POV-Ray : Newsgroups : povray.general : Radiosity Question Server Time
24 Aug 2025 04:53:31 EDT (-0400)
  Radiosity Question (Message 1 to 10 of 11)
Subject: Radiosity Question
Date: 28 Aug 2002 19:12:17
Message: <3d6d58d1$1@news.povray.org>
I've just started a radiosity render and noticed right off the bat that
things are way way too bright in what has been rendered... the same thing
without radiosity on renders just fine light-wise...
What should I modify first... light defs with their fade_power and
fade_distances or the radiosity parameters?
Thanks,
Robert J Becraft
aka cas### [at] aolcom
Subject: Re: Radiosity Question
Date: 28 Aug 2002 19:36:12
Message: <3d6d5e6c@news.povray.org>
  Try modifying #default { finish { diffuse ... } } and
global_settings { radiosity { brightness ... } } until you find
a good combination which gives you the best brigthness for illuminated
and shadowed parts.
  (Note that making radiosity brightness too large will give you rather
unrealistic lighting, so don't raise it too much.)
Date: 28 Aug 2002 19:55:25
Message: <3d6d62ed@news.povray.org>
3d6d58d1$1@news.povray.org...
Hint : always work with radiosity turned on and use something low for the
tests, like count 30 error_bound 1. Then put a switch in the scene so that
you can use better settings for quality tests and final renders.
That way, you can tune your lighting as the scene requires it. I personally
find lighting scenes with radiosity much easier than without because it's
often possible to get away with one light only. Otherwise there are no
specific rules for radiosity lighting. Jaime's light macros for artificial
lights, for instance, use extremely bright colors and very small
fade_distance but natural lighting can use very standard lights.
Note that higher recursion levels tend to wash out the scene if it has
little contrast per se (I keep it at 1 unless the scene requires something
higher). The brightness parameter can be used to enhance the radiosity
effect though it may look unnatural if too high. Rad scenes can also benefit
from some post-processing like tone level adjustment to get a richer and
more pleasant tone range.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 28 Aug 2002 20:08:59
Message: <3d6d661b@news.povray.org>
Reading Warp's comment I realise that I forgot to add that when using
radiosity it is preferable to have ambient set at 0 (using #default). The
default ambient 0.1 may also explains why it looks too bright. Let the
radiosity do the work.
G.
- Posters
Date: 28 Aug 2002 21:30:29
Message: <i2uqmu4frbnl94v5u9shh5vjvfi8ndqcpg@4ax.com>
  While not quite a tutorial, you can read and view Warp's radiosity
example page at:
http://www.students.tut.fi/~warp/pics/Radiosity_test2/
  I also found the link to Warp's comments page to be of value when it
comes to setting ambient to 0 (zero). There is a disclaimer that some of
what he has written applies to POV-Ray 3.1, but I still found the
examples interesting.
Alan
ako### [at] povrayorg
a k o n g <at> p o v r a y <dot> o r g
Date: 28 Aug 2002 21:43:17
Message: <3d6d7c35$1@news.povray.org>
Or using
global_settings {
ambient_light 0
 - Slime
[ http://www.slimeland.com/ ]
Date: 28 Aug 2002 22:45:59
Message: <3d6d8ae7$1@news.povray.org>
> global_settings {
> ambient_light 0
Better to use the #default option for ambient in textures.  If you set
global ambient to 0, you can't create visible light sources for radiosity
using ambient.
-tgq
Date: 28 Aug 2002 23:14:13
Message: <3d6d9185$1@news.povray.org>
> using ambient.
Funny you mention that; I just now ran into that problem again and realized
why Gilles said that =)
In the past I just set ambient_light .00001 and then used ambient 1/.00001
for bright objects.
 - Slime
Date: 29 Aug 2002 09:46:04
Message: <3d6e259b@news.povray.org>
  Actually the whole text applies almost exclusively to POV-Ray 3.1.
The radiosity has changed so much in 3.5 that almost nothing of that
text applies anymore.
Date: 30 Aug 2002 02:55:20
Message: <3d6f16d8@news.povray.org>
I certainly wouldn't change the fade_power or fade_distance at this
point! Altering the "physical" characteristics of your light will
certainly change the lighting, but probably not in the way you want.
Radiosity effectively adds light to the scene (assuming that some
already exists in the form of ambience or light_sources, of course).
It's not surprising that a scene which is perfectly-lit by standard
lighting would be too bright with radiosity added.
Consider using a default ambient 0, as the other posters have suggested
(otherwise, radiosity will make EVERYTHING glow). If that doesn't help,
the next easiest thing to do is simply to reduce the intensity of your
lighting (letting the radiosity "fill in" for the missing
illumination).. or alternatively, if none of your textures use a custom
diffuse value, and you have a lot of lights, just lower the default
diffuse value.
You could also lower the brightness in the radiosity block.. of course,
at some point, this becomes counterproductive. The point of using
radiosity is to have it be visible. ;)
It's usually a good idea to write and test your scenes with radiosity on
all the time (even very low quality settings - say, count 10-30,
error_bound 1 - will give you a rough idea of how the lighting will
look). At the very least, do turn it on for the lighting tweaks, if not
for the modeling.
-Xplo
