POV-Ray : Newsgroups : povray.general : Overlaping objects with different ior values Server Time
28 Nov 2026 10:24:00 EST (-0500)
  Overlaping objects with different ior values (Message 1 to 48 of 48)
Subject: Overlaping objects with different ior values
Date: 21 Jul 2002 04:19:23
Message: <3d3a6e8b@news.povray.org>
Considering two objects with ovelaping area. Like:
sphere{<-1,0,0>,2 pigment{rgbt 0.8} finish{ior 1.5}}
sphere{<1,0,0>,2 pigment{rgbt 0.8} finish{ior 1.2}}
How does POV-Ray handle this? In the intersection of the spheres there are
two ior values defined. Which one does POV use?
- Micha
Subject: Re: Overlaping objects with different ior values
Date: 21 Jul 2002 05:57:31
Message: <3d3a858b@news.povray.org>
"Micha Riser" <mri### [at] gmxnet> wrote in message
news:3d3a6e8b@news.povray.org...
My 2c.
Since ior is defined in the finish a surface property), the overlap is
irrelavent?
The only place that this would be an issue is on co-incident surfaces, which
are a no-no anyway (for presumably exactly this kind of reason).
Date: 21 Jul 2002 06:53:56
Message: <Xns925282A371CD5raf256com@204.213.191.226>
Micha Riser <mri### [at] gmxnet> wrote in news:3d3a6e8b@news.povray.org
> are two ior values defined. Which one does POV use?
If You have i.e. big box (A) and small (B) placed like :
aaaaa
abbba
abbba
abbba
aaaaa
Then in 'a' area (that is inside of object A) - ior will be as in A object
In 'b' are - with is both inside A and B - AFAIK ior will be like in 'B' -
because this object is closest to tested points - in other words - ray
intersect surface of B at last.
in area 'A' ray traveled trought A surface so ior is A
in 'B' tray traveled trought A, and later trought B - and the last value is
important
If You talk about two _ideal_ same objects in same space like
sphere { 0 1 } and sphere {0 1 } - this will always result errors, not only
in interior
Date: 21 Jul 2002 08:49:50
Message: <3d3aade9@news.povray.org>
> irrelavent?
  IOR should not be defined in the finish block,
but in the interior block.
Date: 21 Jul 2002 12:51:19
Message: <3d3ae686@news.povray.org>
> aaaaa
> abbba
> abbba
> abbba
> aaaaa
This case is clear as B is compleatly inside A. But what happens if A and B
only partly overlap?
> only in interior
No, that's not was I meant. Look closer at my example scene above.
- Micha
Date: 21 Jul 2002 13:00:33
Message: <Xns9252C0CB37C84raf256com@204.213.191.226>
Micha Riser <mri### [at] gmxnet> wrote in news:3d3ae686@news.povray.org
>>> there are two ior values defined. Which one does POV use?
>> aaaaa
>> abbba
>> abbba
>> abbba
>> aaaaa
> and B only partly overlap?
They should not overlap. At least - they can overlap in some not-connected
points, like sphere { y*0 1 } sphere { y*2 1 }. Point <0,1,0> is inside A
_OR_ inside B, the result is quite random - it deppends on implementation,
but if this is 1 separate pint - this artfact probably will not be visible.
If the overlap area is bigger, like
cone { y*0 1 y*1 1 }
cone { y*1 1 y*2 1 }
then area with shape of cone { y*1 1 y*1 1 }will have random artefacts (it
can be i.e. black pixels)
Date: 21 Jul 2002 13:04:37
Message: <Xns9252C17CE93CEraf256com@204.213.191.226>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote in
news:Xns### [at] 204213191226
in other words - any objects in POV intersect, but intersection of objects
_surfaces_ can lead to errors it some cases (if objects, or it's parts are
too similar to each other)
Date: 21 Jul 2002 13:09:03
Message: <3d3aeaae@news.povray.org>
> irrelavent?
As Warp said ior is a interior property. It is allowed to be specified in
finish only for backwards compatibility. See chapter 6.6.1 of the
documentation.
I made some further test with CSG and ior. Obviously there is also a
problem when objects with different ior ar merged together/intersected.
Consider:
merge{ // or intersection{
Note that here ior is specified in finish where it does no longer belong to.
What ior does the resulting object have? Testing showed that POV-Ray uses
the ior value from the first object that has a finish{ior xy} defined for
the whole object.
However if I specify ior in interior as
  sphere{<-1,0,0>,2 pigment{rgbt 0.8} interior{ior 1}}
  sphere{<1,0,0>,2 pigment{rgbt 0.8} interior{ior 1.2}}
I get a different result. I cannot exactly say how POV treats this case
though... anybody?
- Micha
Date: 21 Jul 2002 13:11:19
Message: <3d3aeb37$1@news.povray.org>
From what I understand, the ior value comes into play whaent he ray passes
through a surface, so any time the ray passed through a surface of  either
sphere, that sphere's ior value would be applied even if the surface is
inside or intersects another surface.  On the other hand, if you apply a
'merge' to these two spheres, the surfaces inside the intersection are
removed so the image would come out quiet different looking.
-tgq
Date: 21 Jul 2002 13:14:54
Message: <3d3aec0d@news.povray.org>
>>> aaaaa
>>> abbba
>>> abbba
>>> abbba
>>> aaaaa
> visible.
I think we are talking of different things. With 'overlap' I do not mean
that big parts of the *surface* overlap. Obviously this has undefined
result. What happens if the objects have a partly common interior. Maybe
csg intersection is better to make you clear what I mean:
intersection{
  box{0,5 interior{ior 1.1}}
  box{2,6 interior{ior 1.2}}
This results in a box{2,5} but what ior is used?
Date: 21 Jul 2002 13:22:12
Message: <3d3aedc4@news.povray.org>
But when the spheres are merged a ray on the x-axe coming from -x to +x
would enter the merge at ior from the the first sphere. But the point where
it leaves the merge (<3,0,0>) the surface would have a different ior which
leads to the same problem as described in chapter 6.6.1 when ior was a
surface property.
Date: 21 Jul 2002 13:26:35
Message: <3d3aeecb@news.povray.org>
Judging with my limited understanding of what is happening, I think it's
quite clear.
As we are talking about a raytracer here, the ior acts directly on the ray,
which hits the object. That is, if the ray hits the object, the angle in
which it travels further is calculated from the current ior and the one of
the object it's hitting. If it hits another object, the same happens. If it
leaves the object the same happens. Ior has no effect if it is constant,
important are those points on the ray where the ior changes.
Now - in your example everything is clear - in overlapping areas the current
ior depends on the object which was hit as the second one. I might be wrong,
though.
Hope that helps and is absolute nonsense,
Marc-Hendrik
"Micha Riser" <mri### [at] gmxnet> schrieb im Newsbeitrag
> - Micha
Date: 21 Jul 2002 13:31:38
Message: <Xns9252C6121F1B4raf256com@204.213.191.226>
Micha Riser <mri### [at] gmxnet> wrote in news:3d3aec0d@news.povray.org
> mean that big parts of the *surface* overlap. Obviously this has
> undefined result. What happens if the objects have a partly common
> interior. Maybe csg intersection is better to make you clear what I
> mean:
> intersection{
hmm... render it and see what's the result :) set one's ior to 1.001 and
second to ior 2.0
btw. can You pleas NOT quote ENTIRE posts ?
Date: 21 Jul 2002 13:50:05
Message: <3d3af44d$1@news.povray.org>
where
> surface property.
See the image I posted in p.b.i.
The camera is orthographic and looking down on 6 sets of two stacked clear
spheres.
1st row: both spheres have an ior of 1.5
2nd row: bottom sphere has ior of 1.5, top sphere has an ior of 2.5
3rd row: bottom sphere has ior of 2.5, top sphere has an ior of 1.5
for each row, the left hand spheres are 'union'ed and the right hand ones
are 'merge'ed
as you can see, no two groups look the same.
-tgq
Date: 21 Jul 2002 14:28:26
Message: <3d3afd4a@news.povray.org>
>> intersection{
> second to ior 2.0
Of course I have done test renderings before. But always with spheres so
far and I have not been able to see what exactly happens. But this box
example is more interesting. See picture in p.b.i.
IMO it is a bug in POV-Ray. The ray passes through the box and is refracted
when it leaves it. That means it is refracted even though the ior before
the hit and after the hit both are 1.0.
To produce consistent results following has to be assured:
- transparent unions with iors are not allowed to overlap
- merge and intersection have to have the same ior within all parts
The first point can hardly be assured at parsing time. It could issue a
warning during rendering though.
The second point could be checked during parsing.
Usually I only quote as much as I consider neccessary to understand the
posting. No need to shout.
- Micha
Date: 21 Jul 2002 14:42:31
Message: <3d3b0097@news.povray.org>
refracted
This is not a bug, it is the intended operation as AFAIK.  Even though ior
is specified in 'interior'  it isn't treated as an interior property but
rather acts only on surfaces.  This is whay you can't have ior mapping or
variable iors within a single object.  When a ray passes through a surface
it is refracted according to the iors at that surface.  In your example only
the surface of the intersection that belonged to the box with an ior of 1
has an ior of 1, the other surface has the ior of 1.2 so when the ray hits
this face, with the 1.2 ior, it gets refracted as if the interior had an ior
of 1.2 and the exterior had an ior of 1.
-tgq
Date: 21 Jul 2002 14:55:54
Message: <3d3b03b9@news.povray.org>
> refracted
> only the surface of the intersection that belonged to the box with an ior
> of 1 has an ior of 1, the other surface has the ior of 1.2 so when the ray
> hits this face, with the 1.2 ior, it gets refracted as if the interior had
> an ior of 1.2 and the exterior had an ior of 1.
I do not think this behavior can be intended.
From the documentation part 6.6.1
"... It is totally illogical to have a ray enter an object with one index
or refraction and then recalculate with another index. The result is not an
average of the two ior values. Similarly it makes no sense to have a ray
enter at one ior and exit at a different ior without transitioning between
them along the way. ..."
That is the reason why ior was moved from finish to interior. But exactly
what one wanted to prevent happens with the merges boxes!
Another point to consider is that refraction is directional, so ior A ->
ior B gives a different result than B -> A. That means it has to be
distinguished between entering and leaving objects. Now at the back surface
of the box should the ray be refracted 1.0 -> 1.2 or 1.2 -> 1.0?
Date: 21 Jul 2002 15:32:03
Message: <3d3b0c33@news.povray.org>
an
Read the next two sentences:
POV-Ray only calculates refraction as the ray enters or leaves. It cannot
incrementally compute a changing ior through the interior of an object.
surface
1.2 -> 1.0  where the 1.0 is the ior (implied) of the space outside the box
(as opposed to the applied ior 1.0).  The ray is considered leaving this
surface, the suface has an ior of 1.2 going into empty space, ior 1.0,
therefore it would act as though the interior of the object had an ior of
1.2 at this surface.  At the front surface it acts as if the interior has an
ior of 1.0, no refraction.  As stated (though perhaps not as clearly as it
could) in 6.6.1, the ior should vary alng the interior of this object but
that is almost impossible to calculate properly.  Having a CSG object with
different iors on different parts will not produce any kind of realistic
results and I would consider poor coding practice (unless it is intended).
This is just a limitation of POV, not a bug though.
-tgq
Date: 21 Jul 2002 15:43:57
Message: <3d3b0efd@news.povray.org>
> box
> an
Okay, like this the refraction is always well defined. But it is rather
unlogical to refract from 1.2 -> 1.0 even though though the ray has never
been in space with ior 1.2.
Of course, a feature not a bug ;). What has the effort of moving ior from
finish to interior been worth if it is still possible that a ray enters at
one ior and leaves at another? IMO at least a warning should be issued.
- Micha
http://objects.povworld.org - the POV-Ray Objects Collection
Date: 21 Jul 2002 16:01:44
Message: <3d3b1328@news.povray.org>
But can you tell me conclusively what the interior ior of the intersection
object is, 1.0 or 1.2?  Sort of schrodinger's fridge*.
I don't know why it was moved other than in reality it is a property of the
interior rather than the surface regardless of how POV treats (calculates)
it.
yes, perhaps it would be helpful for debugging puprose to have POV warn you
when an object has more than one ior applied.
-tgq
*http://angryflower.com/schrod.gif
Date: 21 Jul 2002 16:16:24
Message: <Xns9252E1FFF6E60raf256com@204.213.191.226>
"TinCanMan" <Tin### [at] hotmailcom> wrote in
news:3d3b1328@news.povray.org
>> rather unlogical to refract from 1.2 -> 1.0 even though though the
>> ray has never been in space with ior 1.2.
> intersection object is, 1.0 or 1.2?  Sort of schrodinger's fridge*.
I suggest to make intersection and later apply interior/material to entire
object.
Date: 21 Jul 2002 16:24:06
Message: <3d3b1866@news.povray.org>
In article <3d3b0efd@news.povray.org> , Micha Riser <mri### [at] gmxnet>  wrote:
There were reasons and it had been explained when 3.1 was released also I
unfortunately do not recall where (nor do I have the time these days to look
it up).  If it isn't explained anywhere in the (3.1) docs, I would suggest
to find someone who has an archive of the CompuServe Go POVRAY forum...
The way ior works right now is definitely as it should.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 21 Jul 2002 16:29:25
Message: <3d3b19a4@news.povray.org>
No, IMO it is not defined (and cannot be defined in a logical and
consistent way). That is why I think there is something to be changed with
POV-Ray, e.g. issue a warning.
Date: 21 Jul 2002 16:43:34
Message: <3d3b1cf6@news.povray.org>
> object.
Sure. But I want to test the limits of POV-Ray ;)
The reason why I came up with this question was that I am writing my own
little ray-tracer and have to find a way to handle refraction with csgs.
So I am not looking from the user's point of view (I want to do X. How do I
tell the program to do so) but from the programmer's point of view (The
syntax allows the users to specify X. How should the program interpret this
to ensure consistency).
- Micha
Date: 21 Jul 2002 16:49:16
Message: <Xns9252E790F9920raf256com@204.213.191.226>
Micha Riser <mri### [at] gmxnet> wrote in news:3d3b1cf6@news.povray.org
> own little ray-tracer and have to find a way to handle refraction with
> csgs.
me too :) But it's now - a 2d (!) program - just for testing some
algorithms. The important thing - it's a photons-tracer not
[camera]-ray-tracer. So it will work _much_ slower but will implement all
radiosity (true - with normals, specular etc), caustics etc in natural way.
Maybe some parts of code may be used in POV ? Normaly ray-tracing is
ofcourse very fast, but after some point of photo-realistics it may be
better to use photon-tracer, rather then make wark-around's for ray-tracer
limitations.
Date: 21 Jul 2002 16:50:26
Message: <3d3b1e92@news.povray.org>
In article <3d3b1cf6@news.povray.org> , Micha Riser <mri### [at] gmxnet>  wrote:
That is the wrong approach.  If you look at POV-Ray that way you will always
only run against walls and never get done anything.
    Thorsten
e-mail: tho### [at] trfde
Date: 21 Jul 2002 17:43:20
Message: <3d3b2af8@news.povray.org>
  I think that one of the most practical reasons for moving ior outside
the texture block is that when it was in the finish block it was possible
to define an ior which changes along the surface of the object (ie.
different parts of the surface have different ior), which gave a physically
completely incorrect result (in reality IOR never changes only in the
surface of an object).
Date: 22 Jul 2002 12:37:45
Message: <chrishuff-CD7B74.11304922072002@netplex.aussie.org>
In article <3d3b1cf6@news.povray.org>, Micha Riser <mri### [at] gmxnet>
Well, the method I'm considering with my own raytracer is to just forbid
overlapping transparent objects. After a ray enters a shape, the tracer
will only test against that shape until it exits again. Things will be
arranged so that each shape only has one material, so it won't enter
through a surface with one material and exit through one with a
different material. Non-refracting objects would be exempt from this, it
would be very undesireable for media containers.
One potential problem: exiting into the interior of a shape that is
overlapping. I'll probably just ignore this condition, it would be
impossible to say which object it entered into when several are
overlapping. It would be possible to check this condition, just check
the exit point to see if it is inside any other object, but that would
slow things down. Maybe for a scene debugging mode...
Another odd little trick I've been wanting to try: normally, when you
hit a surface like glass, you have to trace a refracted ray and a
reflected ray. With many transparent objects, this can create a lot of
rays very quickly.
The trick would be to randomly choose refraction or reflection. The rays
would never "branch", they would just take a random path through all the
possible paths. You would then take several samples for each pixel, each
sample would take a different path and you would get a fair
approximation for the pixel without tracing every single ray. I have no
idea how well this would actually work, but it seems like an interesting
idea.
Date: 23 Jul 2002 09:24:39
Message: <chrishuff-26297A.08172523072002@netplex.aussie.org>
In article <chr### [at] netplexaussieorg>,
Another problem with this: transparent objects inside other transparent
objects, like a glass marble in a pool of water. It would also make the
pool of water more difficult.
I think the only solution is to do something like what POV does and just
say that partially overlapping objects won't render correctly because it
is impossible to say what the "correct" way is. A render-time warning
might be helpful sometimes, but would usually be useless overhead.
Date: 24 Jul 2002 10:16:46
Message: <slrnajtdmf.d5q.ron.parker@fwi.com>
Careful what you call a bug.  You seem to be concerned that POV-Ray does
something unrealistic when you present it with a situation that cannot exist
in reality.  Why is this a problem?
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 24 Jul 2002 12:07:55
Message: <3d3ed0da@news.povray.org>
> exist
I called it a bug because ior has been moved from finish to interior
because ior has to be constant in the whole object to prevent that a ray
enters at one ior and leaves at a different one. But when two object of
different ior are merged / intersected exactly the same thing happens.
I see now that overlaping of transparent object in union cannot be checked
at parsing time and checking it during rendering would things slow down.
But in the case of merge/intersection a warning at parsing time could be
issued.
- Micha
Date: 24 Jul 2002 12:10:03
Message: <3d3ed15b$1@news.povray.org>
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:slr### [at] fwicom...
Something about the above statement, even though I understand it, makes my brain
hurt.
Date: 24 Jul 2002 12:12:58
Message: <3d3ed209@news.povray.org>
Well, it could still be done by cutting the space for the marble out of the
water. But with too many cuts out the performance gain would be lost.
- Micha
Date: 24 Jul 2002 12:28:26
Message: <chrishuff-932C85.11211724072002@netplex.aussie.org>
In article <3d3ed0da@news.povray.org>, Micha Riser <mri### [at] gmxnet>
There isn't really any way around that. At least it is an improvement.
One thing that has been bothering me is the "glass of water" type
situation...I'm not sure POV handles it correctly or how to model it
correctly.
> issued.
It is no more possible in those cases than it is in a union. They would
have to be checked at render time just like unions.
The best you could do is check if the bounding boxes overlap and give a
"possible overlap" warning if more than one object is transparent, but
that would happen so often it would be completely useless.
Date: 24 Jul 2002 12:34:03
Message: <3d3ed6fa@news.povray.org>
> rays very quickly.
> idea.
But how would you combine the sample values to the final value? Average
would be much too dark. Sum of course depends on the number of samples..
One would kinda have to estimate the number of all possible paths by
measuring the samples trace depth and then mulitplicate the average by that
number.
- Micha
Date: 24 Jul 2002 12:43:31
Message: <3d3ed933$1@news.povray.org>
news:3d3ed209@news.povray.org...
the
> - Micha
Doing this, you essentially increase the number of surfaces as you can't
have coincidental surfaces.
-tgq
Date: 24 Jul 2002 12:49:31
Message: <3d3eda9b$1@news.povray.org>
> correctly.
Here it is necessary to double up your surfaces so the surface of the water
is slightly outside the surface of the glass. ie, the ray exits the glass
into air and then into the water.  There is no way to avoid increasing the
number of surfaces in this case if you want it to work correctly. For
something completely immersed int the water (or glass for that matter) this
isn't necessary (in case you think this is contradicatory to my previous
post).
-tgq
Date: 24 Jul 2002 12:58:30
Message: <3d3edcb6@news.povray.org>
> correctly.
AFAIR the discussions about this problem the suggested why to do this is
make the water overlap the glass. Because leaving a space between will
cause multiple reflections. However I don't know if the overlaping is
handled as wished in that case.
>> checked at parsing time and checking it during rendering would things
>> slow down. But in the case of merge/intersection a warning at parsing
>> time could be issued.
It is in the nature of merges to overlap.Otherwise you could just as well
use union. It is even more in the nature of intersection memebers to
overlap ... otherwise you have a null object. So it would be natural to
assume at parsing time that merge/intersection do overlap and always issue
a warning when iors are different.
So forcing merge/intersection to have one single ior would not make the sdl
weaker because in that case where the merges do not overlap the user should
have used union anyways.
- Micha
Date: 24 Jul 2002 13:02:42
Message: <3d3eddb2@news.povray.org>
An alternative would be to allow objects be (compleatly) inside another. So
that the water object would have a list of its 'internal' objects. Tracing
ray inside the water would then only test for these interal objects and the
water container. Outside the water the interal objects would not have to be
considered.
- Micha
Date: 24 Jul 2002 13:31:25
Message: <chrishuff-DAB12C.12241724072002@netplex.aussie.org>
In article <3d3ed209@news.povray.org>, Micha Riser <mri### [at] gmxnet>
It wouldn't be a good solution. The interface between glass and water
should be a single surface, with two they would have to either overlap
or leave an air gap to avoid coincident surface problems. Overlap = bad,
air gap = an entirely different situation from the one being simulated.
Better to just say that if you are entering the marble you are exiting
the water. But when you exit the marble, what do you exit into? Could be
air, could be water...just check to see if the point is still "inside"
the water object?
If you can guarantee that the marble is completely immersed, a ray could
just check each surface against the last surface it hit to detect an
exit, but if it pokes through the surface...similar to the "glass of
water" situation.
Maybe a new type of "immersion" CSG would be helpful, some kind of
half-merge: surface A (water) does not exist inside surface B (marble),
but surface B does exist inside surface A.
immerse {
    FLUID_OBJECT
    IMMERSED_OBJECTS
Maybe separate ior entirely from the surfaces...say "this area of space
has glass ior, this area has water, everything else has air". Whenever a
surface is hit, check the ior at a tiny distance to each side. I don't
really like this solution, but I think it would work.
Maybe at the CSG stage, the ior on each side of the surface could be
computed and saved...
immerse {
    Water
    GlassCup
 ___ air ___
|g _|___|_  |
|l| |wat| | |
|a| |er | | |
|s| |___| | |
|s|_______| |
|___________|
A ray entering through the side of the glass and exiting either through
the water (a) or the other side of the glass (b):
1: Start in air, hit the glass surface.
2: Hit the water surface, ignore because still inside glass object, but
set "containing medium" to the water object.
3: Hit the glass surface again, exit to containing medium (the water).
4a: Hit the water. It is the containing medium, so exit into the next up
medium (air).
4b: Hit the glass again, go from containing medium (water) to glass.
5b: Hit the water surface, inside glass so ignore, but exit containing
medium to next up (air).
6b: Hit the glass surface, exit to containing medium (air).
This would require the immerse CSG, but it would work in every
(realistic) situation I've thought of.
Date: 24 Jul 2002 13:45:24
Message: <chrishuff-E445B9.12381724072002@netplex.aussie.org>
In article <3d3edcb6@news.povray.org>, Micha Riser <mri### [at] gmxnet>
Which is exactly what I was talking about...
Ah, I see what you are saying now. That would apply to all non-unions, I
think. And maybe different amounts of transparency as well as differing
iors. And a "nowarn" flag to turn off the warnings for those cases where
it is intentional.
Date: 24 Jul 2002 13:51:19
Message: <chrishuff-093E2E.12441124072002@netplex.aussie.org>
In article <3d3ed6fa@news.povray.org>, Micha Riser <mri### [at] gmxnet>
> number.
The sum should do the job...it would be darker than you would get by
tracing all the paths, but ideally the paths that are skipped would have
little contribution anyway. The first few samples are what would really
determine the color, the "root" of the tree would fill in first, it is
the furthest branches that would get left out. A simple scaling factor
could compensate for that, maybe automatically depending on depth.
Date: 24 Jul 2002 13:53:54
Message: <chrishuff-EF37ED.12464124072002@netplex.aussie.org>
In article <3d3eda9b$1@news.povray.org>,
> post).
That is a different situation, where the fluid doesn't "wet" the glass
and a layer of air is trapped between the two. That is a very easy case,
POV definitely doesn't have any trouble with that one, but water doesn't
usually do that.
Date: 24 Jul 2002 14:45:45
Message: <slrnajtter.db0.ron.parker@fwi.com>
It's handled correctly except for the very rare case where a ray enters
the water object without leaving the glass object.  If your surfaces are
close enough together, that almost never happens and AA will fix it if it
does.
POV keeps a list of all interiors it's inside, and when it hits another face
that has the same interior, it removes that interior from the list.  If it
wasn't the last interior, though, the IOR doesn't change.  That effectively
makes the glass faces that are inside the water "disappear" from the point
of view of refraction/TIR, though of course any textures will still be
computed.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 24 Jul 2002 22:14:01
Message: <chrishuff-CFA82F.21065324072002@netplex.aussie.org>
In article <slr### [at] fwicom>,
> does.
You mean where it just skirts the edge of the water object where it
overlaps but doesn't touch the inner surface of the glass?
> computed.
I see...I think. ;-)
Seems slightly similar to my immersion CSG, only ignoring the ior
instead of removing the entire surface, and quite a bit more general.
I'll just have to try to implement it for my own tracer, then I'll
understand it completely.
Date: 25 Jul 2002 00:56:15
Message: <pan.2002.07.25.04.55.38.836653.197@gte.net>
On Wed, 24 Jul 2002 12:49:10 -0400, TinCanMan quoth:
>> correctly.
> water is slightly outside the surface of the glass. ie, the ray exits
> the glass into air and then into the water.  There is no way to avoid
> increasing the number of surfaces in this case if you want it to work
> correctly. For something completely immersed int the water (or glass for
> that matter) this isn't necessary (in case you think this is
> contradicatory to my previous post).
> -tgq
If you could create the glass without an inner surface (perhaps by using
clipped_by), you would get the most realistic performance, since the ray
would go directly from glass to water, without passing through a layer of
air.
Mark
Date: 25 Jul 2002 09:16:20
Message: <slrnajvuh5.2ut.ron.parker@fwi.com>
>> does.
Right.  A very rare case indeed.
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C,T)bicubic_patch{type 1u_steps
6v_steps 6R(1)R(3)R(5)R(7)pigment{rgb z}}#end#macro _(Y)#local X=asc(substr(C,Y
,1))-65;<T+mod(X,4)div(X,4)9>-2#end#macro O(T)Q("ABEFUQWS",T)Q("WSXTLOJN",T)#
end O(0)O(3)Q("JNKLCGCD",0)light_source{x 1}// ron### [at] povrayorg
Date: 25 Jul 2002 11:38:40
Message: <chrishuff-9B5702.10313425072002@netplex.aussie.org>
In article <pan### [at] gtenet>,
> air.
If you cut away the water surface, the ray never "enters" the water
object. If you cut away the glass surface, it won't leave the glass
object until it reaches the other side of the cup, if it exits through
the top of the cup it will never become "outside" the cup.
As Ron Parker explained though, when there is an overlap the glass/water
transition is handled as it should be and the ior of the redundant
surface is ignored, so you don't need any special CSG. Still, there are
two extra surfaces in the body of the glass...that just bugs me, having
6 surfaces where 4 should be sufficient.
Maybe it would be possible to specify interior transitions on a
per-surface basis...instead of a "water object" and a "glass object",
the glass of water situation would be 3 separate surfaces: glass-air,
glass-water, and water-air. The modelling would be more difficult...it'd
probably only be worth it for a scene with a lot of glasses and bottles
of liquids (a lab or bar?) or if it was somehow automatically generated
(back to the immerse CSG?). Maybe a good trick for a real-time raytracer
though.
