POV-Ray : Newsgroups : povray.general : Shortest Code Contest, Round Two, display and voting page Server Time
3 Nov 2026 03:37:34 EST (-0500)
  Shortest Code Contest, Round Two, display and voting page (Message 1 to 23 of 23)
Subject: Shortest Code Contest, Round Two, display and voting page
Date: 2 Jul 2002 13:51:36
Message: <3d21e828@news.povray.org>
. . .  is now open.
http://10best.raytrace.com/short2/shortvote2.html
Votes accepted until July 17th, 2002.
Thanks to Mr.  W3 ABX Skiba for help in rendering (and to numerous others
who offered it earlier).
Subject: Re: Shortest Code Contest, Round Two, display and voting page
Date: 2 Jul 2002 15:18:32
Message: <3d21fc88@news.povray.org>
Greg M. Johnson <gregj;-)565### [at] aolco:-(m> wrote:
> . . .  is now open.
  Would it be possible that next time you could use some smarter program
to reduce the size of the images (for the thumbnails)? It looks like the
program you used reduced the images simply by dropping rows and columns
of pixels, which is not really nice.
  The images with most little details suffer the most from this. They end
up looking like random noise.
Date: 2 Jul 2002 17:19:42
Message: <3D2218BB.1010503@videotron.ca>
Greg wrote:
> . . .  is now open.
Hmm...  You might want to correct the typo on the viewing page:
"    * The voting period will close July 176h, 2002, at midnight (time
stamp on your email)."
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Date: 3 Jul 2002 01:57:46
Message: <n745iu0famk2im741ntethqccuehme639s@4ax.com>
> > . . .  is now open.
You are right. I missed this during conversion. I had no scope on thubnail
smoothing since I had already set Lanczos filter in my IrfanView. Looks like
batch converting in IrfanView has no setup for resize filter so I assume it
should get the same as for normal converting. But it doasn't. Greg I will
upload zip with correct thubnails after ten minutes at the same place as
previously.
ABX
Date: 3 Jul 2002 18:25:49
Message: <3d2379ed@news.povray.org>
Should be fixed in an hour or so.
Q: are the 800's the best they can be??
Date: 3 Jul 2002 18:41:52
Message: <3d237db0@news.povray.org>
  I would have made my images a LOT better, but with only 500 bytes available
it's not easy... ;)
Date: 3 Jul 2002 18:59:02
Message: <3d2381b6@news.povray.org>
Errr,  I mean is the render-quality of the 800's ok: I don't mean technical
merit and all that.............
Date: 3 Jul 2002 19:13:43
Message: <3d238527@news.povray.org>
  I knew that.
Date: 6 Jul 2002 18:32:16
Message: <3d276ff0$1@news.povray.org>
Aaah.  Some versions of IE will squish an image down to fit the browser
window if they are larger than the size it wants to give them.  The
squishing is apparently "AA 0.0."
Date: 6 Jul 2002 21:31:47
Message: <3d279a03@news.povray.org>
  Which is, of course, another braindead idea from MS.
  I suppose that it can be turned off...
Date: 6 Jul 2002 21:48:45
Message: <3d279dfd$1@news.povray.org>
yep.  This makes a *big* difference for one of the entries, but I won't say
which one...
Date: 6 Jul 2002 21:49:03
Message: <3D279E02.169380FF@pacbell.net>
If someone knows how let me know.
Ken Tyler
Date: 6 Jul 2002 23:41:05
Message: <3d27b851$1@news.povray.org>
    Yes. I know how.
Date: 7 Jul 2002 06:38:36
Message: <3d281a2c$1@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3D279E02.169380FF@pacbell.net...
http://wp.netscape.com/computing/download/index.html?cp=hop05ft6
Perhaps this beats Bill's answer for wit?
Date: 7 Jul 2002 07:06:15
Message: <3d2820a7@news.povray.org>
  I suppose that you mean:
http://mozilla.org/releases/
  Why use an older version when a newer is available?
Date: 7 Jul 2002 09:07:36
Message: <o6fgiuo8fjffbl8m7a1gvsm5r1nj7q9d1i@4ax.com>
  In MSIE 6.0, menu item Tools|Internet Options|Advanced|Enable
Automatic Image Resizing.
Alan
ako### [at] povrayorg
a k o n g <at> p o v r a y <dot> o r g
Date: 7 Jul 2002 09:40:26
Message: <3D2844BE.4DE893F@pacbell.net>
Thanks, Alan.
Ken Tyler
Date: 8 Jul 2002 11:59:11
Message: <3d29b6cf$1@news.povray.org>
news:3D2### [at] pacbellnet...
> Thanks, Alan.
And, of course, if you hover over the image, a graphic pops up that allows you
to toggle between screen size/image size.
Actually, I quite like this option - I could do with an easier universal toggle
and some sort of indicator that resizing has taken place, but whenever I've
turned it off completely, I pretty soon end up turning it back on again.
Date: 8 Jul 2002 20:55:12
Message: <qtckiugiqh2djpmg2gsgdla1g4iklhslmk@4ax.com>
  It sort of grew on me, and now I like it, too. I regularly download
larger-than-my-browser window images from my favorite WRC site. It's
nice not to have to scroll the window to see the rest of the images.
Alan
Date: 11 Jul 2002 07:02:12
Message: <mmoqiug368v6g3pfink48edu5grdiua8hp@4ax.com>
On Tue, 2 Jul 2002 13:31:55 -0400, "Greg M. Johnson"
> . . .  is now open.
I hope that playing with new official people don't forget to participate in
voting. What is the current status of it ?
I didn't noticed this mistake earlier but I'm W�odzimierz which can be
simplified to Wlodzimierz (the second letter is stroked L). I hope that when
registered www.povray.org users would have posting feature then it should fix
my language caprice.
ABX
Date: 11 Jul 2002 07:41:31
Message: <3d2d6eeb$1@news.povray.org>
> I didn't noticed this mistake earlier but I'm W³odzimierz which can be
when
fix
> ABX
I had been wondering what the little superscript '3' meant :)
Now how do you pronounce this this?
-tgq
Date: 11 Jul 2002 08:09:31
Message: <3d2d757b$1@news.povray.org>
    Just like it's spelled. With difficulty.
    Vladimir with a Russian accent?
Date: 14 Jul 2002 11:19:10
Message: <3d31966d@news.povray.org>
  This means that you are using the ISO-8859-1 charset (aka. ISO-Latin-1),
which is the most common charset.
  If you are going to use characters with values >127, you'll better use
the Latin-1 charset or just transliterate to ASCII, or else most people in
the world will see the wrong characters (as happened in this case). You just
can't assume that everyone in the world uses the same charset as you
(you can more or less assume this for the Latin-1 charset, even though not
*everyone* uses it, but most people by default).
  (Of course this depends a lot where you are. In Japan the most common
charsets are Shift JIS and EUC JP.)
  In webpages the situation is better because you can tell the charset to
use in the headers of the page (and then it's only up to the viewer to have
the proper browser support and font to view it).
