POV-Ray : Newsgroups : povray.general : contained_by problem... Server Time
16 Aug 2025 17:10:54 EDT (-0400)
  contained_by problem... (Message 1 to 10 of 15)
Subject: contained_by problem...
Date: 31 Mar 2002 12:32:43
Message: <3ca7483b@news.povray.org>
I am having problems trying to contain an object.  The object defined is:
#declare DaggerHilt =
union {
   difference {
      height_field {
         tga "DaggerHilt.tga"
         smooth
         hierarchy on
         translate <-0.5, -0.5, -0.5>
         rotate <-90,0,0>
         scale <0.3,1,0.1>
         photons {target reflection on}
        XXXXXXXXXXXXXXXXXX
      box{<-0.2,-0.6,-0.02>,<0.2,0.6,2> pigment {rgbft <1,1,1,0,1>}
         no_shadow no_reflection no_image photons {collect off}
   difference {
      superellipsoid {<0.10, 0.30> scale <0.033,0.11,0.045>}
      cylinder{<-0.15,0,0>,<0.15,0,0>,0.015 translate <0,0.10,-0.05>}
      cylinder{<-0.15,0,0>,<0.15,0,0>,0.015 translate <0,-0.10,-0.05>}
      cylinder{<-0.15,0,0>,<0.15,0,0>,0.015 translate <0,0.10,0.05>}
      cylinder{<-0.15,0,0>,<0.15,0,0>,0.015 translate <0,-0.10,0.05>}
      translate <-0.01,0.005,-0.035>
     XXXXXXXXXXXXXXXXXXX
   texture {BChrome rotate z * 90}
   XXXXXXXXXXXXXXXXXXXXX
The XXXXXX lines are different places where I have tried to place a
container.  In this case the container would be:
contained_by {box <-2,-2,-2>,<2,2,2>}
Povray tells me that it expects the end of the union or difference
(depending on where I place the container.)  If I don't contain this
object povray considers it infinite.  I'm trying to get rid of the infinite
objects to help the photons.
How can I contain this thing or make it finite?
Patrick Dugan
Subject: Re: contained_by problem...
Date: 31 Mar 2002 12:40:02
Message: <3CA74A84.D41629C3@pacbell.net>
>snip>
There is no reason why with that scale POV-Ray should be treating the HF
as an infinite object. Are you sure that you don't have a plane or something
else in the scene that is infinite?
P.S. contain_by is only valid syntax in isosurface objects.
Ken Tyler
Date: 31 Mar 2002 12:49:09
Message: <3ca74c15@news.povray.org>
I *thought* I used contained_by with other objects in the past, but perhaps
the syntax has changed since then.
No the object was copied here verbatim.  If I comment out this object the
infinite goes to zero.  With it the infinite goes to 1.
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3CA74A84.D41629C3@pacbell.net...
is:
> >snip>
something
> Ken Tyler
Date: 31 Mar 2002 13:00:14
Message: <3CA74F44.3AFF5602@pacbell.net>
Perhaps you are confusing contained_by with bounded_by ?
Ken Tyler
Date: 31 Mar 2002 13:28:41
Message: <3ca75559$1@news.povray.org>
Ahhhhhh!!  Yes you are right!  Thank you!
news:3CA74F44.3AFF5602@pacbell.net...
perhaps
> Ken Tyler
Date: 31 Mar 2002 13:30:16
Message: <3ca755b8$1@news.povray.org>
You probably used clipped_by or bounded_by- most likely the latter. Try one of those
instead of an iso keyword.
"Patrick Dugan" <pat### [at] netinsnet> wrote in message
news:3ca74c15@news.povray.org...
> is:
> > >snip>
> something
> > Ken Tyler
Date: 31 Mar 2002 13:30:59
Message: <3ca755e3$1@news.povray.org>
I'm still not sure why it was infinite though...
perhaps
> Ken Tyler
Date: 31 Mar 2002 13:38:37
Message: <QXx$oFAnd1p8Ewym@econym.demon.co.uk>
Perhaps you are confusing contained_by and clipped_by ?
Mike Williams
Gentleman of Leisure
Date: 31 Mar 2002 13:56:49
Message: <3ca75bf1@news.povray.org>
  Does clipped_by convert an infinite object to a finite one (internally,
I mean)?
  The best thing to do is:
clipped_by { something } bounded_by { clipped_by }
Date: 31 Mar 2002 15:07:05
Message: <chrishuff-530D90.15080431032002@netplex.aussie.org>
In article <QXx$oFAnd1p8Ewym@econym.demon.co.uk>,
It doesn't sound like it...bounded_by is the feature used to, well,
bound infinite objects, and based on the description it is the one he
wants.
The clipped_by feature is for removing parts of an object that are
outside another object, which doesn't seem to have anything to do with
this.
The contained_by keyword is only used in isosurfaces, to specify the
volume in which to test for the surface. It has never been used for
other objects (except maybe parametric), and wasn't even added until
after the isosurface patch had been around a while. (previous versions
reused bounded_by, which caused some problems)
