"JRG" <jrg### [at] hotmail com> a écrit dans le message de news:
3d7b7fd0@news.povray.org...
> I have two height_fields and I want them to create a round corner instead
of a sharp
> one. I thought about cutting the height_fields (which come from a seamless
bitmap)
> and rotating these thin "slices" around the y axis... but maybe there are
more
> efficient ways to accomplish this (hmm... displacing an iso cylinder?).
I used the slicing method once for my IRTC "fortress" image. The height
field I used were rough so that I didn't have to use many slices (I think 3
to 5 did the trick). Note that I was folding one HF in 2, not joining two
of them but since you're using a seamless bitmap it should be the same
technique.
Oh well the macro's here:
#macro mHFCorner(HF,xHF,yHF,zHF,rCorner,nCorner)
// the HF must be already textured and vertical
// it must have been translated before to be in the positive z
// xHF = width of front pane (x, 0 -> xHF)
// yHF = height of side pane (y, 0 -> yHF)
// zHF = depth of side pane (z, 0 -> zHF)
// rCorner = radius of corner
// nCorner = number of corner elements
#local lHF=xHF+zHF+rCorner*(-2+pi/2);
#local HF=object{HF scale <lHF,yHF,1>}
#local iCorner=(rCorner*pi/2)/nCorner;
#local i=0;
union{
object{HF clipped_by{plane{x,xHF-rCorner}}}
#while (i<nCorner)
object{HF clipped_by{box{<0,-0.1,-1.1>,<iCorner,yHF*1.1,1.1>
translate x*(xHF-rCorner+i*iCorner)}}
translate -x*(xHF-rCorner+(i+0.5)*iCorner)
translate z*-rCorner
rotate -y*(i*90/nCorner+45/nCorner)
translate z*rCorner+x*(xHF-rCorner)
#local i=i+1;
object{HF clipped_by{plane{x,lHF-zHF+rCorner inverse}}
translate -x*(lHF-rCorner-zHF) rotate y*-90 translate <xHF,0,-rCorner>} //
pigment{Cyan}}
G.
http://www.oyonale.com
- Graphic experiments
- Posters
