Has anyone seen an IRQL_NOT_LESS_OR_EQUAL bluescreen when rendering in WXP?
The STOP error is: 0x0000000A.
If so, know of a fix, or can anyone recommend anything?
I'm using:
WXP Gold (not SP1)
128MB system memory
1.3GHz CPU
Was rendering benchmark.pov for chess2.pov
Thanks, Shane
On Thu, 5 Sep 2002 00:20:07 -0500, "Shane"
Almost sure it's some kind of hardware problem, I don't see what POV
has to do with IRQs.
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] vip bg
TAG e-mail : pet### [at] tag povray org
"Shane" <**shane**@**yarbrough.net**> schreef in bericht
news:3d76e82f$1@news.povray.org...
> I'm using:
> WXP Gold (not SP1)
> 128MB system memory
> 1.3GHz CPU
That is exactly the same error I had with WXP. It has nothing to do with
POV-Ray, but with your hardware.
VIA-chipset, right?
Possible solution: install new VIA-drivers, but that didn't help here.. I had to
reinstall W98SE.
cu!
<.5,1,.5>,x)L(0,x-y,<.5,1,.5>,x) // ZK http://www.povplace.be.tf
I get this often in Adobe Premiere under Win 2000 (and previously NT) and
have been told it relates to video drivers. For example, if I am connected
to an external DV device and try to scrub in the Premiere timeline...
Do a search on exactly that message in the MS Knowledge Base and you will
see several possible causes.
I don't believe it has anything to do with POV.
D.
"Shane" <**shane**@**yarbrough.net**> wrote in message
WXP?
> I'm using:
> WXP Gold (not SP1)
> 128MB system memory
> 1.3GHz CPU
> Thanks, Shane
Thank you to all for replying. I'll attempt to answer some of the questions
in the various replies below.
1) WXP Gold is simply a common tag used to communicate the initial release
of WXP, whether it be Home or Pro
2) Yes, WXP SP1 is now released
3) My video controller is an ATI M9
4) I'm thinking hardware as well
Thanks again, Shane
WXP?
> I'm using:
> WXP Gold (not SP1)
> 128MB system memory
> 1.3GHz CPU
> Thanks, Shane
