Hi all,
I unfortunately miss that feature. I've a Linux SMP machine and would like
to provit from it in my POV-Ray times as well ;)
I just made a picture with radiosity and it's still computing - since 3 +1/2
hours :(((. It would be 2x faster if it would use both CPUs.
This could be implemented for example by having 2 processes with concurrent
pixel computation. (that's how I'd implement it ;)
Thanks,
Christian Parpart.
p.s: I hope that some developers are watching to the NG.
Oh, well, shucks, why didn't we think of that? It's so much easier than
the way we were planning on doing it, where the processors vote on the colors
of all of the pixels.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Ron Parker inspired the electrons to say:
>> concurrent pixel computation. (that's how I'd implement it ;)
> colors of all of the pixels.
Looks interesting, but not fast enough IMO. When do you think of a first
beta release of it? I'd beta test it (any algorithm you chose).
Well, I didn't take a look at your (old) sources yet, all I know is that
it's written in (plain?) C and I unfortunately prefer C++ and their design
patterns ;) But if your API to the POV-Ray Backend is clear I'd really like
to take a look at it and write it myself.
Just note, that I'm using Linux with GCC 3.1. wo I can't produce windows
binaries for windows testing.
How do you think?
Greets,
Christian Parpart
p.s.: but the source isn't _still_ available.
Christian Parpart inspired the electrons to say:
> +1/2 hours :(((. It would be 2x faster if it would use both CPUs.
http://cparpart.surakware.net/public/water.png (original)
http://cparpart.surakware.net/public/water.jpeg (converted)
It really used 4 hours 38 minutes on a dual machine.
AMD AthlonMP 1500+ 2CPUs, 1GB RAM.
amazing.
Cheers,
Christian.
On Wed, 31 Jul 2002 16:45:13 -0400, Christian Parpart quoth:
> Hi all,
> like to provit from it in my POV-Ray times as well ;)
To give a non-sarcastic answer:
This topic comes up so often that it is mentioned both in the VFAQ and
the manual. RTFM.
Mark
> easier than the way we were planning on doing it, where the
> processors vote on the colors of all of the pixels.
Simple majority or 2/3rds?
Tim Cook
Version: 3.12
And if one of the CPUs is really offended by a color, can it be blocked
in committee and prevented from ever coming to a floor vote?
And what about filibusters?
I'm starting to understand why this hasn't been implemented. It sounds
very complicated. Just the task of implementing Robert's Rules of Order
would be overwhelming.
"Christian Parpart" <cpa### [at] surakware net> wrote in message
news:3d484c5a@news.povray.org...
+1/2
Only 3 1/2? I can make a reflective sphere over a checkered plane take that
long to render, w/o radiosity :)
...Chambers
On Wed, 31 Jul 2002 22:45:13 +0200, Christian Parpart <cpa### [at] surakware net>
Please spend some time:
- reading documentation
- digging newsgroups
- searching website
all at povray.org.
Your a few years long working with pov means
nothing when you are asking such questions.
This is really serious advice. IIRC I have spend more than
year reading all important groups. Then I send first post.
There goes a big knowledge follow pov-community. Don't waste
their time if they already answered many of question.
ABX
"Ed Jackson" <eja### [at] iastate edu> wrote in message
news:pan### [at] iastate edu...
Well, as you know, the colors must all be politically correct, these rules
are difficult to express in algorithms (as they seem to change every few
months).
-- Chris
>> blocked in committee and prevented from ever coming to a floor vote?
> rules are difficult to express in algorithms (as they seem to change
> every few months).
perhaps something involving a little MathML would help, we should set up a
steering commitee....
PGP Public Key
Version: 6.0.377 / Virus Database: 211 - Release Date: 15/07/2002
Christian Parpart <cpa### [at] surakware net> wrote in
Stupid question... why not just :
CPU-1 render lines 0..160
CPU-2 render lines 160..320
etc ?
or CPU-1 render every n*2 pixel, and CPU-2 (n*2)+1 pixel in each line
"Rafal 'Raf256' Maj" <raf### [at] raf256 com> wrote in
news:Xns### [at] 204 213 191 226
renders can be run as completly separate thread's (like running 2 copys of
POV at once, each on diffrent CPU). Disadvantage is duplicating memory, and
dual parsing for each process.
Second solution is :
Parsing scene - only one CPU
Shooting photons - one CPU,
or give 1-st, 3,5 light-source to 1-CPU and
2,3,6 to 2-CPU, and/or do same with target objects
Sorting Photons - there probably are algorithms for sorting on 2-CPU's
Radiosity pre-trace - not shure, maybe divide scene into separate pixels,
as in Render step
Render - give half pixels to one CPU, and half to others, run both
renders as separate threads tahat will share memory with
Photons/Vista/Scene/etc data
On 1 Aug 2002 09:20:35 -0400, "Rafal 'Raf256' Maj" <raf### [at] raf256 com> wrote:
> Stupid question...
http://www.povray.org/search/?s=multiple+processors
ABX
"Rafal 'Raf256' Maj" <raf### [at] raf256 com> wrote in message
news:Xns### [at] 204 213 191 226...
I think this is what some people do - obviously it depends on scenes where the
render time is the issue, rather than parse time. With radiosity, it all gets
more complicated.
Question: Do photons break this method, or are they more "fixed" than radiosity?
(I assume the latter).
ABX wrote:
>> Stupid question...
not a stupid question, a very valid and *required* feature
PGP Public Key
Rick [Kitty5] wrote:
> ABX wrote:
>>>Stupid question...
Which has been answered from a long time already.
For the technically minded, you "just" have to rewrite the
rendering engine so that no global/static variable is used with
write/modify access. The bad news is that it is only the first
step, and that there is a lot of such variable/arrays,
specially as optimisation of some patterns and computation
of shadow & reflection.
The following steps introduce non-portability unless
you restrict portability to something like Posix thread
compliant systems (or whatever you choose for multiple processors).
Anyway, it is bad...
