POV-Ray : Newsgroups : povray.general : layered texture help please Server Time
3 Nov 2026 02:46:47 EST (-0500)
  layered texture help please (Message 1 to 16 of 16)
Subject: layered texture help please
Date: 14 Jul 2002 13:52:25
Message: <3d31ba59@news.povray.org>
Hi all,
I'm creating a layered texture and I want one of the layers to blur those
under it. The overall effect should be similar to adding guassian blur in
post-processing image software.
I've tried lots of combinations of pigments and normals but not achieved
much success. Any ideas?
thanks
jim
Subject: Re: layered texture help please
Date: 14 Jul 2002 14:06:44
Message: <3d31bdb4@news.povray.org>
This is not possible because you are not allowed to use patternd textures in
a layered texture.
But why dont you blur the normals and pigments under your layer manually?
Date: 14 Jul 2002 14:07:44
Message: <3d31bdf0$1@news.povray.org>
Simon Adameit <gom### [at] gmxde> schrieb in im Newsbeitrag:
3d31bdb4@news.povray.org...
in
> a layered texture.
It would also not be possible if you were allowed to do so...
Date: 14 Jul 2002 15:51:02
Message: <Xns924BDDB29352Fraf256com@204.213.191.226>
"James Taylor" <jim### [at] blueyondercouk> wrote in
news:3d31ba59@news.povray.org:
> Hi all,
1. use imag_map - generate texture.bmp (same as HF generation, but in
normal color mode), process it in external program, use image_map in pov :)
2. in case of i.e. sphere :
sphere { 0 5.0001 material { /*glass*/ normal { blur 0.3 scale 0.1 } }
sphere { 0 5 /* ......... */ }
simmilar thing could be probably done for more complex objects.
In glass material I suggest :
  pigment { color rgbf 1 }
  normal { bozo }
interior { ior 2 }
Rafa� 'Raf256' Maj
Date: 14 Jul 2002 16:06:19
Message: <3d31d9bb@news.povray.org>
> I'm creating a layered texture ... The overall effect
> should be similar to adding guassian blur ...
It's not possible. But you can come close by duplicating a texture layer
10-30 times (usually enough) each time with a small 'translate' to it, in
some direction (I suggest random directions for 3d textures, and for example
a circular direction for a 2d texture). This works quite well.
If you have a complex texture layer, duplicating it will get slow, but
sometimes - if you only need a defined area of the texture and not an
infinite non-repeating texture - then you can 'sample' the desired texture
area with the function{} keyword.. I succeded with this as well..
I can dig up the files, but perhaps you get the idea?
Hugo
Date: 14 Jul 2002 16:09:47
Message: <3d31da8b$1@news.povray.org>
What's that?  That's not Pov 3.5 ?
Hugo
Date: 14 Jul 2002 16:19:18
Message: <Xns924BE27C57FEAraf256com@204.213.191.226>
"Hugo" <hua### [at] post3teledk> wrote in news:3d31da8b$1@news.povray.org:
sorry - I was thinking about "bozo"
Rafa� 'Raf256' Maj
Date: 14 Jul 2002 16:23:25
Message: <3d31ddbd@news.povray.org>
Here is one. You will probably be able to improve it.
// Blur pigment from <0,0,0> to <1,1,0>
// by Hugo Asmussen
camera { location <0,0,-5> look_at 0 angle 48 }
light_source { <-80,80,-80>, 1 }
#declare Input=pigment { checker rgb 1,rgb 0 scale .5 }
#declare Layers=255; // between 1 - 255
#declare Amount=.025;
#declare Output=
pigment { image_map { function 50,50 {
 pigment { average pigment_map {
  #local Layers=1/Layers;
  #local Count=0;
  #while(Count<1)
   [1 Input translate vrotate(Amount*x,(360*Count)*z)  ]
   #local Count=Count+Layers;
 } scale .5 +(.5/25) }
} interpolate 2 }
box { <-10,-10,0>,<10,10,-1> pigment { Output } }
Date: 14 Jul 2002 18:08:43
Message: <3d31f66b@news.povray.org>
"Hugo" <hua### [at] post3teledk> wrote:
>...But you can come close by duplicating a texture layer
example
That's the one that'd do it :)
The texture I'm using is for a background on a plane aligned such that the
normal points towards the camera. It's basically a pigment_map with a
turbulent facet normal. The trouble is the facets produce abrupt edges and I
wanted a way to blur these a little - this technique seems like the way to
go...
thanks
jim
Date: 14 Jul 2002 18:23:24
Message: <3d31f9dc$1@news.povray.org>
> I wanted a way to blur these a little - this
> technique seems like the way to go...
If it's just a normal you want to blur, specifying a low accuracy might
do it; at least that's what the documentation says.
Rune
rune|vision:  http://runevision.com (updated July 12)
POV-Ray Ring: http://webring.povray.co.uk
Date: 14 Jul 2002 19:10:56
Message: <chrishuff-70EFA2.18081914072002@netplex.aussie.org>
In article <3d31f9dc$1@news.povray.org>,
That doesn't really give a blurring effect, just loss of small detail. I
don't think it would work very well with the facet normal. However, if
just the normal is being blurred, it might work to just use an averaged
normal instead of averaged textures. Might render a bit faster.
Date: 15 Jul 2002 20:22:22
Message: <3d33673e@news.povray.org>
What's the difference? It does give a blurring effect, as opposed to
abrupt changes.
It doesn't work with the special facets normal though, but for other
normals it works.
See for example here:
   location -3*z
   look_at 0
light_source {<1,2,-3>*100, color 1}
sphere {
   0, 1
   pigment {rgb 1}
   normal {
      crackle scale 0.3
      accuracy pow(10,sin(2*pi*clock)*0.6)*0.15
   finish {phong 0.5}
Render this as a cyclic animation. If that isn't blurring of the normal,
then I don't know what is...
Rune
Date: 16 Jul 2002 13:03:31
Message: <chrishuff-7F3B93.11581516072002@netplex.aussie.org>
In article <3d33673e@news.povray.org>,
> abrupt changes.
> normals it works.
If it was a blur effect, it would work with the facets pattern (it would
also be slower). It is just a reduction in accuracy. Small features
aren't blurred out, the gradient of the pattern just isn't sampled as
finely, so small details aren't picked up. The facets pattern doesn't
have a gradient, it is solved in a different way, so it won't work with
this trick. A true blur would work though.
Make an average texture of several textures with randomly jittered
normals...that's a blur. The effect of reducing the accuracy is just to
make the sample points farther apart, not to spread out the existing
features which is what a blur is.
Date: 16 Jul 2002 14:01:09
Message: <3d345f65$1@news.povray.org>
> isn't sampled as finely
I'm aware of the technical difference, but would you be able to spot the
difference in a rendered image? (Looking apart from the fact that the
real blur method will often create grainy results, while the accuracy
method won't.)
Rune
Date: 17 Jul 2002 05:24:08
Message: <3d3537b8@news.povray.org>
> the real blur method will often create grainy results,
> while the accuracy method won't.)
The method I posted here does not produce grainy results. There are no
jittering, and the amount of blur we need is usually small, so the steps
between samples aren't visible.
Your method was however a surprise to me. I didn't know there was an
'accuracy' available in normals. Though, my method blurs pigments, patterns,
or whole textures, not just normals.
Hugo
Date: 17 Jul 2002 12:27:10
Message: <chrishuff-BF55C1.11215917072002@netplex.aussie.org>
In article <3d345f65$1@news.povray.org>,
> method won't.)
The real blur method won't make grainy results. It might have "stepping"
results in some cases without enough samples, but not grainyness...
Yes, the difference would be visible, I'll work up some images to show
the differences. And the convolution matrix method (which is essentially
what the averaged texture method is) is much more flexible.
