POV-Ray : Newsgroups : povray.general : Placing objects on spheres... Server Time
2 Nov 2026 22:52:45 EST (-0500)
  Placing objects on spheres... (Message 1 to 18 of 18)
Subject: Placing objects on spheres...
Date: 27 Aug 2002 12:39:49
Message: <3d6bab55$1@news.povray.org>
Hi all!
I'm looking for a method to calculate positions in order
to place objects with N radius onto a sphere with R radius.
These small objects shouldn't intersect each other (as less
as possible), but cover the entire sphere.
I need this to generate positions for some CSG-Hairs to
get a furball (the last try was suspected to be fireworks...)
I'm thankful for any link or help regarding this, and do
note that I'm the kinda guy who likes to script the required
algorithms himself...
Thanks,
Tim
Tim Nikias
Email: Tim### [at] gmxde
Subject: Re: Placing objects on spheres...
Date: 27 Aug 2002 12:46:31
Message: <q3bnmu0sbvs20bve02r9rv0lh3t3oor8rh@4ax.com>
http://www.math.niu.edu/~rusin/known-math/index/spheres.html
ABX
Date: 27 Aug 2002 12:47:26
Message: <3D6BAD1E.2007FB01@gmx.de>
Tim Nikias wrote:
> Hi all!
http://astronomy.swin.edu.au/~pbourke/geometry/spherepoints/index.html
Date: 27 Aug 2002 14:54:53
Message: <3d6bcafd$1@news.povray.org>
Try dissecting this macro I wrote a couple of years ago.  It basically
triangulates a sphere to 'n' iterations (like a geodesic sphere).  The
limitation here is that you are restricted to the number of points related
to the iteration level 'n' (I don't know the formula off the top of my
head).  I did this a long time ago and my brain isn't functioning properly
at the moment to be of any further help...
-tgq
#macro Geodesic(n,R,Obj)
  union{
    #if (n=0)
      object{Obj}
    #else
      #local nL=2^(n-1);
      #local i=-nL;
      #while (i<=nL)
        #local nS=4*(nL-abs(i));
        #if (nS=0)
            object{Obj translate<0,0,-R> rotate x*i*90/nL}
        #else
          #local j=0;
          #while (j<nS)
            object{Obj translate<0,0,-R> rotate x*i*90/nL rotate y*j*360/nS}
            #local j=j+1;
        #local i=i+1;
Date: 27 Aug 2002 16:20:23
Message: <3d6bdf07@news.povray.org>
"TinCanMan" <Tin### [at] hotmailcom> wrote:
> ... . The
> head).
If you're really doing "standard" triangulation of a sphere with equidistant
points, then it should be something like s*(4^n) triangles where s is the
number of the starting triangles (its easy if you start with an octaeder)
Date: 27 Aug 2002 16:44:11
Message: <3d6be49b@news.povray.org>
Tim Nikias <tim### [at] gmxde> wrote in message
news:3d6bab55$1@news.povray.org...
Start with a cube. If you ever want to color the hairs in any type of
organized fashion you will be glad you did. I played around with several
different ways of dividing a sphere, and this is by far the most versatile.
 -Shay
Date: 28 Aug 2002 00:55:05
Message: <3d6c57a9@news.povray.org>
This looks like the most easy one to implement and the example
pic shows that it really is what I'm looking for...
Thanks for this one...
Tim Nikias
Date: 28 Aug 2002 00:56:03
Message: <3d6c57e3$1@news.povray.org>
There are a lot of links, and the mathematical descriptions
are sometimes a little above me, but I'll keep the links and
see if I can find something more efficient and more versatile
than what Christoph posted. Nontheless, thanks!
Tim Nikias
> ABX
Date: 28 Aug 2002 00:58:15
Message: <3d6c5867$1@news.povray.org>
Are you referring to the method described in Christoph's
link on the bottom "Uniform Distribution - Hypercube rejection
method"? It does look interesting, solving how to let it us
a given number of positions might be interesting though...
Also, texturing the hairs shouldn't be too difficult anyways,
I can always use the base-position for calculations,
can't I?
Tim Nikias
versatile.
Date: 28 Aug 2002 01:12:45
Message: <3D6C5C89.D55978E4@pacbell.net>
Tim Nikias wrote:
> Hi all!
See Also - http://www.ogre.nu/sphere.htm
Ken Tyler
Date: 28 Aug 2002 12:33:18
Message: <3d6cfb4e@news.povray.org>
news:3d6c5867$1@news.povray.org...
> method"?
No, something much simpler. I am talking about taking a cube and inflating
it into a sphere. I found this pic on google:
http://www.truegrid.com/sphere.100.jpg .
Of course this doesn't give you as much freedom over how many points you
want, but it has other advantages. I had a macro which split up a sphere
three different ways, but I guess I killed it, because I cannot find it.
> can't I?
I am guessing that by "base-position" you mean the location of the hair
before or after it is wrapped around the sphere. If this is the case, then
the pigment will have to be placed in a 2D pattern which will represent the
sphere "unwrapped." With the inflated cube method, this 2D representation
can be a simple 't' shape if you don't mind just a little distortion. This
method will also return a point set much faster than any other I can think
of.
 -Shay
Date: 28 Aug 2002 18:59:43
Message: <3d6d55df$1@news.povray.org>
...snip...
Nope, I meant the actual position on the sphere.
As for speed, that might be true, but look at Christoph's link, that first
algorithm looks very promising to me...
Tim Nikias
Date: 28 Aug 2002 21:19:49
Message: <3d6d76b5$1@news.povray.org>
"Tim Nikias" <tim### [at] gmxde> wrote in message
news:3d6d55df$1@news.povray.org...
Still, you need to map which pigment to apply for any given position on the
sphere.
Looks very cool, but I wouldn't want to wait for over about 500 hairs. It
might take several days to parse.
 -Shay
Date: 29 Aug 2002 00:59:06
Message: <3d6daa1a$1@news.povray.org>
If I get to it, I'll script the algorithm today, then I'll
tell you, how long it does take...
Tim Nikias
Date: 29 Aug 2002 14:25:46
Message: <3d6e672a@news.povray.org>
news:3d6daa1a$1@news.povray.org...
Considering 10K hairs would require literally BILLIONS of operations, we may
have to wait more than one day for your response!!<g> The code will be very
useful for other things, however.
 -Shay
Date: 29 Aug 2002 16:29:27
Message: <3d6e8427@news.povray.org>
So. Code cooked.
Well. Hm. You were right.
*crunching on a woodstick*
Takes ages for decent amounts of nodes.
Makes interesting animations though!
*sigh*
Well. I'll be trying some other algorithms
(hypercube to begin with something that'll
work FAST).
By the way... What could the code be used for?
Tim Nikias
may
very
Date: 29 Aug 2002 17:44:00
Message: <3d6e95a0@news.povray.org>
news:3d6e8427@news.povray.org...
Gerbera seed clusters for a close-up?
-Shay
Date: 29 Aug 2002 18:39:32
Message: <3d6ea2a4@news.povray.org>
Didn't I use fibonacchi for that already?
Tim Nikias
