POV-Ray : Newsgroups : povray.general : Spline object: what is it? Server Time
2 Nov 2026 20:50:12 EST (-0500)
  Spline object: what is it? (Message 1 to 38 of 38)
Subject: Spline object: what is it?
Date: 17 Sep 2002 13:54:38
Message: <3d876c5e$1@news.povray.org>
I remember seeing splines as objects, perhaps in Chris Colefax's include
file.  It's not just a means of decribing points but an "object."
What kind of pov primitive is that: sphere sweep,  bicubic, etc.
Subject: Re: Spline object: what is it?
Date: 17 Sep 2002 14:12:12
Message: <e0seous1gv4knl640h9d0rq1kuvqqt87nf@4ax.com>
On Tue, 17 Sep 2002 13:53:47 -0400, "Greg M. Johnson" <gregj:-)565### [at] aolcom>
Spline is in general vector function (in POV 2D-5D). It's equations base on
set of points. Just like you have function based primitives you can spline
based primitives. There is whole chapter about it in documentation.
ABX
Date: 17 Sep 2002 14:18:21
Message: <3d8771ed$1@news.povray.org>
I read the docs but thought someone had a utility that make "visible"
splines.
Date: 17 Sep 2002 14:22:23
Message: <9iseousvbet76h4l4tbdnqddr43ckbap9s@4ax.com>
On Tue, 17 Sep 2002 14:17:29 -0400, "Greg M. Johnson" <gregj:-)565### [at] aolcom>
> splines.
There is no "visible" spline. There are only spline based objects. Examples of
splines "visible" this way are in sample docs. You have to precise what you
want to make visible.
ABX
Date: 17 Sep 2002 14:27:49
Message: <3d877425@news.povray.org>
Has anyone else looked at Chris Colefax's spline include file?
http://www.geocities.com/ccolefax/spline/index.html
Is his
    preview_spline (MySpline, default_options)
simply a sphere sweep?
Date: 17 Sep 2002 15:07:40
Message: <3d877d7c$1@news.povray.org>
> Is his
Don't confuse Chris Colefax's spline include file with POV-Ray 3.5 splines.
The include file was written well before splines were brought into POV-Ray,
so it doesn't make any use of them at all.
The preview_spline macro does not use sphere sweeps, though it may simulate
them. If you want the 3.5 equivalent of that macro, then use a sphere_sweep.
Unfortunately, POV-Ray has no way to apply a separarely defined spline to a
sphere_sweep object. Nor can it apply a separate spline to a prism object or
something of that sort. I think this is a weakness in POV-Ray - it has the
same data structure represented in different ways depending on what you're
using it for.
I understand that the data structures aren't *identical*, but they're darn
similar and would be much more powerful if they were more portable.
 - Slime
[ http://www.slimeland.com/ ]
Date: 17 Sep 2002 18:00:58
Message: <3d87a619@news.povray.org>
Slime wrote:
> <snip>
> a sphere_sweep object. Nor can it apply a separate spline to a prism
> object or something of that sort. I think this is a weakness in POV-Ray -
> it has the same data structure represented in different ways depending on
> what you're using it for.
Something vaguely related that came to my mind: Is it possible with the
current tools to define a sort of hybrid between a lathe and a prism? I
mean: in a prism you specify the section with a spline, in a lathe you
specify the generatrix (is that the word?) with a spline, what about
specifying both? In case it isn't possible (as I guess), wouldn't it be
cool to have this kind of objects (lathes with non-circular section /
prisms with non-linear sweeps)? Just an idea, though.
Greetings
Date: 17 Sep 2002 19:53:06
Message: <3d87c062$1@news.povray.org>
"Jellby" <jel### [at] M-softhomenet> wrote in message
news:3d87a619@news.povray.org...
I've used this before in Imagine 2 on the amiga (where is was called
'Forms') and I think it will have to become my new project while I wait for
inspiration on the current IRTC topic
jim
Date: 17 Sep 2002 22:51:27
Message: <3d87ea2f@news.povray.org>
  It shouldn't be too difficult to make a macro which creates that kind
of surface as a mesh using the two splines. (It would probably render 10
times faster as a mesh, as well.)
Date: 18 Sep 2002 01:56:10
Message: <Xns928D517C42B77seed7@povray.org>
http://www.econym.demon.co.uk/isotut/splines.htm
prismatic lathe
Ingo
Date: 18 Sep 2002 04:12:44
Message: <3d88357c$1@news.povray.org>
"Greg M. Johnson" <gregj:-)565### [at] aolcom> skrev i melding
news:3d8771ed$1@news.povray.org...
> splines.
As ABX said, the spline itself is just a set of points. See the docs
[6.1.9] - "Spline Identifiers" for a better description..
If I understand your question right you want to make a spline "visible",
(show it's path). Then you just have to place objects along it with a #while
loop.
Something like this:
location z*-5 look_at 0
light_source {z*-15 1}
#declare My_Spline =
spline{
natural_spline
-1,< 1.5, 0,0>,// control point
 0,< 1, 1,0>,
 1,<-1, 1,0>,
 2,<-1,-1,0>
 3,< 1,-1,0>,
 4,< 1, 0,0>,
 5,< 0, 0,0>,
 6,<-1, 0,0>// control point
#local Q = 0; // shows smoothed path
#while (Q < 5)
        sphere {My_Spline(Q),0.1 pigment {rgb 1}}
#local Q = Q+0.1;// decrease to make smoother
#local Q = -2;// shows spline points (control points too)
#while (Q < 7)
        sphere {My_Spline(Q),0.15 pigment {rgb <1,0,0>}}
#local Q = Q+1;
I reccomend docs [3.4.1.1]  "Understanding The Concept of Splines", if you
haven't read it already!
Good luck!
-Peter
http://hertel.no/peter
Date: 18 Sep 2002 08:49:28
Message: <3d887658$1@news.povray.org>
news:3d87ea2f@news.povray.org...
Thanks for the idea!
 In order to be 10 times faster, would you have to "store" the coordinates
of the mesh first as an INC or would I lose speed if it were "calculated"
anew for each frame of an animation?
The application is that I want to make a railroad.   I want to make the
rails, and want to identify the path of the rails with a spline.  The
question then is what to make it out of:   a sphere sweep seems
impractically slow in parsing/rendering, especially if it's "big".
Date: 18 Sep 2002 09:38:30
Message: <3d8881d6@news.povray.org>
> prismatic lathe
> Ingo
Yeah, I should have thought of isosurfaces :) However, would an optimised
implementation be possible? Would anyone find it useful?
Date: 18 Sep 2002 09:45:24
Message: <chrishuff-3DA8F4.09434918092002@netplex.aussie.org>
In article <3d8881d6@news.povray.org>,
You could do it with meshes.
http://tag.povray.org/
Date: 18 Sep 2002 10:24:36
Message: <3d888ca4@news.povray.org>
  I'm talking about render time, not parse time.
  If you need to create the mesh for each frame separately (eg. because it
changes shape) then parsing can be slowish. However, if you need to create
it just once, then saving it in a file in mesh2 format should make parsing
quite fast as well.
Date: 18 Sep 2002 12:09:50
Message: <3d88a54e$1@news.povray.org>
news:3d888ca4@news.povray.org...
>  However, if you need to create it just once, then saving it in a
>  file in mesh2 format should make parsing quite fast as well.
I understand the benefit of  "removing all duplicate vertices " as mentioned
in 3.5.2  Mesh2 Object.
Q: If I'm making something complex ( for my brain at least), is there still
a huge render/parse benefit from using an UNoptimized mesh2 over anything
else??
Date: 18 Sep 2002 12:37:19
Message: <3d88abbf@news.povray.org>
Greg M. Johnson <gregj:-)565### [at] aolcom> wrote in message
news:3d88a54e$1@news.povray.org...
mentioned
still
> else??
There is a considerable benefit over csg and some small benefit over
mesh(one). I'm not sure what you mean by an UNoptomized mesh2, but in order
to find vertex normals for your mesh(one) you will need to identify the
duplicate vertices anyway, so I cannot see any reason to use mesh(one) in
your final scene.
 -Shay
Date: 18 Sep 2002 14:33:53
Message: <1fiq3hu.wzcuh8kf32d8N%jlippert@ubcom.de>
> using it for.
I agree that this would be a handy feature. However, if I remember
correctly, there were no splines in POV-Ray 3.1 on which I based the
sphere_sweep stuff on, so I had to "build my own". Makes for a good
excuse, eh? ;)
However, I think it could be done now, with a bit of rework of the
sphere_sweep syntax. Just let the sphere_sweep take a four-dimensional
spline as input data. I'm not volunteering to do this in the foreseeable
future, though, just in case. ;)
Jochen Lippert
No smilies were harmed in the making of this message ;)
Date: 18 Sep 2002 16:05:42
Message: <3d88dc96$1@news.povray.org>
thanks for everyone's help.
I now have code that builds my railway with mesh2 based on any given spline.
Is there a spline visualizer scene file already out there based on mesh2:  I
could tweak mine to do this if it were a benefit to the community .    8o{|
Date: 18 Sep 2002 17:05:40
Message: <3d88eaa4@news.povray.org>
> else??
  If you are going to use duplicated (or triplicated/quadruplicated/whatever)
points, better use the regular mesh (as it internally joins duplicates into
one, thus saving memory).
Date: 18 Sep 2002 17:19:21
Message: <3d88edd9$1@news.povray.org>
Warp <war### [at] tagpovrayorg> wrote in message news:3d88eaa4@news.povray.org...
into
Does this use less memory than joining them yourself into a mesh2
vertex_vector list? If so I have some recoding to do.
 -Shay
Date: 18 Sep 2002 17:43:57
Message: <3d88f39d$1@news.povray.org>
news:3d88dc96$1@news.povray.org...
I
8o{|
I don't see any benefit for visualizing splines. It's too easy to do this
with a #while loop. Your code could be modified into an extrusion macro,
however. I think that many would find use in that.
 -Shay
Date: 19 Sep 2002 00:45:04
Message: <web.3d89562229f3d87418ccf4f70@news.povray.org>
This could be used to make the tubing for a neon sign. Use the spline once
for the outer part of the tube, then again with smaller radius for the
inner part. Perhaps this could be done with a loop inside the sphere_sweep
object. Then use csg to make the hollow tube.
Rohan _e_ii
Date: 19 Sep 2002 08:11:23
Message: <3d89beea@news.povray.org>
  If you do the same job as POV-Ray does internally, ie. join all duplicate
points into one in the vertex_vector list, then you are doing exactly that:
the same job as POV-Ray.
  The advantage of allowing POV-Ray to do it (ie. by you using 'mesh') is
that it will save you work and will probably be a lot faster (finding
duplicate points is not a trivial task and needs clever data structures
in order to be fast). The best thing you can do is to figure out a way of
not creating duplicate points in the first place (this is possible and even
easy in many cases, and the issue in question is this kind of case).
  Of course the disadvantage of using mesh is that it takes more disk space
(if you write it to a file) and it may be a bit slower to parse (if nothing
else, because it's more to read, being a larger file).
Date: 19 Sep 2002 09:59:32
Message: <3d89d844@news.povray.org>
Warp <war### [at] tagpovrayorg> wrote in message news:3d89beea@news.povray.org...
duplicate
that:
Yes, but I still prefer to do it myself. Even if my mesh generation code is
sometimes crap, I like the output to be as perfect as possible. Besides, I
already have the code to identify the duplicates, so it's now only a matter
of waiting a few minutes for it to parse.
 -Shay
Date: 19 Sep 2002 11:14:48
Message: <chrishuff-CEF64D.11131019092002@netplex.aussie.org>
In article <3d89d844@news.povray.org>, "Shay" <sah### [at] simcopartscom>
The output will be identical. It is just that the built-in feature will
always get the vertices right, while your duplicate-removal code might
have a bug. Using the built-in feature will get a "perfect" result
(correct image and minimal memory usage), and be much faster than doing
the duplicate removal in POV script. The mesh2 syntax is mainly useful
for working with mesh files...the files are smaller and faster to parse.
Date: 19 Sep 2002 11:16:08
Message: <chrishuff-989949.11143019092002@netplex.aussie.org>
In article <web.3d89562229f3d87418ccf4f70@news.povray.org>,
Why would this require a new syntax?
Date: 19 Sep 2002 11:42:44
Message: <3d89f074@news.povray.org>
Christopher James Huff <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
> <snip>while your duplicate-removal code might
> have a bug.
In this case it's just too simple to f__k up.
That is a consideration, albeit a small one. My IRTC entry, currently one
large mesh2 file, already takes about 8 seconds to parse. Another
consideration is that when forming mesh objects not generated by an
equation, the vertices must be grouped anyway in order to calculate the
normal vectors. The work to translate the file into a mesh2 after having
grouped the vertices for the purpose of calculating the normal vectors is so
small that it is worth it to me to complete the conversion even for a small
consideration. This is of course provided that my code is error free, which
I am confident it is.
 -Shay
Date: 19 Sep 2002 17:14:46
Message: <3d8a3e46@news.povray.org>
> have a bug.
  It's often the case that you can build the mesh without creating
duplicate vertex points at all. This way you don't have to remove anything.
  For example, if you make a box using mesh2, you simply create 8 points
in the vertex list and then use their index values in the faces list.
Similarly for more advanced shapes, usually created using loops (such
as cylinders, spheres, etc).
Date: 20 Sep 2002 10:14:54
Message: <Xns928FA512C39C1PhiLho@204.213.191.226>
"Shay" <sah### [at] simcopartscom> wrote in news:3d89f074@news.povray.org:
>> have a bug.
Uh? What is this function? In which include file can I find it?
Does it look nice, used in an isosurface?
:-P
Philippe Lhoste (Paris -- France)
Professional programmer and amateur artist
http://jove.prohosting.com/~philho/
Date: 20 Sep 2002 10:36:10
Message: <44cmouskcfosd3oaji0r1pq1ng2m5pfe7d@4ax.com>
On Wed, 18 Sep 2002 15:38:31 +0200, Jellby <jel### [at] M-softhomenet> wrote:
> > prismatic lathe
> > Ingo
It is not isosurface object, it is parametric object. It is not exactly the
same. And if something is possible with parametric object then it is possible
with mesh. Look at http://members.home.nl/seedseven/
ABX
Date: 20 Sep 2002 11:39:14
Message: <3d8b4122@news.povray.org>
Philippe Lhoste <Phi### [at] GMXnet> wrote in message
> :-P
This function can be found in many of my personal *.inc files. Output is a
harsh gong-type noise and a yellow highlight over one line of code.
Isosurface version produces an isosurface the exact shape and scale of the
bounding container.
 -Shay
Date: 20 Sep 2002 14:00:31
Message: <3d8b623e@news.povray.org>
>> > prismatic lathe
>> > Ingo
> the same. And if something is possible with parametric object then it is
> possible with mesh. Look at http://members.home.nl/seedseven/
> ABX
Yes, now I have read the whole tutorial (I just had a quick look before). I
see the difference between isosurfaces and parametric objects. And yes,
almost everything is possible with meshes, but it's not the same, from my
point of view it's just a fake, a useful, efficient, clever fake, but a
fake.
Date: 20 Sep 2002 14:31:42
Message: <e2qmous6t21v2n7c3n1do6ibdtsb0ld3p8@4ax.com>
On Fri, 20 Sep 2002 20:00:31 +0200, Jellby <jel### [at] M-softhomenet> wrote:
> fake.
Is approximation a fake in your definition ?
ABX
Date: 20 Sep 2002 14:41:32
Message: <3d8b6bdc@news.povray.org>
Jellby <jel### [at] M-softhomenet> wrote in message
news:3d8b623e@news.povray.org...
< And yes,
> fake.
I'd better get on the phone to Pixar right away!! <g>
 -Shay
Date: 20 Sep 2002 16:27:19
Message: <3d8b84a6@news.povray.org>
>> I see the difference between isosurfaces and parametric objects. And yes,
>> fake.
> ABX
Don't misunderstand me. Maybe 'fake' was not a very well-chosen word (I'm
not an English speaker). I meant that meshes are not the 'true' object (if
you are approximating an object by means of a mesh), if you zoom it you
will eventually see the triangles in the shadow, and they are not quite
'elegant', I think... We do have true spheres in povray, and they can be
made as meshes too. I was just wondering if it would be possible to have
such prismatic lathes in an optimized way (parametrics are slow, I've
heard), without the need of converting to a mesh. I don't demand it, I
can't do that and I don't want to do that, I was just giving an idea.
After all, everything in povray is just a fake of reality ;)
Date: 20 Sep 2002 16:52:34
Message: <fk1nouonc1met665ah87bj2iapq79619q4@4ax.com>
On Fri, 20 Sep 2002 22:27:17 +0200, Jellby <jel### [at] M-softhomenet> wrote:
> you are approximating an object by means of a mesh).
When I asked above question I tried to point you that surfaces of isosurface
and parametric objects are approximations. You can control accuracy of this
approximation with max_gradient, accuracy and evaluate keywords. You can
control accuracy of the mesh with vertex resolution. So isosurface is a fake,
"a useful, efficient, clever fake, but a fake" quoting you. It is better
approximation becouse of its alogithms but for the same reason it is usually
slower.
and animation features are just a fake of real movie www.POVtheMOVIE.com ;)
ABX
Date: 20 Sep 2002 17:09:37
Message: <3d8b8e91@news.povray.org>
> isosurface and parametric objects are approximations. You can control
> accuracy of this approximation with max_gradient, accuracy and evaluate
> keywords.
I had the feeling that was what you meant ;)
