POV-Ray : Newsgroups : povray.general : proximity pattern Server Time
3 Nov 2026 04:28:41 EST (-0500)
  proximity pattern (Message 1 to 2 of 2)
Subject: proximity pattern
Date: 25 May 2002 14:13:35
Message: <3cefd44f$1@news.povray.org>
Does anyone have an idea as to how one could create an effect like the
"proximity pattern" in Pov 3.5? That is to say I have an object and I would
like to make an object pattern with it except I want the colors of the
pattern to be selectd from a color map according to the proximity to the
object. I was thinking that some sort of function that might be able to
achieve this.
H²
Subject: Re: proximity pattern
Date: 25 May 2002 14:29:42
Message: <3CEFD813.1C0BAD27@gmx.de>
> achieve this.
There were several experiments in that direction in the past, see for
example:
Subject: proximity/blur pattern finally adjusted
Date: Thu, 07 Mar 2002 08:52:33 +0100
From: Włodzimierz ABX Skiba <abx### [at] babilonorg>
Newsgroups: povray.binaries.images
Subject: proximity pattern in 3.5 example
Date: Fri, 08 Feb 2002 16:26:37 +0100
The rounded version of the IsoCSG library (iso_rcsg)
http://www-public.tu-bs.de:8080/~y0013390/pov/ic/index.html
also generates functions representing the distance to the surface, but as
soon as you use difference operations this is no more valid.
Last updated 05 May. 2002 _____./\/^>_*_<^\/\.______
