In RL, is there any difference between highlights and blurred reflection?
#macro G(D,E,F)#local I=array[3]{D,E,F}#local B=0;triangle{#while(
B<3)#while(I[B])A[mod(I[B],10)]+#local I[B]=div(I[B],10);#end<-5,-
2,9>#local B=B+1;#end}#end #local A=array[7]{x,x*2,x*4,y,y*2,y*4,z
}light_source{-x*6-z*9,1}mesh{G(105,10,146)G(105,246,10)G(105,56,
146)G(105,1256,246)G(1256,126,220)G(22156,2216,201)pigment{rgb 1}}//TM
In real life there are neither highlights nor blurred reflections, only
waves, photons, atoms and a lot of interferences and even those are only
fairly accurate models.
Last updated 05 May. 2002 _____./\/^>_*_<^\/\.______
I'm pretty sure there isn't. You never see highlights on materials that
reflects mirror-like, only on materials which have "blurred reflection".
You also don't see highlights on surfaces that don't reflect at all.
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Apr 14)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring: http://webring.povray.co.uk
"Tom Melly" <tom### [at] tomandlu co uk> wrote in message
news:3cdb9e68$1@news.povray.org...
Highlights seen in real life are pretty much the same as reflection, blurred
or otherwise (i.e., highlights on shiny plastic, highlights on rough
plastic.) If you look closely at a highlight (the less blurred it is) you
should be able to see that it's shape resembles that of the reflection of
light sources or other bright objects.
Lately, in my modeling of textures, I have been trying to avoid using
specular or phong highlight models (in fact, I don't know when the last time
I used them was) in favour of fresnel reflection, visible light sources and
surface 'micro-normals' (see Duckie and Duckie II from a couple of weeks
ago in p.b.i, no highlight models were used). However, using this requires
high AA settings and longer render times in order to render the textures
properly.
-tgq
This of course depends on how you define 'highlight', but you can surely
see a bright spot on a mirror ball when illuminated by a light source like
the sun.
The reason for using specular/phong models to simulate the highlight
effect is not only to avoid calculating blurred reflection but also
because you commonly use invisible light sources.
time
and
May sound attractive to use such techniques but the rendertime > down the
abyss... And doesn't look much different in the end, based on my tries...
Does fresnel make any difference unless a material has an IOR value? I
think, only transparant objects should have IOR... Tell me I'm wrong?
Hugo
"Hugo" <hua### [at] post3 tele dk> wrote in message
news:3cdbb971@news.povray.org...
> time
> and
In order for fresnel to work (in 3.5) you need an ior. Read the 3.5 docs on
fresnel for a better understanding and explanation of how it works. giving
an opaque object an ior value will only affect fresnel reflections since you
can't see through the object anyways.
As for the results looking the same, this is somewhat true for circular
light sources, but not for light sources with other shapes. i.e., ambient
light coming from a square window.
I guess when it comes down to it, I'm a bit of a perfectionist and would
rather try to produce highlights in a more realistic fashion than using
highlight simulation models.
-tgq
Not quite true. The "Real World," what physicists refer to as "local
non-contextual reality," is composed of cars, trees, planets, apples, people
and computers. In this reality, specular highlights are indeed blurred
reflections.Wwaves, photons, atoms and quantum entanglements (interferences)
can only be measured indirectly and are not what most people consider part of
the the real world. A good joke, but a straight answer might have sufficed
here.
> the sun.
You are just seeing the Sun reflected on the ball. :)
Of course, but you don't get it in a raytracer if you just use a point
light and no specular finish.
> just use a point light and no specular finish.
I'm sure no one doubt that, but we were talking about real life here...
Rune
This is exactly what i was talking about, in real life highlights (which i
would define as the bright spot appearing on on illuminated shiny
surfaces) are caused by reflection on the surface. Whether the reflection
is blurred or not (in other words how rough the surface is) only
influences the characteristics of the highlight.
> life highlights (which i would define as the bright
> spot appearing on on illuminated shiny surfaces) are
> reflection is blurred or not (in other words how
> rough the surface is) only influences the
With your definition of a highlight, that is correct. I don't know what
the actual definition of a highlight is, but when I see a light bulb in
a mirror I usually don't think of it as a highlight.
Rune
Dave Dunn wrote:
> [...] Wwaves, photons, atoms and quantum entanglements (interferences)
> the the real world.
Huh? I don't see why interferences are only detectable less diretly than
cars, trees and planets, but that's merely a philosophical question of
course.
