POV-Ray : Newsgroups : povray.general : Re: Continue-Trace and Booting... Server Time
23 Oct 2026 02:12:12 EDT (-0400)
  Re: Continue-Trace and Booting... (Message 1 to 4 of 4)
Subject: Re: Continue-Trace and Booting...
Date: 20 May 2002 07:13:57
Message: <3ce8da75@news.povray.org>
> So, I'm basically looking for an automatic way for POV
> to run and trace a certain image every time the computer
> starts up...
Perhaps if you put a shortcut to povray in the startup menu, using the
shortcut properties to specify certain command line parameters?
Or maybe you could set povray to *render* a file when it's opened rather
than open it in the editor, and then just put a shortcut to the file in the
starup menu?
 - Slime
[ http://www.slimeland.com/ ]
Date: 20 May 2002 07:59:43
Message: <3CE8E511.8384AF23@gmx.de>
Hm. Interesting ideas. I'll look into those...
Thanks!
> > starts up...
> starup menu?
>  - Slime
Tim Nikias
Email: Tim### [at] gmxde
Date: 21 May 2002 09:05:02
Message: <MPG.1754e2c0576261be9896ae@news.povray.org>
In article <3CE8E511.8384AF23@gmx.de>, tim### [at] gmxde says...
> Thanks!
> > > starts up...
> > starup menu?
> >  - Slime
> Tim Nikias
> Homepage: http://www.digitaltwilight.de/no_lights/index.html
How did you go, Tim?  I took a different path and experimented with
running it directly from the registry.
First create a POV ini file called (eg.) "D:\Graphics\RunRender.ini",
containing the file to render plus any options you want, eg:
  Height=480
  Width=640
  Input_File_Name="D:\Graphics\PoV Projects\thing.pov"
  Continue_Trace=on
Then to place a startup command in the Registry.  To make it easier to
load (if you choose to do this), create a text file called
"PoV-Render.reg", with contents (example below) matching your own
directory paths.  You can then simply double-click the REG file you
created to merge it into your registry, without having to run Regedit.
You only need to do this once, but there is no harm in subsequently re-
editing the .REG file and re-loading it, if you wish to change the
registry value.
The following is how Regedit exported my own Registry value to the
PoV-Render.reg text file, including the double-slash escape sequences.
[the last "two" lines are actually a single line, with a space between
"Windows" and "v3.5".]
--cut--
REGEDIT4
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run]
"PoV-Ray Render"="D:\\Program Files\\POV-Ray for Windows
v3.5\\bin\\pvengine.exe D:\\Graphics\\RunRender"
--cut--
To change your scene or options, just edit the RunRender.INI file.
To disable or re-enable it, simply use the msconfig utility:- a "PoV-Ray
Render" tick option is now in the "startup" tab!
Cheers,
   Brian.
"Strictly UNIX"    To dance is to live.
bel### [at] gilcomau
Date: 21 May 2002 13:21:41
Message: <3CEA8207.AA333657@gmx.de>
Well, I didn't have to do it for the image I was working on. It took
only two days, which I could judge from when it started, so I told
myself I could keep it running. If at some point I'll need waaaaay
longer than that, then I'd be fumbling with startup etc...
But I'll keep your method in mind (and on disk) in case I need it...
> > Thanks!
> > > > starts up...
> > > starup menu?
> > >  - Slime
> > Tim Nikias
>   Height=480
>   Width=640
>   Continue_Trace=on
> registry value.
> --cut--
> REGEDIT4
> --cut--
> Cheers,
>    Brian.
Tim Nikias
