Does anyone know of any conversion utility that can take one of
WorldMachine's 16-bit (or more) output formats (Such as Terragen TER) and
convert it to a format that POV-Ray can read (without returning to 8 bits)?
- Slime
[ http://www.slimeland.com/ ]
> - Slime
Sure, somthing like
height_field{
function X_res,Y_res {
pattern{
image_map{tga "HF.tga"}
rotate -90*x
translate <-,.5,0,-.5>
// WARNING: UNTESTED CODE
=RAY=
In article <web.3d4f2f4bbaf777fe264908380@news.povray.org>,
> Sure, somthing like
> height_field{
> pattern{
> rotate -90*x
Not sure what you are suggesting here...the height_field shape can use
anything an image_map can use, so running the image through a function
is no help at all. And it looks like you misread "TER" as "TGA".
Christopher James Huff <chr### [at] mac com>
POV-Ray TAG e-mail: chr### [at] tag povray org
Christopher James Huff wrote:
>In article <web.3d4f2f4bbaf777fe264908380[at]news.povray.org>,
>> Sure, somthing like
>> height_field{
>> pattern{
>> rotate -90*x
I saw the "such as" and I know WorldMachine exports greyscale TGAs. Also,
the docs explain that TGA HFs aren't greyscale. See 6.5.1.5 Paragraph 13
(or so).
=RAY=
> Sure, somthing like
> height_field{
> pattern{
> rotate -90*x
nonono, the targas that WorldMachine outputs are greyscale; they only have 8
bits of depth per pixel. I'd like to use one of the other output formats and
convert it to, perhaps, that special kind of targa with the red and green
channels used separately for 16 bits of information.
A POV-Ray SDL script can't do this for me.
Slime
I jump through the following hoops (and not always w/o tripping):
WM -> save as *.TER
Terragen -> load then save in *.RAW format (16 bit, Motorola byte order)
HCR-Edit -> load then save as *.PNG, *.TGA, etc...
....you asked.
Abe
> - Slime
>WM -> save as *.TER
>.....you asked.
>Abe
>> - Slime
There are some Terragen export plugins (SOPack) for POV-Ray HFs, BMPS, ect,
but I'm not sure about the 16 bit aspect.
=RAY=
On Mon, 5 Aug 2002 21:06:57 -0400, "Slime" <slm### [at] slimeland com> wrote:
Yes, today my brother wrote two utilities - one converts the 32-bit
float format from WM to 16-bit raw integer (that PhotoShop can read),
and the other converts from that to PNG. He's merging them into one at
the moment, cleaning up and adding a more user-friendly set of
command-line switches. Expect the source really soon, and if we can
get our hands on Borland C++ 5.5, a Windows binary (you can always
build your own Linux one if you want to).
The utilities work and I'm already using them :)
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] vip bg
TAG e-mail : pet### [at] tag povray org
Send send!!! =)
That'd be great if I could use those...
- Slime
> Yes, today my brother wrote two utilities ...
Is there anything he can't do? ;) Tell him he rocks and that we'd like to
see the source soon. :)
Great! Well, I already use a converter suggested by the creator of WM.. It's
a less elegant choice but until your utilities are ready it will do fine.
1) Output from WM to Terragen file.
2) Load into Wilbur. Expand range of values 0 to 1 into 0 - 65535
3) Output as 16bit POV-TGA
Wilbur can be downloaded here:
http://www.ridgenet.net/~jslayton/software.html
Hugo
By the way,
If someone thinks it could be useful to have the same color maps in POV-Ray
as those used in WorldMachine previews, I wrote a converter. It simply read
the color maps into POV pigments.
Posted to povray.text.scene-files
Hugo
On Tue, 6 Aug 2002 17:02:16 -0500, "Tony[B]" <ben### [at] catholic org>
Sure thing, if I get to see him soon - he went out for a football
game. Meanwhile, I took over merging the (now) 3 programs into one (3
because he decided he didn't like the command line lib in glibc [or
gcc?] and wrote his own one). That is, when I'm taking a rest from the
Flayer Dungeon on Hell :)
Don't worry, I won't have much time to screw things up - he'll be back
early tomorrow (if 2 am counts).
I couldnt find any referance to expanding the range of values...
Could you tell me how it is done? Please? Thanks.
> > into 0 - 65535
Hmm, you have downloaded Wilbur, I suppose? I found out, that simply loading
and exporting the file won't give you a nice 16bit image for POV.. I guessed
that expanding the values would solve the problem, and it did.. Here's how
to do it:
Load the file.
Go to menu: Surface / Point Process / Scale
In the popup window, select scaling type: To Range
Enter the values 65535 as "Highest" and 0 as "Lowest"
Click Ok.
Save the file as "POV Targa surface 16bit".
And by the way, there won't be any visible change of the image in Wilbur,
after you scaled it. But there will be a big difference in POV! ;o)
Hugo
>>> into 0 - 65535
I have had Wilber arround for a few years. I got the
newest version about 2 months ago.
> Here's how to do it:
> Load the file.
> Click Ok.
Thanks, I missed that one.
umm ... I have a scene that needs some work, got to go.
