POV-Ray : Newsgroups : povray.general : Placing objects on spheres... Server Time
24 Aug 2025 05:14:39 EDT (-0400)
  Placing objects on spheres... (Message 1 to 10 of 18)
Subject: Placing objects on spheres...
Date: 27 Aug 2002 12:39:49
Message: <3d6bab55$1@news.povray.org>
Hi all!
I'm looking for a method to calculate positions in order
to place objects with N radius onto a sphere with R radius.
These small objects shouldn't intersect each other (as less
as possible), but cover the entire sphere.
I need this to generate positions for some CSG-Hairs to
get a furball (the last try was suspected to be fireworks...)
I'm thankful for any link or help regarding this, and do
note that I'm the kinda guy who likes to script the required
algorithms himself...
Thanks,
Tim
Tim Nikias
Email: Tim### [at] gmxde
Subject: Re: Placing objects on spheres...
Date: 27 Aug 2002 12:46:31
Message: <q3bnmu0sbvs20bve02r9rv0lh3t3oor8rh@4ax.com>
http://www.math.niu.edu/~rusin/known-math/index/spheres.html
ABX
Date: 27 Aug 2002 12:47:26
Message: <3D6BAD1E.2007FB01@gmx.de>
Tim Nikias wrote:
> Hi all!
http://astronomy.swin.edu.au/~pbourke/geometry/spherepoints/index.html
Date: 27 Aug 2002 14:54:53
Message: <3d6bcafd$1@news.povray.org>
Try dissecting this macro I wrote a couple of years ago.  It basically
triangulates a sphere to 'n' iterations (like a geodesic sphere).  The
limitation here is that you are restricted to the number of points related
to the iteration level 'n' (I don't know the formula off the top of my
head).  I did this a long time ago and my brain isn't functioning properly
at the moment to be of any further help...
-tgq
#macro Geodesic(n,R,Obj)
  union{
    #if (n=0)
      object{Obj}
    #else
      #local nL=2^(n-1);
      #local i=-nL;
      #while (i<=nL)
        #local nS=4*(nL-abs(i));
        #if (nS=0)
            object{Obj translate<0,0,-R> rotate x*i*90/nL}
        #else
          #local j=0;
          #while (j<nS)
            object{Obj translate<0,0,-R> rotate x*i*90/nL rotate y*j*360/nS}
            #local j=j+1;
        #local i=i+1;
Date: 27 Aug 2002 16:20:23
Message: <3d6bdf07@news.povray.org>
"TinCanMan" <Tin### [at] hotmailcom> wrote:
> ... . The
> head).
If you're really doing "standard" triangulation of a sphere with equidistant
points, then it should be something like s*(4^n) triangles where s is the
number of the starting triangles (its easy if you start with an octaeder)
Date: 27 Aug 2002 16:44:11
Message: <3d6be49b@news.povray.org>
Tim Nikias <tim### [at] gmxde> wrote in message
news:3d6bab55$1@news.povray.org...
Start with a cube. If you ever want to color the hairs in any type of
organized fashion you will be glad you did. I played around with several
different ways of dividing a sphere, and this is by far the most versatile.
 -Shay
Date: 28 Aug 2002 00:55:05
Message: <3d6c57a9@news.povray.org>
This looks like the most easy one to implement and the example
pic shows that it really is what I'm looking for...
Thanks for this one...
Tim Nikias
Date: 28 Aug 2002 00:56:03
Message: <3d6c57e3$1@news.povray.org>
There are a lot of links, and the mathematical descriptions
are sometimes a little above me, but I'll keep the links and
see if I can find something more efficient and more versatile
than what Christoph posted. Nontheless, thanks!
Tim Nikias
> ABX
Date: 28 Aug 2002 00:58:15
Message: <3d6c5867$1@news.povray.org>
Are you referring to the method described in Christoph's
link on the bottom "Uniform Distribution - Hypercube rejection
method"? It does look interesting, solving how to let it us
a given number of positions might be interesting though...
Also, texturing the hairs shouldn't be too difficult anyways,
I can always use the base-position for calculations,
can't I?
Tim Nikias
versatile.
Date: 28 Aug 2002 01:12:45
Message: <3D6C5C89.D55978E4@pacbell.net>
Tim Nikias wrote:
> Hi all!
See Also - http://www.ogre.nu/sphere.htm
Ken Tyler
