POV-Ray : Newsgroups : povray.general : Infinite object question Server Time
16 Aug 2025 07:45:27 EDT (-0400)
  Infinite object question (Message 1 to 10 of 42)
Subject: Infinite object question
Date: 2 Apr 2002 14:15:27
Message: <3caa034f@news.povray.org>
When I try to render this object Povray tells me it is infinite.  The
"bounded_by"
seems to have no effect on this object.   Why does Povray think this is
infinite?
#declare One =
difference {
   height_field {
      tga "MyPicture.tga"
      smooth
      hierarchy on
      translate <-0.5, -0.5, -0.5>
      rotate <-90,0,0>
      scale <0.3,1,0.1>
      photons {target reflection on}
   box{<-0.2,-0.6,-0.02>,<0.2,0.6,2> pigment {rgbft <1,1,1,0,1>}
      no_shadow no_reflection no_image photons {collect off}
    bounded_by { box{<-5,-5,-5>,<5,5,5>}}
object{One}
Subject: Re: Infinite object question
Date: 2 Apr 2002 14:20:46
Message: <3caa048e@news.povray.org>
  So?
> The "bounded_by" seems to have no effect on this object.
  Why should it?
  bounded_by does not change the shape or dimensions of an object. It's
not CSG.
> Why does Povray think this is infinite?
  Because it is?
Date: 2 Apr 2002 14:22:33
Message: <3caa04f9$1@news.povray.org>
I'm trying to use it with photons and reduce the time it requires.  That is
why.  I see no reason why this
would be infinite.
news:3caa048e@news.povray.org...
>   So?
>   Why should it?
> not CSG.
>   Because it is?
M()}}
Warp -
Date: 2 Apr 2002 14:34:37
Message: <3caa07cd@news.povray.org>
Ah, I see.
  The problem is that the box is inverted. (It's implicitly inverted because
you are using a difference.)
  But there's a solution to the problem: Clip the entire CSG with for
example a box.
Date: 2 Apr 2002 15:15:48
Message: <3caa1174$1@news.povray.org>
The inverted box should still not be infinite.  Clipping the entire csg
results in no image!
news:3caa07cd@news.povray.org...
>   Ah, I see.
because
> example a box.
M()}}
Warp -
Date: 2 Apr 2002 15:30:58
Message: <3caa1501@news.povray.org>
  An inverted box is infinite.
  How did you clip it?
  Just add something like clipped_by { box { -1,1 } } at the end of the CSG
or whatever.
Date: 2 Apr 2002 16:51:07
Message: <3caa27cb$1@news.povray.org>
No, it's not.
At least not from POV-Ray's point of view (just try).
Jonathan.
Home: http://digilander.iol.it/jrgpov
Date: 2 Apr 2002 17:01:20
Message: <f1akau43uc8teqpiq8pcch83k4s23rjkui@4ax.com>
> No, it's not.
it is
ok, try inverse box - it is hole in everything
// begin scene
box{-1 1 translate z*10 inverse}
// end scene
Warning: Camera is _inside_ a non-hollow object.
And put camera anywhere to test where box will finish.
But You can be mistaken by:
// begin scene
#include "strings"
#local B=box{-1 1 translate z*10 inverse}
#warning VStr(min_extent(B))
#warning VStr(max_extent(B))
// end scene
but min/max_extent returns coordinates of _bounding box_ which isn't object but
speed trick - as documentation says: "the bounding box does not represent the
actual dimensions of the object".
ABX
Date: 2 Apr 2002 17:08:03
Message: <3caa2bc3$1@news.povray.org>
That does not make it an infinite object.
I can read:
"scene contains 1 frame level objects; 0 infinite".
Either an inverted object isn't infinite, or that message is wrong.
BTW, I used difference many times, and my CSG objects never happened to become
infinte.
Jonathan.
Date: 2 Apr 2002 17:17:47
Message: <chrishuff-0655F0.17185602042002@netplex.aussie.org>
In article <f1akau43uc8teqpiq8pcch83k4s23rjkui@4ax.com>,
> // begin scene
> // end scene
You are mistaken. This message means exactly what it says, the camera is
inside the box. It has nothing to do with finite-vs-infinite, any solid
shape can produce it. If you put it at < 0, 0, 0>, you won't get this
message.
> object but speed trick - as documentation says: "the bounding box
> does not represent the actual dimensions of the object".
But infinite objects don't have finite bounding boxes. And anyway, the
bounding box of an axis-aligned box is pretty accurate.
