Subject: Starfield: pow(10,6) spheres or an isosurface?
Date: 26 Aug 2002 21:52:26
Message: <3d6adb5a$1@news.povray.org>
I didn't quite like how the starfield pigments looked in a sky_sphere, so
I'm going to make my own.
Q: which will render faster,
i) pow(10,6) spheres, or
ii) an isosurface of say the f_noise3d at low threshold and a huge scale?
Be a manly man, plot a few hundred actual stars' relative positions.
(Actually I'd like to try that, I just need to get a nice
comma-delimited text file of their positions)
Tim Cook
Version: 3.12
Subject: Re: Starfield: pow(10,6) spheres or an isosurface?
Date: 27 Aug 2002 00:44:44
Message: <3d6b03bc$1@news.povray.org>
You can find this already somewhere on the net,
let me just see...
http://www.starbase1.co.uk/downloads.htm
Is what I found, but it's not what I was looking for.
I found a set of include files last year somewhere
where you could include well over 200.000
stars... A little searching on google should do the
job.
Tim
Tim Nikias
Email: Tim### [at] gmx de
> let me just see...
> job.
http://www.geocities.com/CapeCanaveral/Galaxy/8018/ ???
Ken Tyler
If you're serious about that, I can send you a list in this format
"Alpheratz",0,8,23.30,+29,5,26.00,-0.163,
"Caph",0,9,10.70,+59,8,59.00,-0.181,
"Eps Phe",0,9,24.70,-45,44,51.00,-0.181,
"Algenib",0,13,14.20,+15,11,1.00,-0.012,
"Iot Cet",0,19,25.70,-8,49,26.00,-0.036,
"Iot Scl",0,21,31.20,-28,58,54.00,-0.074,
"Bet Hyi",0,25,45.10,-77,15,15.00,0.324,
"Ankaa",0,26,17.00,-42,18,22.00,-0.396,
"Bet1 Tuc",0,31,32.70,-62,57,29.00,-0.054,
"Pi And",0,36,52.90,+33,43,10.00,-0.004,
"Del And",0,39,19.70,+30,51,39.00,-0.091,
Each line contains the star name (If no actual name, then the Flamsteed
letter and constellation. If no Flamsteed, then Henry Draper number. If
no HD then Hipparcos number).
The next three numbers are hours, minutes, seconds of the Right
Ascension.
The next three numbers are degrees, minutes, seconds of the Declination.
(Note, only the degrees show the sign but you'll have to remember to
apply it to the degrees and seconds).
The final number is the base magnitude, which indicates the brightness
of the star.
I have such a list for all stars brighter than magnitude 7.5, that's
15654 stars. The file is about 668 Kb in size.
Mike Williams
Gentleman of Leisure
Mike Williams <mik### [at] econym demon co uk> wrote in
news:Aj0### [at] econym demon co uk
Please eamil it to me (pov### [at] raf256 com)
what exacly are this numbers - with can be used as <x,y,z> coordinates ?
i should run faster
Have Fun!
Rafal 'Raf256' Maj typed:
> Mike Williams <mik### [at] econym demon co uk> typed:
Ditto on that. (tim### [at] scifi-fantasy com)
Also a nice macro to convert from decl/ascension to XYZ...
tho the geocities pov include looks useful, too...
Tim Cook
Version: 3.12
I take that back. That geocities include file is damn cool.
Tim Cook
Version: 3.12
Date: 27 Aug 2002 08:31:34
Message: <3d6b7126$1@news.povray.org>
"Mike Williams" <mik### [at] econym demon co uk> wrote in message
news:Aj0### [at] econym demon co uk...
> of the Right Ascension.
I'm rendering an anim of spheres right now. Since the anim involves the
travel of a spacecraft, I wanted a "3d" look to it, not merely white points
on a skysphere.
Date: 27 Aug 2002 08:31:54
Message: <3d6b713a$1@news.povray.org>
Thank you, the one straight man in the crowd.........
I would also appreciate having this list. =)
- Slime
[ http://www.slimeland.com/ ]
On Tue, 27 Aug 2002 11:31:39 -0400, "Slime" <slm### [at] slimeland com> wrote:
so many orders ?
what about some binary group or web upload ?
ABX
Date: 27 Aug 2002 12:17:47
Message: <3d6ba62b@news.povray.org>
Yup, that was the one I was referring to...
Thanks, Ken.
*bows before the great master of links*
Tim Nikias
Sorry to de-lurk, but I also would be extremely interested in that list. My
email is pov### [at] ubidubium net. Thanks.
Heh, what have I started....(actually I don't think I'll need the list,
as the one from the geocities site looks more than sufficient)
Tim Cook
Version: 3.12
Date: 27 Aug 2002 13:40:13
Message: <3d6bb97d$1@news.povray.org>
you are joking, aren't you?
Ascension.
of the star.
Convert the Right Ascension and Declination to degrees. Place the star a
long distance away in the z direction. Rotate by -x*RA then y*Dec (or is
it -y*Dec).
Mike Williams
> so I'm going to make my own.
A mesh with triangles will render quicker, and use far less memory.
If the triangles are far enough away, they look just like spheres
that are far, far away.
#local SEED=seed(0);
mesh {
#local iI=0;#while(iI<NUMBER_OF_STARS)
#local vR=<rand(SEED),rand(SEED),rand(SEED)>*360;
triangle {
vrotate(<0,1,DISTANCE>,vR),
vrotate(<-97/112,-.5,DISTANCE>,vR),
vrotate(< 97/112,-.5,DISTANCE>,vR)
#local iI=iI+1;#end
no_shadow
pigment { rgb 1 }
finish { ambient 1 diffuse 0 }
translate CAMERA_POSITION // makes stars appear stationary
Set DISTANCE so that the triangles just become points.
>so many orders ?
That sounds like a good idea.
<http://www.econym.demon.co.uk/stars.zip> 219 kb
Mike Williams
a
is
> it -y*Dec).
It is worth mentioning that RA is measured in hh:mm:ss, so the way to
convert it to degrees is simply to multiply it by 15, i.e. ( hours +
( minutes / 60 ) + ( seconds / 3600 ) ) * 15
Declination is already in degrees, so no need to convert!
Date: 29 Aug 2002 15:05:37
Message: <3d6e7081$1@news.povray.org>
"Jan Walzer" <jan### [at] lzer net> wrote in message
news:3d6bb97d$1@news.povray.org...
scale?
certainly there's got to be some crossover for
pow(10, n) spheres
vs.
an isosurface whose containment sphere contains roughly pow(10, n)
particles.
