POV-Ray : Newsgroups : povray.general : Radiosity Artifact Smoothing Server Time
15 Aug 2025 20:13:57 EDT (-0400)
  Radiosity Artifact Smoothing (Message 1 to 3 of 3)
Subject: Radiosity Artifact Smoothing
Date: 19 Apr 2002 23:32:33
Message: <3cc0e151$1@news.povray.org>
Lightwave3D has a feature where it smooths or blurs the radiosity artifacts,
and it seems to work fairly well. It would be great to see this in POV-Ray
as well. I have tried this in photoshop and it is much more pleasing to the
eye to see smoothed out inaccuracies rather than patchy ones. However this
really needs to be done inside of POV-Ray since doing it in photoshop for
all but the simplest scenes with no textures is impractical.
George Pantazopoulos
Subject: Re: Radiosity Artifact Smoothing
Date: 23 Apr 2002 12:54:01
Message: <3CC591B8.E05F9DC7@luxlab.com>
First render with low error_bound, without aa:
  nearest_count 1
  error_bound 0.1
  save_file "rad"
Then with higher error_bound:
  pretrace_start 1
  pretrace_end 1
  nearest_count 1
  error_bound 0.4
  load_file "rad" always_sample off
This averages more samples from the first render. Setting
nearest_count higher didn't improve quality on the scenes
I have tested this. Just made it slower. The first render
doesn't need to be full resolution because the image isn't
used anyway. When reducing resolution maybe also reduce
minimum_reuse the same amount.
If the scene contains transparent objects this two phase
method also cuts down render time. Just set max_trace_level
to the minimum so that rays still pass through transparent
objects and use diffuse 0, ambient 0, no normal and no
reflection on those objects for the first render.
_____________
Kari Kivisalo
Date: 23 Apr 2002 16:52:55
Message: <3cc5c9a7@news.povray.org>
Thanks for the advice Kari, I'll try that out !
"Kari Kivisalo" <pro### [at] luxlabcom> wrote in message
news:3CC591B8.E05F9DC7@luxlab.com...
>   nearest_count 1
>   error_bound 0.1
>   save_file "rad"
>   pretrace_start 1
>   pretrace_end 1
>   nearest_count 1
>   error_bound 0.4
> _____________
> Kari Kivisalo
