POV-Ray : Newsgroups : povray.general : does #break work as intended with #if statements? Server Time
22 Oct 2026 21:53:31 EDT (-0400)
  does #break work as intended with #if statements? (Message 1 to 11 of 11)
Subject: does #break work as intended with #if statements?
Date: 19 Aug 2002 14:19:19
Message: <3d6136a7$1@news.povray.org>
I expected that #break would ignore the #end in an #if statement and proceed
to the #end of the current #while loop, but this is not the case. Is this
intended?
An example:
#while (True)
  #if (True) #break #end
Will loop forever. It would sure help speed up some code if this worked
differently. Is there a reason why #break behaves the way it does with #if
statements?
Just an additional thought. It would also be very cool if
 #while (condition & condition)
would not evaluate the second condition if the first were false. I think
that implementing this might cause a slow-down in code where the behavior
was not needed, however.
 -Shay
Subject: Re: does #break work as intended with #if statements?
Date: 19 Aug 2002 14:33:07
Message: <3D6139E2.C69ADD83@gmx.de>
> intended?
Why do you think #break is valid in #while or #if?
#break can only be use in #switch.
Date: 19 Aug 2002 14:41:08
Message: <3d613bc4$1@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote in message
news:3D6139E2.C69ADD83@gmx.de...
That explains it then, doesn't it. I just assumed that it was valid because
it is a keyword used in other languages. Perhaps the use of this word will
be expanded in 4.0. Thank you.
 -Shay
Date: 20 Aug 2002 03:39:36
Message: <3D61F252.20203@free.fr>
And that's good enough.
Because others do it is no excuse. The scene has to be described, not
processed. There is no need for #break in #while/#if, if you can keep
your mind on the right track.
I'm afraid someone come up with a "#goto" idea... followed by a blury
"#continue"
I hope and wish not!
Date: 20 Aug 2002 05:28:03
Message: <3d620ba3@news.povray.org>
In article <3D6### [at] freefr> , Le Forgeron <jgr### [at] freefr>
> "#continue"
I agree.
    Thorsten
e-mail: tho### [at] trfde
Date: 20 Aug 2002 06:11:25
Message: <3d6215cd@news.povray.org>
So now we are two wishing that pov would use short-circuit evaluation. It
is still on my wish-list for 4.0. See
http://news.povray.org/povray.general/18724/ for further discussion about
it.
- Micha
http://objects.povworld.org - the POV-Ray Objects Collection
Date: 20 Aug 2002 09:28:29
Message: <3d6243fd@news.povray.org>
> I agree.
  I don't. #break and #continue would be useful inside loops. Without them
you have to make kludges which make parsing slower.
Date: 20 Aug 2002 09:40:05
Message: <3d6246b5@news.povray.org>
In article <3d6243fd@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Not with properly designed algorithms ;-)
    Thorsten
Date: 20 Aug 2002 18:21:27
Message: <chrishuff-02B72D.17070020082002@netplex.aussie.org>
In article <3d6246b5@news.povray.org>,
I have occasionally found break useful, but rarely...I've never needed
either one in POV. And I've never had to use continue.
In some cases I think using them is a good thing, I don't consider them
a forbidden statement like goto. You just need to be sure you need them,
and I don't think their absence is a problem for POV. Same as for and
do-while loops: would be nice but isn't necessary.
http://tag.povray.org/
Date: 20 Aug 2002 20:55:29
Message: <3d62e501@news.povray.org>
While not strictly necessary, it would be nice to have a C style "for" loop.
I've toyed around with the idea of implimneting it as a macro, but the
deliniators tend to get in the way.  Has anyone already done this?  If not
I'll keep working on my own.
JFMILLER
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
them
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Date: 20 Aug 2002 21:19:24
Message: <chrishuff-79AC73.20045820082002@netplex.aussie.org>
In article <3d62e501@news.povray.org>,
I am pretty certain it is impossible as a macro, it would need to be
done as a patch. The closest you could do is take the loop body as a
string parameter and write the entire loop to an include file, then
include that file. You can't have the beginning of the loop block in one
macro/include file and end it elsewhere.
