POV-Ray : Newsgroups : povray.general : function question Server Time
3 Nov 2026 07:11:38 EST (-0500)
  function question (Message 1 to 16 of 16)
Subject: function question
Date: 3 Apr 2002 16:20:36
Message: <3cab7224$1@news.povray.org>
Can I define a function that takes a float and returns a vector?
Something like this:
function Get_Vec {<x^2,x^3,x^4>}
Get_Vec (2) ------> <4,8,16>
Do I have to use a macro to accomplish this?
 -Shay
Subject: Re: function question
Date: 3 Apr 2002 16:24:26
Message: <dismau0b4okcpjbttn20s9pc7lhftp9smo@4ax.com>
Not directly but there is possible workaround.
If it is called only at parse time then macro version could be simpler to code.
ABX
Date: 3 Apr 2002 16:33:59
Message: <3cab7547@news.povray.org>
No.
Either that or something like:
#declare vec = <Get_VecX(2),Get_VecY(2),Get_VecZ(2)>;
Jonathan.
Home: http://digilander.iol.it/jrgpov
Date: 3 Apr 2002 16:37:06
Message: <3cab7602@news.povray.org>
Thanks, guys. I'm going to have to time the workaround against a macro. I am
thinking of building combination fractal / 3D knots so speed is a very
important consideration.
 -Shay
Shay <sah### [at] simcopartscom> wrote in message
news:3cab7224$1@news.povray.org...
Date: 3 Apr 2002 16:37:22
Message: <3cab7612@news.povray.org>
You mean some cyiptic code?
Jonathan.
Date: 3 Apr 2002 16:40:39
Message: <ljtmauofa469e877m395m9e19pl5fl8djj@4ax.com>
It depends what you mean as cyiptic.
ABX
Date: 3 Apr 2002 16:43:15
Message: <3cab7773@news.povray.org>
> ABX
Oops, I meant "cryptic".
Jonathan.
Date: 3 Apr 2002 17:12:44
Message: <jltmaukpci64s7497l1qdr79asqpl6tpln@4ax.com>
// at first you have to code functions for each component of your vector
// sample operations attached
#local f_X = function ( float ) { float };
#local f_Y = function ( float ) { float/2 };
#local f_Z = function ( float ) { float/3 };
// then you have to bound possible results
// bounding can be pretty large but remember about accuracy problem
#local X_Min = -10000;
#local X_Max = 2560;
#local Y_Min = 1000;
#local Y_Max = 1280;
#local Z_Min = 1000;
#local Z_Max = 3300;
// then you have to calculate ranges of coordinates
#local X_Range = X_Max - X_Min;
#local Y_Range = Y_Max - Y_Min;
#local Z_Range = Z_Max - Z_Min;
// now create pigment inside ranges
// our float is supposed to be at x coordinate position
#local P = pigment{
  average
  pigment_map{
      1
      function { ( f_X(x) - X_Min ) / X_Range }
      color_map { [0 red 3*X_Min] [ 1 red 3*(X_Range+X_Min) ] }
      1
      function { ( f_Y(x) - Y_Min ) / Y_Range }
      color_map { [0 green 3*Y_Min] [ 1 green 3*(Y_Range+Y_Min) ] }
      1
      function { ( f_Z(x) - Z_Min ) / Z_Range }
      color_map { [0 blue 3*Z_Min] [ 1 blue 3*(Z_Range+Z_Min) ] }
// now convert pigment to function
#local F=function{pigment{P}};
// finally call function putting float at x position and putting anything
// (for example 0) at x and y position
#local V = F(300,0,0);
// remember result is 5D vector (color) so before use as 3D recconvert it
#include "strings.inc"
#warning VStr( <V.x,V.y,V.z> )
// ABX
// I hope I will be considered as the father of this method ;-)
Date: 3 Apr 2002 17:16:19
Message: <0ovmauor2afad073nh0s42uhjjv5qqq2gg@4ax.com>
It depends what you mean as cryptic.
Anyway code after moment in this thread so You'll see it is cryptic or not.
ABX
Date: 3 Apr 2002 17:21:02
Message: <vvvmaus0bvr1jq81bl52sdf4nsqvlvb6cm@4ax.com>
On Thu, 04 Apr 2002 00:12:05 +0200, W�odzimierz ABX Skiba <abx### [at] babilonorg>
should be rather
#local Y_Min = -1000;
#local Z_Min = -100;
ABX
Date: 3 Apr 2002 17:30:48
Message: <3cab8298$1@news.povray.org>
W³odzimierz ABX Skiba <abx### [at] babilonorg> wrote in message <
><snip>
> should be rather
> <snip
Z = -1000?
The only part of your process that I do not understand is the bounding
process. Are the bounds chosen arbitrarily, or is there a method for
assigning bounds?
 -Shay
Date: 3 Apr 2002 17:33:17
Message: <3cab832d@news.povray.org>
Never mind. I just figured it out.
news:3cab8298$1@news.povray.org...
Date: 3 Apr 2002 17:39:52
Message: <un0naussdera8t89o4n8gttvebm6gdk8m0@4ax.com>
> assigning bounds?
Bounding is necessary to rescale value from space to 0-1 entry for color map in
color component and then rescale back to original value. Every scaling requires
origin of scaling and scale value - here they are min and range value.
Presented values are randomly choosed without any important rule. My suggestion
is to use something like:
#local X_Max = 1e5;
#local X_Min = -X_Max;
and the same for Y and Z.
You have to remember that outside bounding results can be wrong.
ABX
Date: 3 Apr 2002 17:59:31
Message: <3cab8953$1@news.povray.org>
I'm going to time this method tonight against <get_x, get_y, get_z> and
macro.
I will post the results tomorrow.
I understand why you are scaling the results to an appropriate range for the
color map, but is it really necessary. Can a pigment function not return
values greater than 1 for a hue? I know that Povray will accept {rgb
<100,30,80>} or even {rgb <-1,-1,-1>}. Does a pigment function behave
differently? I will test this tonight.
 -Shay
Date: 3 Apr 2002 18:33:28
Message: <664nau8q81a42tlo21afo1e6gal8ebjs49@4ax.com>
Pigment can return values greater than 1. My methor return values greater than
1. Only problem is that map entries are placed along <0,1> range.
ABX
Date: 3 Apr 2002 18:36:45
Message: <9e4nau079sb1fsbc4ui4gbnnnr7mfc659m@4ax.com>
'6.7.1.3  Color Maps' second paragraph
ABX
disc{z,-z#macro O()asc(substr("-+((1*(,1,/.-,*/(,&.323/'1"e,1))*.1-4#declare
e=e-1;#end#local e=26;5pigment{#local g=function(_){ceil(_)-_}function#local
k=function{pattern{object{sphere_sweep{linear_spline 13#while(e)<O(),O()//35
>.01#end}}}}{k(g(atan2(x,y)),g(ln((y+x)^2+1e-5)),0)}}finish{ambient 1}}//ABX
