fTitles,dummyï <----ERROR
Parse Error: Illegal character in input file, value is ef.
Returned from renderer with error status
The input file in question is as follows (the file is encoded with utf8:
"\u3061\u3087\u3073\u3064\u30C4",
"\u30D5\u30EB\u30E0\u30FC\u30F3\u6E80\U6708\u3092\u2055\u304C\u3057\u3066"
EOF
But wait, it gets even better!  When I save the file with ansi encoding,
it does, in fact, render...
...but...
the fonts I wish to use are "C:\\windows\\fonts\\msgothic.ttc" and
"C:\\windows\\fonts\\msmincho.ttc"
which should interpret the above listed utf8 codes as (in this order)
double quote, hiragana chi, hiragana small yo, hiragana bi, hirigana
tsu, katakana tsu, double quote, comma, katakana fu, katkana ru,
katakana mu, hiragana/katakana prolonged sond mark, katakana n, unified
CJK ideograph 'full', unified CJK ideograph 'moon', hiragana wo,
hiragana sa, hiragana ga, hiragana shi, hiragana te, double quote
EOF
guess what it doesn't do.  try it yourself.  then tell me again how
POV supports unicode.
Tim Cook
Version: 3.12
Date: 21 Sep 2002 23:20:34
Message: <3d8d3702$1@news.povray.org>
Insert "CR/LF, double quote" here
> EOF
Tim Cook
Version: 3.12
Date: 22 Sep 2002 04:24:45
Message: <3d8d7e4d$1@news.povray.org>
In article <3d8d3685@news.povray.org> , "Timothy R. Cook"
>> global_settings."
Where does the POV-Ray documentation ever say that you may use any but A-Z,
a-z,0-9 and _ in an identifier?  I do not recall that it says you may use
any other charcaters in identifiers...
    Thorsten
e-mail: tho### [at] trfde
Date: 22 Sep 2002 04:27:40
Message: <3d8d7efc@news.povray.org>
> EOF
Where does the POV-Ray documentation ever say that the #read directive does
support utf8?  I do not recall it being specified to read and decode
anything in files in the way you are trying to use.
    Thorsten
Date: 22 Sep 2002 04:35:18
Message: <3d8d80c6$1@news.povray.org>
POV-Ray supports Unicode just fine if one actually would bother to read the
documentation.  Neither of the two examples is said to be valid anywhere.
To the contrary, it says:
10.1.3.5 Strings
String Expressions
STRING:
    STRING_FUNCTION | STRING_IDENTIFIER | STRING_LITERAL
STRING_FUNCTION:
    chr (INT) | concat (STRING,STRING[,STRING]...) | str (FLOAT,INT,INT) |
    strlwr (STRING) | strupr (STRING) | substr (STRING,INT,INT) |
    vstr (INT,VECTOR,STRING,INT,INT)
STRING_LITERAL:
    QUOTE [CHARACTER...] QUOTE
    Limited to 256 characters.
QUOTE:
CHARACTER:
    global_settings. The following escape sequences might be useful when
    writing to files or message streams:
    \a - alarm
    \b - backspace
    \f - form feed
    \n - new line
    \r - carriage return
    \t - horizontal tab
    \uNNNN - unicode character four-digit code
    \v - vertical tab
    \\ - backslash
    \' - single quote
    \" - double quote
From this it is trivial to see an example of the currect use:
    #declare foostr = "\u3061\u3087\u3073\u3064\u30C4";
Very clear and very simple...
    Thorsten
Date: 22 Sep 2002 04:46:15
Message: <3d8d8357@news.povray.org>
I are confused now.  Why would POV, supporting unicode strings
internally, not be able to read a data file...that's ansi, and
use that as a string...in whatever format?
Tim Cook
Version: 3.12
Date: 22 Sep 2002 04:47:38
Message: <3d8d83aa@news.povray.org>
...that is rather strange, which I did not notice when I got the error.
Of course, there is no i with umlaut in the file, so, who knows?
Tim Cook
Version: 3.12
Date: 22 Sep 2002 05:04:35
Message: <3d8d87a3$1@news.povray.org>
Two things:
1) #read apparently didn't have a problem reading it because I get the
    same output having swapped the data in the file with strings inside
    the .inc file that uses it
2) did you get the result i specified in my post, namely some japanese
    characters?  i do see that there are some unicode characters in the
    string (an e with cedilla being the first), but it is not japanese
    characters, which is what they should be, because that is what those
    unicode character codes specify.
Tim Cook
Version: 3.12
Date: 22 Sep 2002 05:19:57
Message: <3d8d8b3d$1@news.povray.org>
In article <3d8d87a3$1@news.povray.org> , "Timothy R. Cook"
Interesting.  This is indeed possible that #read may work, but if so then it
is not officially supported at the moment...
Well, that would require me to have the font.  I can tell you that it works
with TTF fonts.  The problem with TTC font files is that they are a
collection of TTF font files in one file, and POV-Ray only supports them
with one TTF font file inside (the others are ignored).  So if the font does
not include the correct TTF font file as the first in the collection it
contains, POV-Ray will not be able to find the correct character because it
does not have enough information to make a choice which TTF font in the TTC
font file to pick.  The solution is to convert the TTC font file to multiple
TTF font files and then use the appropriate TTF file.
    Thorsten
Date: 22 Sep 2002 07:22:19
Message: <3d8da7eb@news.povray.org>
which I have...
> I can tell you that it works with TTF fonts.  The problem with TTC
 > font files is that they are a collection of TTF font files in one
 > file, and POV-Ray only supports them with one TTF font file inside
 > (the others are ignored).  So if the font does not include the correct
 > TTF font file as the first in the collection it contains, POV-Ray will
 > not be able to find the correct character because it does not have enough
 > information to make a choice which TTF font in the TTC font file to pick.
ahhh, that'll do it
Next question: how do I do that?
Tim Cook
Version: 3.12
Date: 22 Sep 2002 07:28:24
Message: <3d8da958$1@news.povray.org>
> ahhh, that'll do it
Oh shoot, I just realised something: I'd have to specify the proper font
for each of the titles, depending on english or japanese...and if
japanese, I'd sometimes have to specify several fonts, depending on
character...oyyyy funness.
Tim Cook
Version: 3.12
Date: 22 Sep 2002 07:39:18
Message: <3d8dabe6@news.povray.org>
In article <3d8da7eb@news.povray.org> , "Timothy R. Cook"
Well, I suppose most font editors that support both TTC and TTF files should
be able to do it.  I don't know any font editors for Windows however, so I
cannot help you picking one ;-)
    Thorsten
Date: 22 Sep 2002 07:45:17
Message: <3d8dad4d@news.povray.org>
In article <3d8da958$1@news.povray.org> , "Timothy R. Cook"
Not really.  All you would need is one font which all the characters in it.
The problem is that few fonts come with characters for many different
languages (also it is possible), because seldom a person needs characters of
more than one language (or language family, like all using the Latin
alphabet) in a font and having many different languages, i.e. Japanese and
Chinese in there would create a very huge font file.
The trick why it works in your operating system / word processor is that
they always will attempt to pick a font that does have characters for that
language.  This is not a choice POV-Ray can make :-(
    Thorsten
Date: 22 Sep 2002 07:59:59
Message: <3d8db0bf$1@news.povray.org>
Guess I could use the font editor I have to compile just the characters
I need...(nice little shareware called 'Font Creation Program'...I hope
it reads TTCs)
hmm, msgothic and msmincho are both over 8 MB TTCs...'batang' is 15.7 mb
...whew
Tim Cook
Version: 3.12
Date: 22 Sep 2002 08:03:00
Message: <3d8db174$1@news.povray.org>
> it reads TTCs)
Darn, it doesn't.  Hmmm...
Tim Cook
Version: 3.12
Date: 22 Sep 2002 08:20:36
Message: <3d8db594$1@news.povray.org>
Wow, simhei.ttf ...9.8 megs, and it's a single ttf.  maybe this'll work
SUGOI!!!! sugoisugoisugoi!  It even works inside of Moray, with the
\uNNNN!  hahaha this is cool
Tim Cook
Version: 3.12
Date: 22 Sep 2002 09:00:17
Message: <3d8dbee1$1@news.povray.org>
In article <3d8db0bf$1@news.povray.org> , "Timothy R. Cook"
> ...whew
Exactly.  And they could be several times the size if they contained only
all the 65535 UCS2 characters supported by POV-Ray.  And even then it would
only be a subset of all Unicode characters (TTF fonts don't support more)...
    Thorsten
