POV-Ray : Newsgroups : povray.general : blob- No pigment type warning Server Time
22 Oct 2026 21:52:57 EDT (-0400)
  blob- No pigment type warning (Message 1 to 17 of 17)
Subject: blob- No pigment type warning
Date: 17 Aug 2002 19:10:42
Message: <3d5ed7f2@news.povray.org>
blob{
    sphere{ -x/2, 1, 1 pigment{ red 1 } }
    sphere{ x/2, 1, 1 pigment{ green 1 } }
Pov 3.5 (and 3.1) complain no pigment type given. Am I missing
something simple? I've only just noticed this while updating an old
3.1 scene but docs 6.5.1.1 seem to say above is legal.
Alf
Subject: Re: blob- No pigment type warning
Date: 17 Aug 2002 20:57:25
Message: <3D5EF0F4.7040804@scifi-fantasy.com>
Alf Peake wrote:
> blob{
A sphere needs X, Y, Z, radius, and colour.  What you
have there is being interpreted as the first four of
those.
Tim Cook
Version: 3.12
Date: 17 Aug 2002 21:59:28
Message: <3d5eff80@news.povray.org>
"Alf Peake" <alf### [at] peake42freeservecouk> wrote in message
news:3d5ed7f2@news.povray.org...
> blob{
The "no pigment type given" message is just a warning.  Though the blob
itself has no pigment, what you have specified is perfectly legal.
Robert Chaffe
http://www.donovansweb.com/~chaffe/
Date: 17 Aug 2002 23:42:24
Message: <3d5f17a0@news.povray.org>
  Wrong. What a spherical blob component needs is: vector, float, float
Date: 17 Aug 2002 23:42:59
Message: <3d5f17c3@news.povray.org>
  It's just a harmless bug. Shouldn't affect rendering in any way.
Date: 18 Aug 2002 00:21:49
Message: <chrishuff-FC0680.23083917082002@netplex.aussie.org>
In article <3D5### [at] scifi-fantasycom>,
 "Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote:
> Alf Peake wrote:
> > blob{
> those.
That is not even close to correct. Spherical blob components take a
vector for the center and a float radius, like the sphere primitive, and
an additional strength float value. You can also specify a texture for
individual components. You do not specify a color, but you can specify
only the pigment of a texture. This is exactly what is specified here.
This warning (not an error) is caused by the fact that the blob shape on
the whole doesn't have a texture defined. This is usually a mistake, so
it produces a warning. The components themselves have textures, so it
will render fine.
http://tag.povray.org/
Date: 18 Aug 2002 04:01:36
Message: <3D5F545F.4050207@scifi-fantasy.com>
>>those.
 > components take a vector for the center and a float
 > radius, like the sphere primitive, and an additional
My statement, as it stands by itelf, is correct; I
misunderstood Alf's code because I'm not familiar
with blobs.  A SPHERE does need the five components
I mentioned.  However, what was being talked about
wasn't spheres, it was sphere COMPONENTS of a blob.
Tim Cook
Version: 3.12
Date: 18 Aug 2002 04:11:16
Message: <3D5F56A3.828D7867@gmx.de>
No, as Chris Huff said, a sphere needs a vector for the center and a float
for the radius.  A warning is issued if no texture is given in either the
sphere itself or in a wrapping CSG structure.
So nothing like 5 components, see also the docs, section 6.5.1.9:
SPHERE:
    sphere
        <Center>, Radius
        [OBJECT_MODIFIERS...]
Date: 18 Aug 2002 05:05:25
Message: <3D5F6355.2090302@scifi-fantasy.com>
> SPHERE:
>     sphere
>         <Center>, Radius
I counted the texture modifier as a single component;
center has 3 components (x, y, and z), then there's the
radius.  that leaves us with 5 components.
Tim Cook
Version: 3.12
Date: 18 Aug 2002 05:11:48
Message: <3D5F64D3.ECA3C521@gmx.de>
> > SPHERE:
> >     sphere
> >         <Center>, Radius
Not a very good idea, 'sphere { 0, 1 }' is perfectly legal and i don't see
any five components.
Date: 18 Aug 2002 06:20:34
Message: <3d5f74f2@news.povray.org>
I wouldn't call it a bug ...
The BLOB-Object has no pigment ... so it complains ...
does it also complain, if there's a #default given?
if so, then I think one could talk about a mistake in the
design, but as it stands atm I think it should complain
even if all the components have a pigment attached, because
the warning isn't thrown by a component, that complains
about a missing pigment but it comes from the blob, which
has, in fact no pigment ...
Date: 18 Aug 2002 07:23:52
Message: <3d5f83c8@news.povray.org>
"Jan Walzer" <jan### [at] lzernet> wrote in message
news:3d5f74f2@news.povray.org...
I see nothing wrong with the completed render.
No. I had removed a #default texture and then noticed this warning.
Adding a pigment{rgb 0} outside the sphere components removes the
warning but slows the render.
Alf
Date: 18 Aug 2002 07:35:34
Message: <3d5f8686$1@news.povray.org>
there shouldn't be anything wrong ...
really ... this is interesting ...
Are you really sure about the slowdown?
this could really be a misdesign then ...
... but I'm not programmer enough, to prove that ...
Date: 18 Aug 2002 12:16:43
Message: <chrishuff-D3ED85.11033518082002@netplex.aussie.org>
No, your statement is incorrect. A sphere requires 2 parameters, a
vector for the center and a scalar radius. A sphere blob component can
take 3, the additional one is a strength parameter. Neither of them take
a color value.
Date: 18 Aug 2002 12:28:30
Message: <3d5fcb2e@news.povray.org>
  A CSG does not complain about not having a pigment defined if every
subcomponent has a pigment defined. IMHO the blob object should work in
the same way.
Date: 18 Aug 2002 18:14:45
Message: <3d601c55@news.povray.org>
news:3d5f8686$1@news.povray.org...
My old scene used a 1000 component blob with a calculated texture for
each component. I remember moving the finish from the texture block to
the end of the blob object and not being happy with the new time
(megapov 0.4). I've just tried this again with pov 3.5 and can see no
difference in render times now.
Alf
Date: 22 Aug 2002 10:16:10
Message: <3d64f22a@news.povray.org>
news:3D5F64D3.ECA3C521@gmx.de...
> > > SPHERE:
> > >     sphere
> > >         <Center>, Radius
    And if you're gonna expand a vector out and say it has 3 components, you
should expand out the texture modifier as well, and it's sub-components, and
all their sub-components, and.... So, a sphere takes an _infinite_ number of
components... ;)
Pandora/Scott Hill/[::O:M:C::]Scorpion
Software Engineer.
http://www.pandora-software.com
